Old 05-08-2013, 01:36 PM   #57
Dezoris
Dezoris's Avatar
Originally Posted by feldy View Post
Been hearing a weird clunk when I back out of my drive way in the morning. its the only place I can get it to happen. And only in the first drive of the morning. Never again for the rest of the day. Feels like something is not tight but I can't get it to happen any other time. Its driving me nuts. Going to put the go pro down low and see if I can record the sound.
Two things:
  • Did you hold the piston rod with allen wrench solid while you torqued the center nut?
  • Did you re-torque all your control arms and end link bolts to factory specs?
I have a clunk from the rear on stock suspension over strange dips as well when the car is "cold" sounds like a clunk, but wondering if it is the rear deck or sway bar. Cant ever tell, but I retorqued everything, every bolt and I still get it. So I am done trying to figure it out.
Old 05-08-2013, 01:40 PM   #58
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Any issues with the stock shocks with springs? the 3g wrx's always tended to blow shocks after putting in new springs....how much drop are the yellows w/ stock shocks?
Thanks.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 05-08-2013, 02:10 PM   #59
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Thanks.
The yellows have a 20mm drop. The springs are said to work pretty well with the stock shocks. And since the drop isn't too low there shouldn't be a huge compromise in the life of the shock. But in reality only time will tell how long it will take.
Grimlock is offline   Reply With Quote
Old 05-09-2013, 11:43 AM   #60
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
So I put the Go-pro down low so we could hear the sound. You can hear it clear as day.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 05-09-2013, 11:52 AM   #61
leon78
leon78's Avatar
Drives: 13 Whiteout
Not sure if that sound is coming from the suspension....your hardly moving...but then again I cannot see what your rolling off/over w/ your rear wheels. Have you done any mods to drive train/rear diff mounts/bushings...things of that sort?
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 05-09-2013, 11:54 AM   #62
feldy
feldy's Avatar
Nope not yet.
Old 05-10-2013, 10:44 AM   #63
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
Nope not yet.
If you're stationary, and turn the wheel full lock to the right then to the left, do you hear any noises?
enjoyminutemaid is offline   Reply With Quote
Old 05-10-2013, 11:12 AM   #64
feldy
feldy's Avatar
I heard that pop once this morning. Doing it only on the drivers side. And only once. After the first pop its smooth as butter. Had the wife get in the car so I could look under the hood close. Wondering if we should try the conical washer from the gd imprezza.
Old 05-10-2013, 12:14 PM   #65
enjoyminutemaid
I sprayed WD-40 through the tops of the bearings and the squeak/creak immediately went away, however, i'm still getting quite a bit of popping when turning the wheel from lock to lock.
Old 05-10-2013, 12:17 PM   #66
leon78
leon78's Avatar
Drives: 13 Whiteout
If your Koni’s didn’t come w/ the conical washer then this is likely your issue or something you should address now as it might be down the rd. They will send you a set for free if you purchased before they were included.
Old 05-10-2013, 12:20 PM   #67
OrbitalEllipses
Drives: Attitude
??? The washer is welded to the OEM upper spring perch. What you talkin' bout? I'd have seen conical washers if they were included...but then again everything about my Koni install has been FUBAR.
Old 05-10-2013, 12:31 PM   #68
leon78
leon78's Avatar
Drives: 13 Whiteout
Sry...this is what I was talking about
http://www.ft86club.com/forums/showp...6&postcount=32
Old 05-10-2013, 01:07 PM   #69
enjoyminutemaid
My Koni's came with the washers and they're still making the clunk/pop...
Old 05-10-2013, 01:07 PM   #70
OrbitalEllipses
Drives: Attitude
OH the f*@#ing shaft collars? One of mine went on beautifully, the other needed to be filed down on the inside because it had some machining burrs that were getting caught on the threads of the piston.
Suspension Review: Race Comp Yellow Springs mechaghost Suspension | Chassis | Brakes -- Sponsored by 949 Racing 313 07-23-2017 03:05 PM
Racecomp Engineering Yellow Springs and Cusco Lower Control Arm Review F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-28-2013 12:22 AM
Springs & Shocks: Which to Buy? GhostofAkina Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 03-11-2013 01:16 PM
Tein Street Basis coilover, Koni struts and shocks JoeBoxer Brakes, Suspension, Chassis 6 12-25-2012 09:43 AM
