Old 05-02-2013, 08:31 AM   #1
BLKFRS
Maverick.
Drives: Scion FR-S
Best thing to do for a little hp gain
Hello, i just got myself a FR-S 2013 and if i would want to have a little more fun, what increases power if i would put 3-4K in the car..
BLKFRS is offline   Reply With Quote
Old 05-02-2013, 08:46 AM   #2
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Great question. Someone should make a forum dedicated to getting more HP out of these cars.
The Following 3 Users Say Thank You to SloS14 For This Useful Post:
Chimpo (05-02-2013), Ingen (05-02-2013), Turdinator (05-04-2013)
Old 05-02-2013, 08:47 AM   #3
xjohnx
Grip>Slip
xjohnx's Avatar
Welcome to the boards. That depends on what you want to do, but for that budget you could easily do a nice NA build (Intake/header/exhaust/reflashed ECU), or you could go with forced induction and look at a turbo kit or supercharger, but those will be close to or slightly above the top end of what you want to spend.
Old 05-02-2013, 08:48 AM   #4
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
What do you want to do with the car? $3~4k could get you a lot parts. Minor improvements can be had for waaay less, but again that depends on your goals.
EX: Drop in filter, inlet tube, and crank pulley will set you back < $300 and give you a noticeable increase in pep.
Do a search as people have asked around this topic several times before.
Also: don't forget to invest in some good oils for the engine / trans / rear.
Chimpo is offline   Reply With Quote
Old 05-02-2013, 08:51 AM   #5
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
EcuTek tune - ~$1000.00 (e85)
EL Header - ~$800.00
Overpipe - ~ $300.00
Front Pipe - ~ $300.00
Cat-back - ~ $800.00
CAI - ~ $350.00
Total - ~$3500.00
This setup has been proven to get an FRS just over 200whp. You don't have the budget for a proper turbo or supercharger setup. Nitrous maybe but that comes with other, more long-term, residual costs.
There is a TON of information in this section alone on these various mods and their respective manufactures with dyno results and everything. All you need to do is,
Scott
naikaidriver is offline   Reply With Quote
The Following 2 Users Say Thank You to naikaidriver For This Useful Post:
dokterdewe (05-02-2013), spgrizz22 (05-02-2013)
Old 05-02-2013, 09:06 AM   #6
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Where do you want the additional power? Increasing power mostly in the 3000-4000 rpm torque dip area is a different approach to increasing maximum horsepower. Looking for power everywhere is another approach all together. There are other considerations with respect to noise and driveability.
Gary in NJ is offline   Reply With Quote
Old 05-02-2013, 09:24 AM   #7
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Innovate is working on a supercharger that's all bolt on with no intercooler for a little over 3k. Should be out soon the last I heard they have stated production already. It will put out just a little over 200whp
Sent from my SGH-T989 using Tapatalk 2
Old 05-02-2013, 09:31 AM   #8
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
In order of my preference of cost and power gains:
Drop in Filter ~$40 (makes a hair less power compared to a full intake)
Pulley <$100
UEL Headers $600-1000 (for torque dip in conjunction with tune)
Tune $1k
Overpipe/Frontpipe with HFC~600
Resonated Catback ~600-800
Don't underestimate tires even thou it wont give power. The car was made to handle, which translates to fun as well.
EDIT: ideally you'd want to do the full exhaust with tune, but if funds are limited I'd get headers and tune together.
hyper4mance is offline   Reply With Quote
Old 05-02-2013, 11:32 AM   #9
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Lol, yep pretty soon.
(Note "pretty soon" is a relative term, and in this case it's relative to how long the earth has been inhabited.)
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
The Following User Says Thank You to Adeets For This Useful Post:
Pete (05-03-2013)
Old 05-02-2013, 11:41 AM   #10
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
i hardly ever see anyone mention a lighter driveshaft. same effect as the light weight pulley. any problems with this? i had one in my old car (3000gt VR4) and there was a much noticeable difference.
phanguy is offline   Reply With Quote
Old 05-02-2013, 11:45 AM   #11
leon78
leon78's Avatar
Drives: 13 Whiteout
3-4K in Hookers and blow in your car will be a little more fun.
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
The Following 6 Users Say Thank You to leon78 For This Useful Post:
6-Shift (05-02-2013), BMA (05-03-2013), Mike86 (05-03-2013), ProjectD (05-04-2013), Sonolin (05-02-2013), TweakLawl (05-02-2013)
Old 05-02-2013, 12:00 PM   #12
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
for 3-4k, I/H/E + tune
shu5892001 is offline   Reply With Quote
Old 05-02-2013, 12:07 PM   #13
Accurate Race Shop
Drives: Scion FR-S
The only issue is an aftermarket pulley that was milled just slightly unbalanced or the hole is off center can destroy the engine. If the factory pulley does this the warranty will cover it. Besides that very slight risk of getting a bad one they do help make the car feel better and climb to the top of the rpm range a little faster.
Old 05-02-2013, 12:13 PM   #14
Accurate Race Shop
Drives: Scion FR-S
I have wanted one ever sense I went to the shoot out and got to see one in person. But they have been having issues. I guess it's better for them to find all the problems than have the customers start kicking down their door over a blown up engine. The wait has been a lot longer than I anticipated it would be.
FA20 bolt-on horsepower gain potential CSI:86 Engine, Exhaust, Transmission 42 04-26-2013 11:14 AM
What is this thing? ducks Issues | Warranty | Recalls / TSB 7 01-10-2013 05:54 AM
Good gain + Low decibel? frosty86 Engine, Exhaust, Transmission 1 10-09-2012 06:32 AM
We supercharged the M3... 162rwhp gain! vividracingcom Miscellaneous 14 06-20-2012 07:54 PM
First thing you are going to do when you get your BRZ? Norcalmav23 BRZ First-Gen (2012+) — General Topics 74 04-02-2012 11:05 PM
