#29 |
Drives: Raven Manual FRS
Yes it does. You have to make sure that the fan is ON when you change the temperature to the cold side. then turn the fan back off. You can't just move the temp control while the fan is off. It doesn't do anything.
#30 |
Drives: 2013 Firestorm Scion FRS
I think if this doesnt work for your cars something is definitely wrong with the HVAC
#31 |
Drives: '13 FR-S (Whiteout) Manual
I turned the notch to blue max a/c, pressed the re-circulation button (on) after setting it to the coldest possible, turned the A/C on and then back off. Still, warm air creeped through the vents to bug me. I even turned the slider notch on the AC vents so they don't blow any air at all. Then hot air started seeping into the leg room through the cracks and spacing of the interior panels (Passenger side too)
None of my cars ever did this before...EVER... and i drove a camry and a subaru wrx in that order. So quit telling me it's "normal" when it's not. Oh and on top of that, A/C is starting to smell like shit. |
#32 | |
"Slyde"
Drives: 2013 SWP BRZ
I love how people think they can start things with "no disrespect but.." and then say something insulting. Like that makes it ok? Anyway, yep, I sure have driven cars before. And no, not every car is like this as neither my Chevy or Ford worked this way. You would get cool air from the outside if it was cool outside - not warm air. Thanks for asking, though!!
#33 | |
OP, yes this is normal with some cars, i would bet its the same cars that suffer from one form of heat soak or another. (As my supras, is300, and now this car seem to suffer a bit) possibly in part due to the undercover beneath the engine? If u have ur knob set to cool, and turn the fan one click it should go away w out causing any real noise etc. or close ur vents
#34 |
Drives: 2013 Scion FR-S (Asphalt)
I had this problem with my Rabbit, too. With the fan off and the temperature knob set to cool, it would be warm. With the knob set to hot, it would be hot. It hasn't been cold enough here to use the heat yet, so i can't say much about the FR-S in this regard.
#35 |
Drives: FR-S MT
Anyone come up with a solution for the warmed air problem? Air coming through my vents with temp set all the way counterclockwise is warmer than the outside air. I do not like using the recirculation button since the air gets stuffy and humid. I do keep the fan on all the time though.
#36 | ||
Drives: Raven Black FR-S
basically the vents stay open and whatever air temperature is outside will come into the car, (after it's been slightly warmed up by the engine bay heat of course). Every car is like this. the reason when the temp. dial is turned to heat is more dramatic is because now the heat from the engine bay is now blowing into your cabin... thus = free heater without wasting your gas turning on the heater. great feature for canyon runs too with your windows down at night... however if you do not want the air to flow from into your cabin via vents, then just press the recirculation button and DONE... no more air. and if it's too stuffy, roll down the window or just turn on the A/C :happy0180: |
#37 | |
Drives: FR-S MT
Your statement about saving gas is obviated by the fact that even when the temperature outside is 60 farenheit I must turn on my air conditioner to maintain a comfortable cabin temperature. These are times when I keep my windows closed due to traffic noise. |
#38 | |
but yes I agree with you as to it being cold and the interior air being warmed up... but what can you do eh? |
#39 | |
Drives: Scion frs, Manual, Hot lava
#40 | |
Drives: GTS 86 auto
Set to FRESH you got outside temp. Set to RECIRC you got cabin temp. The fan gave you more. I have filled gaps on the engine compartment side and am confident there's no air getting in from there but it made no useful difference. This is the only car we've had with a pollen filter so I wonder if it is something to do with that? |
#41 | |
Drives: Supercharged Golf Cart
I'm going to revisit this thread when it really gets cold outside. If the air is still warm at that point, I won't be happy. A/C off is a luxury to me, and I love the cold outside air. If it's cold outside and your temp setting is all the way on blue, you shouldn't have warm air, period. We shall see. I never use recirculate, ever. And I shouldn't have to start now. |
| The Following User Says Thank You to fistpoint For This Useful Post: | Evil Jesus (09-08-2013) |
#42 |
On my BRZ, my AC is capable of blowing icy cold, but it cycles on and off and never blows super icy cold (issue #1).
With the system off, my car blows warm air like other have stated. It blows harder when at speed, less when sitting. This tells me it has to do with something being open to the atmosphere, as high speeds equals more warm air blowing. I think part of my issue#1 has to do with the AC having to overcome the warm air that's always blowing into the car. Switching the fan on, temp to LO, and pushing the recirculating button, and then switching the system off doesn't change this. |
| Warm Up? | gt865 | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 09-17-2014 11:28 AM |
| Want to trade my BRZ fender vents for you FRS fender vents, or buy FRS vents outright | ill roller | Exterior Parts (Aero, Lighting, Etc.) | 6 | 09-22-2013 10:49 PM |
| Want to Trade: My Whiteout FRS Fender Vents for the SWP BRZ fender vents | DC-FRS | Exterior Parts (Aero, Lighting, Etc.) | 15 | 11-01-2012 11:41 PM |
| a thought about the warm air coming from the vents... | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 08-02-2012 10:06 AM |
| Warm vs cool Weather performance | EsoBOFH | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 07-10-2012 11:45 AM |
