Old 06-02-2012, 04:32 PM   #1
Partial Stall
Drives: '13 WRB BRZ
Any (easy) way to stiffen up the feel of the clutch?
I love my new BRZ, but with the soft clutch its hard to know when the tranny couples with the engine. Is there some way I can adjust the clutch so I get more feel out of it?
Partial Stall is offline   Reply With Quote
Old 06-02-2012, 04:43 PM   #2
OrbitalEllipses
Drives: Attitude
Check if there's a clutch delay valve; unhooking that will give you more direct and less dampened clutch feel.
Old 06-02-2012, 07:46 PM   #3
DespaiRepair
DespaiRepair's Avatar
Drives: white 2013 Scion FR-S
Question
Make sure to post if you find an answer because I definitely would like a little more clutch feel....
DespaiRepair is offline   Reply With Quote
Old 06-02-2012, 08:11 PM   #4
Julio86
Julio86's Avatar
Drives: 2013 Scion FR-S 6MT
This^^^^
Love the car not the clutch do much
I don't always drift every corner, but when I do, I drift FRS . Stay drifty my friends
2013 Scion FRS Whiteout 6MT
Julio86 is offline   Reply With Quote
Old 06-02-2012, 08:17 PM   #5
dsgerbc
Drives: BRZ(sold), STI
Honestly, when I just got the car I thought that it was needed too, but after roughly 500 miles I got used to it and don't think this is needed.
dsgerbc is offline   Reply With Quote
Old 06-02-2012, 08:20 PM   #6
Julio86
Julio86's Avatar
But for those who do? Lol
Old 06-02-2012, 08:22 PM   #7
dsgerbc
Buy TIS 2-day access for $15 and study the service manual portion related to clutch?
Old 06-02-2012, 08:23 PM   #8
Partial Stall
Drives: '13 WRB BRZ
At 250 miles now and I'm starting to get used to it a bit more I guess, but the entire rest of the car is so hard and precise that having a floppy clutch
is kinda a joke.
Old 06-02-2012, 08:23 PM   #9
Julio86
Julio86's Avatar
Link?/where? Thnx btw
Old 06-02-2012, 08:24 PM   #10
dsgerbc
techinfo.toyota.com
Old 06-02-2012, 08:27 PM   #11
old greg
Rocket Surgeon
Drives: PSM GGA OMG
That depends on what you consider "easy". The easiest solution would be to wait for some aftermarket clutch company to make a more heavily sprung clutch, buy it and pay someone else to install it for you. Alternatively, find out the bore of the stock clutch master cylinder (it should be stamped into the side of the MC), then get a larger bore clutch master cylinder for some other Subaru and hope it fits.
old greg is offline   Reply With Quote
Old 06-02-2012, 11:20 PM   #12
Future
Future's Avatar
Drives: BRZ!
(I don't have the car yet...) If it is like my previous IS300, there could be a tiny damper between the master and the slave in the engine, you just unscrew it, put a fitting to connecter the two ends together, and boom 100% more clutch feel.
Many will likely say the FR-S/BRZ needs more power and while more wouldn’t hurt, those folks (the same ones who have probably never driven on a track) are missing the point.
Future is offline   Reply With Quote
Old 06-03-2012, 01:46 AM   #13
ahausheer
Re-member
Drives: Toyota camry
Is that line fluid filled or is it a vacuum line? What does the damper do? how does it change the feel exactly and are there any drawbacks?
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 06-03-2012, 02:28 AM   #14
old greg
Rocket Surgeon
Drives: PSM GGA OMG
That's the hydraulic line for the clutch, the damper is mounted inline with the master and slave cylinders and effects the flow of fluid between the two.
Short answer: NVH.
Torque pulses from the crankshaft cause vibrations in the flywheel that are transferred through the clutch release mechanism during clutch (dis)engagement. These vibrations travel through the clutch hydraulic line, through the master cylinder and into the pedal where they can be felt and sometimes heard by the driver. The damper gets rid of these vibrations.
It doesn't change the pedal effort, it just disconnects you a little from the clutch. It's a bit like steering rack bushings; the car turns the same with soft bushings but you don't get the same direct feedback/response feeling you would have with stiffer bushings.
On some cars, they are also set up to restrict the maximum flow rate of fluid from the slave cylinder to the master cylinder as a sort of anti-clutch-drop measure to help keep transmissions in one piece. A prime example is the WRX: 2002 = no damper, 2003 = damper.
Clutch/brake smell mr2lor Scion FR-S / Toyota 86 GT86 General Forum 8 05-24-2012 01:45 PM
Clutch wear? Pakjk89 Engine, Exhaust, Transmission 102 04-12-2012 07:21 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
Steering Wheel Feel ap5512 BRZ First-Gen (2012+) — General Topics 8 12-08-2011 11:16 AM
Feel like a Post Whore. Siriusly.Andrew Off-Topic Lounge [WARNING: NO POLITICS] 60 03-14-2010 05:42 PM
