Old 04-30-2013, 12:20 AM   #15
ShikoBariki
Drives: 89 240sx S13 SR20DET, 13 FR-S
Originally Posted by Enraged21 View Post
That performance set up is pretty much the exact way I'm going. I decided to go with performance first because suspension is already tight on this car. I DD my car as well.
A lot of people say you should do a tune first, but I was gonna wait as well til I get most of the mods in place.
My mod list includes the:
Perrin inlet hose + CAI
Perrin overpipe
Don't know who I'm going with the UEL yet
Ark test pipe + Ark GRiP exhaust
and then the tune as well.
In a couple years is when I'll decide to upgrade the suspension components but in the meanwhile I'm getting the eibach sportline to get rid of that wheel gap.
For sure I'd look into the DTS and compare the grip. Personally I think the DTS is better. Read up on it. I'm guna stick it out with performance first then suspension.
ShikoBariki is offline   Reply With Quote
Old 04-30-2013, 02:53 AM   #16
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I was going to say performance first, but then I had a change of heart tonight. You see, Suspension will cost more at one time, and if you have the money now, blow it. With bolt on power, you can add it part by part as you get the money, with the catback, tune, and header costing the most... but you can atleast split that up.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 05-01-2013, 02:50 PM   #17
ShikoBariki
I was thinking the same thing..since i already started with power id stick with it and continue til im done with the basic bolt ons then suspension. when i do suspension id want to have everything done right meaning im not going to short myself budget wise to get the suspension done quick and the rims+wheels set i want is 3k hehe
Old 05-01-2013, 02:52 PM   #18
ShikoBariki
Originally Posted by ngabdala View Post
You're going to need a ton of power man. You know how heavy rims and tires will be according to the sizes you want? Not only that, it is also rotational weight which really sucks. If you're just going for looks and nothing else matters then yeah that's cool. Also remember you're not going to be able to rotate your tires if you only have 2 of the same size on the rear axle. You're not going to swap them with the narrower tires on the front.
Yeah i know im just going for looks for now then when warranty expires, get me a supercharger by then it should be cheaper. For now all stance and maybe a lil power add ons due to bolt ons and tune. what do you mean i wouldnt be able to rotate tires if i have 2 of the same size?
Old 05-01-2013, 03:05 PM   #19
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Because normally when you rotate tires, you move front to back or diagonally rear-left to front right and rear-right to front-left. When you have a different size tire on the back vs the front, you can't do that anymore.
Scott
naikaidriver is offline   Reply With Quote
The Following User Says Thank You to naikaidriver For This Useful Post:
ShikoBariki (05-01-2013)
Old 05-01-2013, 03:33 PM   #20
ShikoBariki
Scott
Thats right i forgot about that..i was thinking of going with an aggressive set up to stance me up just right. 19x9.5 and 19x10.5 then 225/35 and 245/35 what do you recommend? I want to go for the flush look and for sure roll my fenders.
Old 05-01-2013, 04:16 PM   #21
ramiram1984
Drives: 2016 STi DGM
Perrin overpipe
I debated between Rev Works or JDL. I ended up going with the RW. Love the quality and Matt is very helpful. They're made to order. $733 out the door. Installing in a few weeks.
ramiram1984 is offline   Reply With Quote
Borla Header with test pipe and ISIS exhaust post_break Engine, Exhaust, Transmission 12 05-24-2015 10:43 PM
Anyone here with the ARK Grip exhaust and the ARK test pipe ? Vten Engine, Exhaust, Transmission 2 03-24-2013 02:20 PM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 07:24 PM
FR-S/BRZ Agency Power CatBack Exhaust and test pipe 10k Redline Engine, Exhaust, Bolt-Ons 18 10-23-2012 03:11 AM
