Old 04-23-2013, 05:45 PM   #1
cregor
cregor's Avatar
Drives: Whiteout Scion FRS
Door wont stay open
So I have had my new FR-S for about one week now and I absolutely love it, but when I am getting in and out of the car the door keeps shutting on my leg...
I am used to pushing the door open and having it stick at one of the multiple "notches", but if I let go of the door while it still has any momentum, it hits the next notch "hump" and then starts to shut. It almost seems like they put too much grease on the notches and it just won't stick to any of them.
The only way I can get the door to not shut on me is to open the door to the position I want, stop its from moving and then release the door. I know I am knit picking here, but I was curious if anyone else has this problem.
cregor is offline   Reply With Quote
Old 04-23-2013, 05:48 PM   #2
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
This is your first coupe? Coupe has longer and heavier doors therefore its very easy to close, even on the slightest uphill
shu5892001 is offline   Reply With Quote
Old 04-23-2013, 05:50 PM   #3
cregor
cregor's Avatar
Yes this is my first coupe and I did notice that the door was heavier, but its still shutting on me even in the garage (which is completely flat), is that normal?
Old 04-23-2013, 05:54 PM   #4
shu5892001
Ontario's FT86
I don't know because I always hold my door with my hand and never let it wide open unguarded. Because you have the risk of heavy wind, which might blow your doors off, or dent other people's cars.
Old 04-23-2013, 05:54 PM   #5
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
If its that much of an issue take it to the dealer. It's possible the door could be misaligned but then you would have a problem closing the door. Without seeing the door and putting hands ont it its hard to see if there is an issue with it. Car doors arent meant to be pushed open and freely swung about like a gate on a fence.
The Following User Says Thank You to norsamerican For This Useful Post:
SkullWorks (04-23-2013)
Old 04-23-2013, 05:55 PM   #6
SkullWorks
Drives: SSM LT MT BRZ
I always swing it open til i feel it drop into one of the detents then let go...habit from parking in tight garages/trying to fit too many cars in small areas.
Old 04-23-2013, 05:57 PM   #7
FRiSson
Drives: FR-S MT
The FR-S has very weak detents.
FRiSson is offline   Reply With Quote
Old 04-23-2013, 06:04 PM   #8
cregor
cregor's Avatar
This is what I am doing, I open the door till I feel the detent, then let go, but the door seems to rock in the detent (hit the far side then comes back and shuts the door).
Old 04-23-2013, 06:05 PM   #9
cregor
cregor's Avatar
I think this is what I am experiencing, the detents just aren't as deep as the previous cars I have owned. I guess I will get use to it eventually.
Old 04-23-2013, 06:05 PM   #10
norsamerican
Drives: WRB BRZ
This is common and not a known issue.
Old 04-23-2013, 06:54 PM   #11
KSC
KSC's Avatar
Drives: Ion Redline
My Redline did this all the time. The door was incredibly light (Tuperware) and EVERYTIME I'd reach in to put groceries or something in the back, it would slam on my back. Drove me crazy.
"Bullshit, asshole! No one likes the tuna here!"
KSC is offline   Reply With Quote
Old 04-23-2013, 07:13 PM   #12
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
If you swing the door open it will hit the end of its travel and bounce/spring back. Try a lighter touch.
whaap is offline   Reply With Quote
Old 04-23-2013, 07:23 PM   #13
CTB727
Drives: 2013 Subaru BRZ
Personally, I don't think this is that big of a deal. But that's me.
CTB727 is offline   Reply With Quote
Old 04-23-2013, 07:28 PM   #14
fistpoint
Drives: Supercharged Golf Cart
Normal for this car. I was actually commenting on this myself last night after going from my RSX into the FR-S. Luckily I always catch the door before it smashes my leg.
fistpoint is offline   Reply With Quote
Door Open Switch Raz BRZ First-Gen (2012+) — General Topics 7 04-10-2022 06:07 PM
Windows no longer open/close when door opened NOHOME Issues | Warranty | Recalls / TSB 13 04-19-2014 12:13 AM
Passenger Door Courtesy Light Wont Turn Off zex Issues | Warranty | Recalls / TSB 12 10-04-2013 02:31 PM
Door Open Buzzer cmspooner Cosmetic Modification (Interior/Exterior/Lighting) 5 08-13-2012 11:20 AM
