Old 05-09-2013, 02:14 PM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by sw20kosh View Post
Did I miss it? What boost pressure was run for this dyno graph?
Knowing John it was north of 10 psi.
Old 05-09-2013, 02:33 PM   #16
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Power looks low for 10, probably 8-9. 10psi should be closer to 300whp I would think.
raul is offline   Reply With Quote
Old 05-09-2013, 02:45 PM   #17
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
O-rings can be serious business... They brought down the space shuttle, Challenger, back in '86--no joke.
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
The Following 2 Users Say Thank You to GTB/ZR-1 For This Useful Post:
King Tut (05-09-2013), sw20kosh (05-09-2013)
Old 05-09-2013, 02:53 PM   #18
King Tut
NASA SpecE30 Racer
King Tut's Avatar
They would have taken down my car and David's car if we hadn't fixed it. They could definitely take down a Scion dealer installed Full Blown car as well.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
bakerr6 (07-04-2013), SmsAlSuwaidi (05-09-2013), Sportsguy83 (05-09-2013)
Old 05-09-2013, 02:53 PM   #19
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I love generalizations.
Old 05-09-2013, 02:59 PM   #20
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Something I have to keep an eye out when I install my first turbo kit ever
Old 05-09-2013, 03:28 PM   #21
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
I do to. Generally.
I really do dislike when these threads pop up without any valuable information regarding modifications, charts, and conditions from the OP.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 05-10-2013, 11:21 PM   #22
driver01
Drives: brz 13
Originally Posted by Foobar View Post
Hey you were by my neck of the woods on Long Island! Dyno looks good!
Yeah, I was quite far from work
Originally Posted by deucethemoose View Post
So what are the official modifications and when can we expect an official dyno chart?
John is still playing with the boost control with ecutek
Originally Posted by DIM View Post
Post a video of this thing in action!
working on it
Originally Posted by Calum View Post
What octane was that on?
Looks great!
sunoco 93
Originally Posted by JackSmiley View Post
what other mods have you done?
nameless front pipe with high flow cat and hks spec l catback, perrin foam filter, deatschwerks injectors and deatschwerks pump
Originally Posted by djdnz View Post
Pretty impressive that he carries around spare o-rings of all things. Very cool to have a tuner who is so knowledgeable on these cars.
i am very thankful he does, otherwise my long road trip would have been for nothing
How many O-rings had you used? did you use the white plastic spacer below the O-rings? Do you have his fuel pump?
as per the instructions from deatschwerks i used two orings. did not transfer
the spacer and o ring from the oem pump
8-10 psi
Originally Posted by dabocx View Post
stock exaust?
hks hi power spec l exhaust
I do to. Generally.
conditions were slightly cold, probably around 16 - 19 degrees celsius.
on a mustang dyno. I am running the hks oil cooler which seems to be doing an excellent job. the greddy profec ecb was not holding boost as flat as I would have like, so changing to ecutek boost control was as easy to connect two wires. still working on it but the boost line looks excellent.
I have a lot more modifications but i believe the listed ones are the only affecting power
driver01 is offline   Reply With Quote
The Following 2 Users Say Thank You to driver01 For This Useful Post:
Calum (05-11-2013), Sportsguy83 (05-10-2013)
Old 05-10-2013, 11:26 PM   #23
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
MRP's dyno has been known to break some hearts in the past. Great numbers!
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 05-10-2013, 11:33 PM   #24
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
So now you have 4 O-rings? And, does the canister still close like normal with the added
o-rings?
I so much wish you tell me you are still using two, but fear you say 4. I don't want to take that shit out of the tank anymore!!!!
Old 05-11-2013, 12:12 AM   #25
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
I wonder what it takes to make this kit hit 310-320 whp and 250-270 wtq on pump 93.
JackSmiley is offline   Reply With Quote
Old 05-11-2013, 12:17 AM   #26
AVOturboworld
A hub dyno and 10.5 psi of boost.
Already hit 250~260 ft/lbs at 10.5psi, and 295whp on 92. After that, though, you are looking at a fuel pump, possibly injectors, and definitely a clutch.
Old 05-11-2013, 12:23 AM   #27
JackSmiley
JackSmiley's Avatar
Is it safe to run pump 93 on 10.5 psi? Coz i've seen people with the other kits run e85 above 9psi to prevent det. Also, what mods have been done with the 10.5psi power output?
Old 05-11-2013, 10:44 AM   #28
Visconti
Drives: 05 STi
Hey guys
Our mustang Dyno reads low compared to a dynojet.
We were at 8psi on the Dyno , the wave in the dynosheet disgusts me but its from the boost controller that's now been removed
This car makes over 300whp all day long and I think that's about the limit on pumpgas.
Boost is now controlled via the Ecu and based on there logs it looks very good.
I think this kit needs a stronger wastegate spring but that's just me !
John
Visconti is offline   Reply With Quote
Worlds Fastest Turbo BRZ gets faster! Accelerated Performance Built - Visconti Tuned Visconti Forced Induction 697 11-13-2013 06:18 PM
Congiiee's Vortech Supercharger INSTALLED!!! Visconti Tuned congiiee Forced Induction 131 05-30-2013 12:28 AM
Visconti Tuned 0-60 brichard0625 Engine, Exhaust, Transmission 96 09-16-2012 09:56 PM
Worlds fastest BRZ - Accelerated Performance Built - Visconti Tuned !!! Visconti Forced Induction 135 09-06-2012 05:43 PM
Another Accelerated Performance Turbo BRZ - Visconti Tuned ! Visconti Forced Induction 34 08-28-2012 12:47 AM
