#29 | |
Drives: FR-S 6MT
The temp gauge is coolant temp.. Oil temps are slow to follow and don't always reflect coolant temps.. Coolant temps come up quickly while oil temps are slow to follow.. I like to hit 160 oil temps before driving it hard.. Just a way to tell if your fully ready to go. As you stated... Not necessary for a normal car... But who drives this car normal? |
| The Following User Says Thank You to Mikem53 For This Useful Post: | Splat (05-07-2013) |
#30 | |
Drives: FR-S 6MT
They don't heat up anything.. They just provide a rich mixture to keep the car from stalling when cold.. |
#31 |
Drives: '13 FR-S | '08 Evo [Sold]
Obviously a GT-R is a hard comparison because of the cost difference, but it's really easy to just transfer some of this data from the OBD port anyways. With the Bespoke or some kind of in-house navi, they could've easily programmed it to read this data.
#32 |
Drives: 2013 Raven FR-S
The analog speedometer is absolutely useless. I never look at it.
#33 |
Hail Magnet
#34 |
Drives: RAVEN
It is on the list of stupid little annoying items that keep this car from being great. Seriously, the fact that the design committee let this trough tells me that they were not fully up to the job of designing an enthusiast car.
The list of what is good about this car is plenty long, but does not really stray outside of the "Handling" category. |
#35 | |
Drives: 2013 Ultramarine FR-S
#36 |
Hail Magnet
Well, ok, so we have determined that the speedo is pointless (true) and that oil temp gauges may be about as useful as a coolant temp gauge.
Time to make this thread semi-constructive: What kind of gauge would you like to see in there? Fuel economy? A/F? G force (not a good idea, IMO), Multi-information cluster? Aka, something that could be changed, so you could see your tire pressure, compass heading, countdown to next service, other pertinent vehicle info, etc. Start brainstorming! |
#37 |
Actually if it was like every other car (no digital readout in the tach) I would be very annoyed by the speedo where it is. It would need to be in the center of the cluster for a DD (yes, I know tach is more important on a track car).
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#38 | |
Drives: '13 FRS - STX
/discussion. Real world; make the speedo useful for mortals confined to sub-80 mph speeds, I don't care if it scales funny, if I'm doing ~110+ I'm not going to care if it's actually 105 or 115, the big tach in the center is nice but not realistic for 90% of drivers out there, it'd take some rearranging and research but I wouldn't be opposed to an entirely new design. |
| The Following User Says Thank You to strat61caster For This Useful Post: | HunterGreene (05-07-2013) |
#39 |
Drives: FR-S 6MT
My modern vette gave you readout in degrees and psi.. It's easy to implement and display.. The manufactures put it in the more expensive cars.. So they can help justify the price tag.. I'm sure this info can be tapped into via the obd2 port with the right software..
#40 | |
So, basically, a *useful* temperature gauge would be better on these cars than the speedo that's currently there. |
#41 | |
#42 |
Drives: SSM LT MT BRZ
you people are silly,
If the speedo was front and center you would be (i guarantee it) in here whining about the Tachometer placement, and how improper it is. If your brain can't calibrate to the gauge on the dash...you have the problem, not the car, I for one can't stand digital gauges and feel there is tons more class and value in an analogue gauge, this probably stems from my earlier experience with digital clusters in nissan S13's but it is reinforced by decades of beautiful gauges in sports cars and the fact that a digital gauge always looks classless when at rest, the rest of the time it is a tool, and if you know how to use a tool it works, everytime. |
| The Following User Says Thank You to SkullWorks For This Useful Post: | OnionTou (05-15-2013) |
| Change dashboard/speedo lighting? | rhysmcinerney | DIY (Do-It-Yourself) Guides | 4 | 03-02-2013 11:35 PM |
| NY sucks | Hardrock4445 | Off-Topic Lounge [WARNING: NO POLITICS] | 35 | 01-18-2013 09:28 AM |
| Adjusting Speedo to new tires ? | rikdrt1 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 12-16-2012 11:31 AM |
| cruise control and speedo issue.. | tibsy92 | Issues | Warranty | Recalls / TSB | 1 | 10-10-2012 12:21 PM |
| Winter Sucks | OldSkoolToys | Off-Topic Lounge [WARNING: NO POLITICS] | 16 | 02-19-2010 12:02 PM |
