go_a_way1
Old 05-08-2013, 12:28 PM   #1289
jshadeck
jshadeck's Avatar
Originally Posted by aqua8701 View Post
225/40/18 on 18/7.5 +45 offset with 1.4" drop,(eibach sportline)...
Any issues or will this be perfect fit?
Name:  ImageUploadedByTapatalk 21368030500.773102.jpg
http://www.frsproject.com/tire_size.php
jshadeck is offline   Reply With Quote
Old 05-08-2013, 12:49 PM   #1290
nokia7190
Drives: Subaru BRZ limited WRB
Target setup:
Front - 18x8.5 +30 -> 225/40/18
Rear - 18x9.5 +35 -> 255/35/18
Questions:
1) Shall they fit stock height and alignment?
2) Shall they fit with 1" or 1.5" lowering, front camber bolt and rear camber bushing?
nokia7190 is offline   Reply With Quote
Old 05-09-2013, 01:34 AM   #1291
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Contemplating between different sizes of the same wheel:
18 x 8.5 +35 Square
18 x 8.5 +35 & 18x9.5 +35 Staggered
18x9.5 +35 Square
Objective is a set up that handles well, and can be driven hard safely.
Car will have FI, est 300whp.
Car will have Tarmac II coil overs, front crash bolts and rear camber bushings.
I'd like to run the 18x9.5 square with 245/35 rubber for the concave look, but am not sure if this will be too aggressive for functional front fitment..
What's the best set-up for me?
OjiGeorge is offline   Reply With Quote
Old 05-09-2013, 07:34 PM   #1292
xero404
Contemplating on 17x9.5 +38 all around and stretching a 225/45/17. Planning on just crash bolts to get the -1.0 to -1.5 camber in the front and Swift springs for the 1" drop on stock struts. Yes I'm a ricer.
pic of s2ks doing it:
starspecs
Track duty i'd do a 245/40/17 g force rival on the same spec rim 17x9.5 +38. Would that hit the stock strut at +38 or should i just go the proven 17x9 +35 route?
xero404 is offline   Reply With Quote
Old 05-09-2013, 07:48 PM   #1293
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
starspecs
Setup should be fine with the +38
Killerbee is offline   Reply With Quote
Old 05-09-2013, 08:29 PM   #1294
jshadeck
jshadeck's Avatar
Im not so sure about that camber w a 245 and a drop clearing the front spring. Just my .02
Old 05-10-2013, 11:47 AM   #1295
tedddee
Drives: 03 imprz rs, 13 brz
Have a set of 5x100 17x7.5 wheels. Trying to decide on tires for them. I really wanted to put 235/40's on, but the selection in that size is pretty terrible.
Thinking of settling on 225/45 Rivals, thoughts? These sizes are pretty conservative for stock ride height right? Don't want to be anywhere near rubbing anything.
Edit: Forgot offset, +53
tedddee is offline   Reply With Quote
Old 05-10-2013, 12:51 PM   #1296
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
^I would stick to 225/45 for a 7.5" wheel.
This wheel size is confirmed to fit, please refer to the stickied chart:
http://www.ft86club.com/forums/showthread.php?t=7535
Very conservative. The distance to the fender lip will be within 1mm of stock and on the inside it'll be 5-6mm closer to the spring.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-10-2013, 12:58 PM   #1297
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Very close to rubbing the strut/inside.
ill86 is offline   Reply With Quote
Old 05-10-2013, 12:59 PM   #1298
ill86
ill86's Avatar
Drives: iG FR-S
Old 05-10-2013, 01:00 PM   #1299
ill86
ill86's Avatar
Drives: iG FR-S
Make that $.04 :-)
Old 05-10-2013, 01:02 PM   #1300
ill86
ill86's Avatar
Drives: iG FR-S
18 x 8.5 +35 Square
18x9.5 +35 Square
Option b or c. Your choice.
I'd go full 9.5 square if you want to run aggressive camber.
If you want it easier , go staggered.
Old 05-10-2013, 01:04 PM   #1301
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by Touge86 View Post
So i'm looking at some 17x8 +37 advan RGII's. I'm wondering if this is the ideal rim size/width for handling? and what tire specs would be best for this setup?
245/40 will fit fine.
225/40 is a little smaller than stock.
Old 05-10-2013, 01:04 PM   #1302
xero404
guess i'll try to stretch the 225 rival then lol. wish there were more grippy tire choices in 235. or just bite the bullet and get coils already.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
