Old 04-23-2013, 04:37 AM   #1
tracerit
Drives: '13 SSM BRZ Limited 6MT
Will spending only $200-250 on speaker upgrades be worth it?
I've had BMWs the last four years and just recently came from an 07 335i with "Logic 7" sound system. I'm not much of an audiophile at all. I mainly listen to the radio and 128kbps mp3s from my phone via AUX. When I started listening to my music in my BRZ though, it's entirely obvious the whole setup is below average. Even my dad's 2005 Accord sounds better! (IMO)
I read over some threads here and it seems a lot of people are going all out on their setups spending $1000 or more. The OEM Audio + seems to just add some new tweeters and a sub, so are the stock speakers not that bad? If I'm only looking to spend $200-250, is there anything in that range that will improve the sound quality?
I'm mainly looking for an easy replacement using stock wiring and head unit and amp.
tracerit is offline   Reply With Quote
Old 04-23-2013, 04:41 AM   #2
#87
I usually post drunk
#87's Avatar
Maybe your ears are off because I'm coming from a same generation accord as your dad and this is phenomenal in comparison.
#87 is offline   Reply With Quote
Old 04-23-2013, 06:48 AM   #3
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Are you sure you have it set up right? Mine sounded like shit (I almost didn't buy the car because of it) until I read the manual and took the time to set everything correctly. It's not the best stereo system I've ever had but it's really not bad for a factory base system, especially with MP3s. I also spent a little time with the MP3 equalizer making a few adjustments. All in all, I'm very happy now.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 04-23-2013, 08:15 AM   #4
schtebie
Drives: CBS BRZ Limited
Try adjusting the EQ settings if you haven't already. It makes a noticeable difference.
schtebie is offline   Reply With Quote
Old 04-23-2013, 09:29 AM   #5
n2oinferno
Praise Helix!
n2oinferno's Avatar
Here's my hypothesis.
Maybe the sound system in the FR-S is better at pointing out the shitty MP3 quality you're listening to. I'm not saying you have to run everything FLAC, but try 320kbps and see if it's any better.
The Following User Says Thank You to n2oinferno For This Useful Post:
CamryDS (04-23-2013)
Old 04-23-2013, 09:30 AM   #6
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I think the FRS/BRZ stock audio actually sounds pretty good. It lacks some low end, but overall the speakers are good for being stock. If you're going to add $250 in speakers I would go ahead and add a small sub in the trunk area.
Having said all that I did upgrade my entire system and am loving it. I've spent a total of about $1000: $150 JL Enclosed Sub, $200 RF 4-Ch Amp, $520 Pioneer X8500BHS head unit, $130 MB Quartz 6.5" Components, plus wires etc.
mit_peid is offline   Reply With Quote
The Following User Says Thank You to mit_peid For This Useful Post:
ngabdala (04-23-2013)
Old 04-23-2013, 09:58 AM   #7
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Definitely need to mess with the equalizer. I thought the stereo was bad at first, but now that I have the equalizer set, it's not so bad. Good use a dedicated sub woofer in the trunk rather than all the bass coming from the bottom front of the doors. Just my $0.02.
Eurasianman is offline   Reply With Quote
Old 04-23-2013, 10:17 AM   #8
simplicityinsound
simplicityinsound's Avatar
Drives: 2010 Subaru LGT
i think this thread is going to be way too subjective to be meaningful.
i have heard prolly 1000 stock systems in my time, and also aftermarket types from good to unbelievable.
i would put the FR-S system somewhere in the middle on the stock system chain, maybe a 6 out of 10 if 1 is worst and 10 is best. but again, all that is meaningless really, the key is how much does the OP appreciate good sound and what type of listener he is and what are his experiences in other kinds of car audio systems.
i do think in many ways, the FR-S system is better than the L7 system he came from
simplicityinsound is offline   Reply With Quote
Old 04-24-2013, 12:18 AM   #9
tracerit
it's not just the mp3s, the radio is pretty sub par. perhaps it's how loud the entire car is but i do have somewhat of a very low grade headache after getting out of the car after listening to music.
i currently have the EQ setup to the recommended settings from this thread too: http://www.ft86club.com/forums/showthread.php?t=15696
trying to find some higher bitrate mp3s to test.
Old 04-24-2013, 10:48 AM   #10
cruzinbill
Drives: Argento 6spd FR-S
I don't think speakers alone would be worth doing in this car. The head just really doesnt have the power to drive them cleanly.
I would say pick up Alpine KTP-445U Power Pack(its pretty simple to install vs a larger amp and has enough power for most components).
Then Rockford Fosgate POWER T165-S(they have a great tweet plus you can biamp it off the powerpack).
It would cost you 290$ and would sound quite good.
cruzinbill is offline   Reply With Quote
The Following User Says Thank You to cruzinbill For This Useful Post:
JoeBoxer (04-24-2013)
Old 04-24-2013, 11:30 AM   #11
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
I really like my BRZ stock setup. I'd only change if I could find dedicated subs for the doors, or the HU for better EQ settings.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 04-24-2013, 12:00 PM   #12
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
Agreeing with cruzingbill once again. Even though I have a really good SQ system now (thanks for Bing, Joey, and SimplicityinSound! ) When I was waiting for my install to happen, I upgrade my headunit first, and immediately with the more powerful output from the aftermarket unit driving the OEM speakers, the car sounded immediately better. The factory speakers are not that bad at all if you are on a budget, but you need to up the power thats going to them. You could get an inexpensive headunit and maybe have some leftover money to do some sound deadening (DIY though haha), or just go with a higher end aftermarket headunit and upgrade to more components later when you are ready.
悪魔のハチロク
2013 Scion FR-S, Raven
Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound
Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite
brianlo622 is offline   Reply With Quote
The Following 2 Users Say Thank You to brianlo622 For This Useful Post:
cruzinbill (04-24-2013), tracerit (04-24-2013)
Old 04-24-2013, 12:23 PM   #13
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Why not improve your car's environment accoustically? Will do a bigger improvement than speakers alone will tbh, and if then you feel you need to upgrade, you'll get the most improvement with resonances reduced.
JDKane527 is offline   Reply With Quote
The Following User Says Thank You to JDKane527 For This Useful Post:
Old 04-24-2013, 12:58 PM   #14
cruzinbill
Deadening should always be the first thing done, this car car has terrible resonance problems. Most people tho, dont seem to want to invest the time or money to do it.
Tire Upgrades miodculae Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 84 07-27-2017 11:05 AM
GPS Map Upgrades? Enemies Electronics | Audio | NAV | Infotainment 0 04-20-2013 04:18 PM
Speaker upgrades Thongpocket Electronics | Audio | NAV | Infotainment 15 03-01-2013 06:33 PM
Spending my money on Perrin Catback or Tune jflogerzi Engine, Exhaust, Transmission 27 01-07-2013 10:32 PM
Sway Bar Upgrades NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 09-01-2012 06:43 PM
