Old 05-01-2013, 11:41 PM   #29
JDM_Badge
JDM_Badge's Avatar
Drives: '13 FR-S Ultramarine
Originally Posted by xjohnx View Post
Was your issue constant? Or did if go away after a restart?
Constant. The problem is not going to resolve itself as the wire is all chewed up.
JDM_Badge is offline   Reply With Quote
Old 03-25-2014, 01:11 AM   #30
mnsayer
mnsayer's Avatar
Drives: LexusGS,Lotus Exige S240,LexusLX570
It seems im having the same problem, when I start the car there are no problems the second I touch the brakes both the ABS and traction light come on. Im trying to figure out the issue it seems electrical as this only happens when i put my foot on the brake.
mnsayer is offline   Reply With Quote
Old 03-31-2014, 01:57 AM   #31
tala_alyaseen
Drives: Toyota GT- 86
I'm pretty sure it's a loose cable this link might be helpful: http://www.ft86club.com/forums/showthread.php?t=24246
If that doesn't work out try unplugging the battery's cable for a few minutes then hook it back. Start the car without moving for another minute at least. Let's see if that works
tala_alyaseen is offline   Reply With Quote
Old 03-31-2014, 04:24 AM   #32
mnsayer
mnsayer's Avatar
Thanks already got it solved. It was the reverse light wiring.
Old 10-26-2015, 09:28 PM   #33
mtblackfrs
mtblackfrs's Avatar
Drives: 2014 black Scion FR-S
Hello, I just want to ask what is the main cause of this issue and the fix. The first time I went to the Toyota dealership, they fixed it and they said it was a fuse that popped. The 2nd time it came on they said it was the wiring from the 4th brakelight I added and had to pay $55 for the diagnose it. Still did not fix the issue. Anything I should look into?
mtblackfrs is offline   Reply With Quote
Old 10-27-2015, 04:33 AM   #34
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I gave up on mine ... since i put stickier tires on the car i found the traction and VSC to bug out Every turn i took .. so i just hold down the traction off until both lights turn on .. now i don't have to worry about the stupid thing
now i just keep my speeds in control .. my only concern is when its wet (which i leave on)
Vsc sport mode and trac off RWD-boxer Engine, Exhaust, Transmission 94 02-25-2020 09:23 PM
FT86 VSC and TRAC Overview Deslock BRZ First-Gen (2012+) — General Topics 16 01-11-2013 05:04 PM
TRAC/VSC Settings for AutoX? mkiisupra Tracking / Autocross / HPDE / Drifting 6 12-07-2012 07:11 PM
Question about VSC and Trac? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 1 04-23-2012 11:24 PM
Coverage of Subaru BRZ Debut at Re-Mix Night at Tokyo Night Club and Music Video mockngbrd BRZ First-Gen (2012+) — General Topics 36 01-04-2012 06:15 PM
