View Poll Results: Oil Temperatures seen WITH and W/O Oil Cooler
WITH Oil Cooler Spirited Street Driving < 195 F 12 8.28%
WITH Oil Cooler Spirited Street Driving 195-215 F 9 6.21%
WITH Oil Cooler Spirited Street Driving 215-230 F 11 7.59%
WITH Oil Cooler Spirited Street Driving 230-245 F 3 2.07%
WITH Oil Cooler Spirited Street Driving 245-260 F 0 0%
WITH Oil Cooler Spirited Street Driving 260+ F (Oil cooler not doing its job) 0 0%
With Oil Cooler Tracked 195-215 F 5 3.45%
With Oil Cooler Tracked 215-230 F 4 2.76%
With Oil Cooler Tracked 230-245 F 7 4.83%
With Oil Cooler Tracked 245-260 F 6 4.14%
With Oil Cooler Tracked 260-280 F 2 1.38%
With Oil Cooler Tracked 280 + F 0 0%
W/O Oil Cooler Spirited Street Driving < 195 F 5 3.45%
W/O Oil Cooler Spirited Street Driving 195-215 F 6 4.14%
W/O Oil Cooler Spirited Street Driving 215-230 F 30 20.69%
W/O Oil Cooler Spirited Street Driving 230-245 F 16 11.03%
W/O Oil Cooler Spirited Street Driving 245-260 F 11 7.59%
W/O Oil Cooler Spirited Street Driving 260-280 F 5 3.45%
W/O Oil Cooler Spirited Street Driving 280 + F 0 0%
W/O Oil Cooler Tracked 215-230 F 0 0%
W/O Oil Cooler Tracked 230-245 F 2 1.38%
W/O Oil Cooler Tracked 245-260 F 8 5.52%
W/O Oil Cooler Tracked 260-280 F 24 16.55%
W/O Oil Cooler Tracked 280-290 F 5 3.45%
W/O Oil Cooler Tracked 290 + F 4 2.76%
Multiple Choice Poll. Voters: 145. You may not vote on this poll
Old 03-27-2013, 07:16 PM   #113
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by robispec View Post
That's hot for a 60° ambient day!
This is why the fullblown kit was overheating the engine in that "Tuned" video showcasing Team VCMC's FR-S. You are nearly doubling the power of the engine (and placing a super hot turbo in the engine bay) and expecting the stock radiator to take care of it. hehe
Fullblown has a radiator solution. Robispec has a super duper radiator/oil cooler all-in-one solution.
The Following User Says Thank You to sw20kosh For This Useful Post:
ATL BRZ (03-28-2013)
Old 03-27-2013, 07:52 PM   #114
stockysnail
Just the tip
stockysnail's Avatar
I got my ScangaugeII and slapped it on today. I was running around 200-208ish driving around with giving it some gas and also just cruising on the freeway at 60mph. I have the Perrin oil cooler sitting on my table which I'll install soon so I'll be able to give a comparison in temps. Unfortunately no track temps but daily driver/spirited temps I'll compare. Oh and it was about 61-65ish degrees outside today.
Old 03-27-2013, 08:07 PM   #115
Pekingduck
Drives: 4 wheels
My temps stay relatively low, but it might be in part of koyo radiator. I see around 190-215
Pekingduck is offline   Reply With Quote
Old 03-28-2013, 04:47 PM   #116
stockysnail
Just the tip
After driving around today after installing the Perrin oil cooler I'm seeing temperature decreases of around 20 degrees. Obviously the more air flowing through it, for example when on the freeway, the lower the temperatures will be. I was at about 180 when on the freeway after driving around for a while, instead of the 205ish area before installing the oil cooler.
Old 04-01-2013, 05:17 AM   #117
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
On track yesterday with around 68F ambient temp I gave it heaps and oil was around 266F at peak on most sessions with a max peak of 271F in one of the sessions.
Speedtech project 86 car peaked out at 243F with oil cooler driving hard on track. They used to top out at 284F before oil cooler installed and 243F is the highest they have got to now they have an oil cooler installed.
nzer is offline   Reply With Quote
The Following 2 Users Say Thank You to nzer For This Useful Post:
Huehuecoyotl (04-01-2013), Sportsguy83 (04-01-2013)
Old 04-15-2013, 09:38 AM   #118
The Slow One
Track Junkie
Drives: Argento Scion FR-S
I just tracked my car this weekend, Saturday mid 70s ambient temps. I was peaking 245ish temps. Sunday the temperature outside got up to the high 80s(damn you Houston weather) and was seeing 265ish peak oil temps.
I believe I might have to install a oil cooler soon as I now plan to run my car in the summer.
The Slow One is offline   Reply With Quote
Old 04-15-2013, 04:19 PM   #119
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Which oil cooler or was it custom?
Old 04-15-2013, 05:30 PM   #120
nzer
nzer's Avatar
Custom - I can PM you a link bit likely with shipping to USA etc would be more expensive than the Perrin one you could source locally.
Old 05-05-2013, 08:23 PM   #121
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I did four 3rd gear pulls today and two 1 to 4th pulls and top oil temperature was 110 C (230 F).
Old 05-22-2013, 05:35 PM   #122
Dezoris
Dezoris's Avatar
That's exactly where I was at and climbing.
The Following User Says Thank You to Dezoris For This Useful Post:
Sportsguy83 (05-22-2013)
Old 05-22-2013, 07:05 PM   #123
robispec
Drives: Black frs project
The trick is to keep the temperatures from climbing
robispec is offline   Reply With Quote
Old 05-22-2013, 08:54 PM   #124
Sportsguy83
Drives: Limited BRZ
I want to see your V. 2, keep in mind us FI guys with IC in front, and Intake piping running in the engine bay close to the fans. I know both are big limitations in to how thick it can be made, but I hope something can be worked out so that it does fit nicely with FI kits.
Old 05-26-2013, 08:35 PM   #125
Sportsguy83
Drives: Limited BRZ
I did eight 3rd gear pulls and one last 1-4 pull yesterday at night, ambient temp at 86 F, oil temp got up to 245 F Water temp got up to 210 F.
Old 05-27-2013, 10:45 PM   #126
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I have the Perrin Oil cooler, in normal driving around mid 60s I am averaging 165 degree. I will update more info as soon as I get on a track
LeeMaster is offline   Reply With Quote
oil cooler
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Best oil cooler whitefrs Engine, Exhaust, Transmission 4 02-21-2013 11:36 PM
Oil Cooler Location? Captain Snooze Engine, Exhaust, Transmission 5 11-26-2012 05:02 PM
