Old 01-25-2013, 10:07 AM   #15
steve87j
steve87j's Avatar
Drives: Scion FR-S RAVEN
Just had the same problem guys, after turning my car off it went away. I'm hoping its just temporary. I love this car and when it pulls this shit i feel as if my gf cheated on me.
steve87j is offline   Reply With Quote
Old 02-08-2013, 09:33 PM   #16
JDM_Badge
JDM_Badge's Avatar
Drives: '13 FR-S Ultramarine
Just happened to me. Just reporting in. If anything comes of it, I will follow up.
JDM_Badge is offline   Reply With Quote
Old 02-11-2013, 12:50 PM   #17
JDM_Badge
JDM_Badge's Avatar
Well, it looks like a wheel speed sensor had a wire chewed up on it. The dealer wants $350 for a new sensor as the wire is part of it. They claim soldering a new piece of wire in is not a good fix. Apparently there are 3 sensors in the country at the moment...
Old 02-11-2013, 01:04 PM   #18
xjohnx
Grip>Slip
xjohnx's Avatar
Was your issue constant? Or did if go away after a restart?
Old 02-16-2013, 06:58 PM   #19
Redzilla
Redzilla's Avatar
Drives: FIRESTORM RED AT
It happened to me today driving to work, i called my toyota to have it looked at this week hopefully is nothing too bad.
Redzilla is offline   Reply With Quote
Old 02-16-2013, 07:40 PM   #20
Ryan1JZ
Drives: AE93, JZZ30, ZN6
why would you be paying the $350?? can the dealer relate the issue back to something you've done to the car??
Ryan1JZ is offline   Reply With Quote
Old 03-18-2013, 05:24 AM   #21
Firefly
Drives: KE25
Just happened to me too, happened the morning after a day on the track. It turns on at random times, there's no pattern to what seems to be triggering it. Restarting the vehicle resets the lights but they eventually come back on.
I'll check the sensors and then take it into Toyota.
Firefly is offline   Reply With Quote
Old 03-18-2013, 07:31 AM   #22
SloS13
Drives: 2013 FR-S whiteout
I had the same issues on my IS350. It was the brake pedal switch. Luckily I figured it out myself and didn't have to take it to the dealer.
SloS13 is offline   Reply With Quote
Old 03-18-2013, 08:30 AM   #23
White64Goat
Which wheel?
Old 03-18-2013, 10:15 AM   #24
tbwoodlee
I Void Warranties
tbwoodlee's Avatar
Drives: Asphalt 86
Just wanted to follow up and repot that this has not happened to me again since that cold, snowy night a few months ago.
tbwoodlee is offline   Reply With Quote
Old 04-08-2013, 01:20 AM   #25
Eh-Tee
Drives: 2013 FRS - Asphalt
I experienced this same issue; however, in my case it was due to the yaw sensor in the steering wheel.
Eh-Tee is offline   Reply With Quote
Old 04-16-2013, 12:11 PM   #26
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
Mine came on this morning after i put in a new steering wheel stalk from at GT86 last night. I think that i didn't put the steering wheel back on completely straight(i actually know i didn't). Hopefully thats the cause and i'll try and fix it tonight after work, i'll post back.
Trashed675 is offline   Reply With Quote
Old 04-17-2013, 01:15 PM   #27
Trashed675
Trashed675's Avatar
Got the steering wheel back on straight, but still my lights are on(even after pulling the negative terminal for an hour). I guess i'll be putting the OEM light/signal stalk back on and seeing if that fixes it, if not, its back to the dealership.
Old 05-01-2013, 11:40 PM   #28
JDM_Badge
JDM_Badge's Avatar
Well, it has teeth marks in it. The dealer does not cover animal related damage, and frankly I do not blame them. I looked at it myself and would concur that an animal probably chewed through it. I should have mentioned that the $350 was parts and labor. The part alone was $145. I left it not working for quite a while as the car is fun with the nannies off, but I have decided I want my cruise control back.
Vsc sport mode and trac off RWD-boxer Engine, Exhaust, Transmission 94 02-25-2020 09:23 PM
FT86 VSC and TRAC Overview Deslock BRZ First-Gen (2012+) — General Topics 16 01-11-2013 05:04 PM
TRAC/VSC Settings for AutoX? mkiisupra Tracking / Autocross / HPDE / Drifting 6 12-07-2012 07:11 PM
Question about VSC and Trac? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 1 04-23-2012 11:24 PM
Coverage of Subaru BRZ Debut at Re-Mix Night at Tokyo Night Club and Music Video mockngbrd BRZ First-Gen (2012+) — General Topics 36 01-04-2012 06:15 PM
