Old 04-24-2013, 05:23 PM   #15
tracerit
Drives: '13 SSM BRZ Limited 6MT
I tried 128 and 320bit rate mp3s and honestly can't tell the difference much if at all. Since I plan on keeping the car for a while, I'll gradually improve upon it.ilk take everyone's advice and go with sound deadening the environment first.Time to check out that large sound deadening thread haha
tracerit is offline   Reply With Quote
Old 04-24-2013, 06:03 PM   #16
radroach
Drives: car
Originally Posted by tracerit View Post
I'm mainly looking for an easy replacement using stock wiring and head unit and amp.
I can give you a tip on how to improve audio quality on the BRZ head unit. Try this before you start stuffing insulation in your speakerbox. Nobody else says the shit that I'm about to tell you, instead throw money at the problem or mess with the mix, which will totally screw with the sound. But trust me I'm the motherf**n truth when it comes to audiophile shit so read:
The problem is that the source volume control (SVC) levels are too high on the factory settings; bluetooth and satelite radio are being gained too high on their input. This makes all the levels, especially treble, way too high. The stock settings are like a guitar with a Boost Pedal overdriving the amp, for easy comparison. I first noticed these dynamics when listening to Willie Nelson on satelite radio, his vocals were coming through distorted. This told me the input levels were too high.
CD, bluetooth, and radios all have their own SVC, source volume control, found in the audio settings on the stock BRZ head unit. You can adjust the SVC, starting at +/-0dB; I put bluetooth audio around -10dB for instance and cut the volume levels on the device (aka bluetooth device). The BRZ manual has more info about these settings.
My settings are: music player's (android phone) volume is 50-60%. With the SVC levels cut to -10dB, it rounds the levels perfectly. I can crank the BRZ audio unit all the way up without distorting, giving me good volume and good clean audio headroom.
note, I do not believe in changing the EQ settings. My music was already mixed professionally in a recording studio, why would you want to mess with that? Adjust your SVC and volume output, and you can find the sweet spot to flatten out the sound and power from your radio. Leave the EQ to the recording industry professionals. No need to cut trebs or boost bass levels, they're already baked into the track.
The Following User Says Thank You to radroach For This Useful Post:
tracerit (04-24-2013)
Old 04-24-2013, 06:20 PM   #17
tracerit
will give that a try. i only listen to music around volume level 20-25 i think. i don't crave too much bass or loudness.
Old 04-24-2013, 06:29 PM   #18
radroach
Drives: car
This will change your radio dynamics. It will cut all input levels by -10db, therefore you can turn up your radio more and still have clean headroom.
I have my radio cranked 100% and you can only hear the music a few feet from outside the car, not too loud at all.
My equation: low input gain + radio cranked = good classic sound with flat levels across treble, mids, and bass.
Old 04-24-2013, 07:21 PM   #19
KSC
KSC's Avatar
Drives: Ion Redline
I was gonna make a similar thread.
I'd like the stereo to be a just a bit louder, but I don't really want to upgrade the whole system. I usually have the vol around 90% and its just not doing it for me. If I can hear myself sing, something's not right. I'm a terrible singer, too!
I've never been a "system" guy. Love music, but have always found stock to be sufficient. I just drove the wife's Altima today and 17/30 on her volume nearly shook my teeth loose.*I'm just surprised at how soft the stock setup on the BRZ is considering how small the cabin is.
Guess I'll adjust the EQ and see if that improves things.
"Bullshit, asshole! No one likes the tuna here!"
KSC is offline   Reply With Quote
Old 04-25-2013, 12:53 PM   #20
radroach
Drives: car
From what I just wrote in my reply above your comment, the stock stereo doesn't have clean headroom at high volumes, often distorts due to the level of input gain, which is controllable via source volume control.
I think if you want to go louder, you'll want cleaner headroom. the stock stereo system settings only goes about halfway up before the speakers start to distort, so you'll probably want speakers with a higher rating. However, pay attention to what I said about SVC and you'll be able to limit the amount of distortion you get at high power.
Old 04-25-2013, 01:44 PM   #21
Foobar
SLO NO MO
Foobar's Avatar
Good advice here, but as far as music already mixed professionally in a studio not needing any more equalization, would that not require a studio-quality soundstage as well? Surely the car's inherently less-than-perfect audio environment could benefit from some EQ tweaking.
Old 04-25-2013, 01:47 PM   #22
Xdragonxb0i
Drives: ex500r
in the bespoke version there is a setting for "natural" and "feel" select feel
Xdragonxb0i is offline   Reply With Quote
Old 04-25-2013, 03:35 PM   #23
radroach
Drives: car
IMO, the only thing wrong with the system's sound quality is the input gain levels from SVC. In a less than perfect setting with road noise, I suppose you might want to compensate by changing frequency response, but that changes the way your music sounds, and that's even further less than perfect.
Most of the music I listen to was made to be listened to in a car, so called "trunk bangers" where the bass is perfectly mixed and aren't distorted. Changing the EQ settings turns a crisp bass thump into a booming fart in this case, ruins the producer's vision for how these frequencies were supposed to sound.
Old 04-25-2013, 05:22 PM   #24
cruzinbill
Drives: Argento 6spd FR-S
You do realize that with the eq flat in the car the response is not actually flat..... I wouldnt really say it has a crisp bass thump from the factory anyway. Its more of a muddy mix of midbass while it tries to produce sub bass as well.
cruzinbill is offline   Reply With Quote
The Following User Says Thank You to cruzinbill For This Useful Post:
radroach (04-25-2013)
Old 04-25-2013, 05:32 PM   #25
radroach
Drives: car
I agree, what I mean is I'm normalizing the sound by reducing the gain (again via SVC) and upping the wattz, it gives a flatter, clearer response than simply running the radio stock at 50% volume. This keeps high amplitude stuff, bass, from jumping out too much and banging the speakerbox, also keeps trebs from jumping. My ears don't feel like they're going to bleed anymore.
( [ame="http://en.wikipedia.org/wiki/Audio_normalization"]Audio normalization - Wikipedia, the free encyclopedia[/ame] )
Old 04-25-2013, 05:48 PM   #26
xbreed
Drives: 2013 CBS BRZ Limited
Stock speakers are garbage. Replace them and you will get the sound you want.
xbreed is offline   Reply With Quote
Old 04-26-2013, 12:34 PM   #27
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
That is a very misleading statement, especially if you are leaving everything else "stock". Higher-end speakers are usually more power hungry, and underpowering a set of speakers will not give you the result you want.
Now, if you do install an amp to power these new speakers, you will have to deal with issues such as resonance and such, and at that point, sound deadening becomes more critical.
悪魔のハチロク
2013 Scion FR-S, Raven
Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound
Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite
brianlo622 is offline   Reply With Quote
Old 04-26-2013, 01:21 PM   #28
cruzinbill
Agreed, if it wasnt for having to deal with not having xovers on the oem speakers, I would say adding a small amp and deadning is all most would need to make the car sound good. Well and a small sub.
Tire Upgrades miodculae Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 84 07-27-2017 11:05 AM
GPS Map Upgrades? Enemies Electronics | Audio | NAV | Infotainment 0 04-20-2013 04:18 PM
Speaker upgrades Thongpocket Electronics | Audio | NAV | Infotainment 15 03-01-2013 06:33 PM
Spending my money on Perrin Catback or Tune jflogerzi Engine, Exhaust, Transmission 27 01-07-2013 10:32 PM
Sway Bar Upgrades NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 09-01-2012 06:43 PM
