Old 04-21-2013, 06:57 PM   #57
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
My solution implemented, similar to the above:
Old 04-23-2013, 12:44 PM   #58
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
Originally Posted by jaredf1 View Post
brianlo622 have you actually used this??? Ordered and it's definately not the correct connector.
Yes I have. I had my pioneer AVH-X5500BHS's usb port in the back hooked up to this cable, and it goes to the factory harness and that enabled the car's front USB port.
I actually ordered from sonic electronix and the part number/name is AX-TOYUSB.
http://www.sonicelectronix.com/item_...AX-TOYUSB.html
Brian
悪魔のハチロク
2013 Scion FR-S, Raven
Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound
Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite
brianlo622 is offline   Reply With Quote
Old 04-23-2013, 07:32 PM   #59
jaredf1
jaredf1's Avatar
Drives: 2014 Ford Focus ST
Brian
Yeah I feel dumb... I figured that out just shortly after I posted. Was sitting infront of the computer thinking I must be doing something wrong.
jaredf1 is offline   Reply With Quote
Old 04-23-2013, 07:37 PM   #60
jaredf1
jaredf1's Avatar
On another note does this still mean to get the Aux to work with RCAs I will need to tap the 5 wires that somehow convert to TRS(Tip/Ring/Sleve). Any ideas before I used the floppy method but now using the stock harness I don't have that option.
Old 06-09-2013, 10:21 PM   #61
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
[ame="http://www.amazon.ca/Startech-Com-24-Inch-Internal-Motherboard-USBINT5PIN24/dp/B00906HDZA/ref=sr_1_3?ie=UTF8&qid=1370827172&sr=8-3&keywords=motherboard+cable"]Startech.Com 24-Inch Internal 5-Pin Usb Idc Motherboard Header Female to Female Cable USBINT5PIN24: Amazon.ca: Electronics[/ame]
Wire this into a 4 pole aux cable and you should be all set to retain audio and video on the 3.5mm jack. you wont hack up the harness either as this should plug right in. I just ordered the Pioneer X5500BHS and plan on retaining the OE hookups. I'll let you know how it goes.
RandomHero is offline   Reply With Quote
Old 06-10-2013, 10:09 AM   #62
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
This is all you need if you don't care about the 3.5mm jack. I have it and it works perfectly.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 10-21-2013, 12:55 AM   #63
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Originally Posted by abutterman View Post
does this go straight into the back of the factory usb plug and leave enough space for the aux pins?
Does anyone have an answer to this question?
Also, it's been a while so..is there an adapter for maintaining the factory AUX port without the whole servo cable mess, and if so, I would much appreciate a part number or a link to purchase?
Prog is offline   Reply With Quote
Old 10-26-2013, 01:02 AM   #64
CandyFRS
Drives: 2013 FR-S Whiteout 5AD
@RandomHero I ordered this cable but have not tried adapting it yet. Have you had any luck? Does it work? Where did you get your 3.5mm jack?
CandyFRS is offline   Reply With Quote
Old 10-27-2013, 05:45 PM   #65
Homegrown
Drives: Scion FR-S
If anyone needs this cable, I ordered one and didn't end up using it. It's out of the packge, but unused. I'd sell mine for $12 shipped in the usa. Pm me if anyone wants it.
Homegrown is offline   Reply With Quote
Old 10-28-2013, 08:57 PM   #66
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
I didnt end up converting the 3.5mm jack only because I figured I would never end up using it with the Pioneer USB cord and bluetooth combo. Even my laptop has bluetooth so I abandoned that particular part of the conversion project.
However. If you pop the USB/3.5mm jack out of the car you will see the receptical for that plug. All thats left to do is cannibalize a cheap 3.5mm audio cable and voila.
Old 10-29-2013, 02:43 AM   #67
CandyFRS
OK. Thanks for the reply. I think I will try it anyway since I have the parts already.
Old 01-24-2014, 05:57 PM   #68
AKSnowman
Anyone know if it's the AX-TOYUSB or the AX-TOYUSB-2 that we need? gonna install the AVH-P4400bh. Thanks!
AKSnowman is offline   Reply With Quote
Old 03-31-2014, 12:53 AM   #69
kagemusha
driven daily
Drives: 2014 BRZ (SPW)
I used this and have both AUX and USB still usable. Not cutting of wires. Just pop out old device (stock USB/AUX input) and replace with this. Plug USB and 3.5 into aftermarket HU and you're golden. It really just pops in and out.
AX-USB-35EXT (http://www.sonicelectronix.com/item_...USB-35EXT.html)
Does your train of thought have a caboose?
kagemusha is offline   Reply With Quote
The Following 2 Users Say Thank You to kagemusha For This Useful Post:
AdamBomb518 (03-31-2014), calis5nest (05-28-2015)
Old 07-03-2014, 10:40 PM   #70
JPiratefish
So my approach was a little different in getting the factory USB working with my AVH-X5500BHS - the radio has a USB port on it, so it's just a matter of splicing a USB connector onto the factory harness.
I started by grabbing an old USB mouse - something we all have laying around - and I cut 2 feet of cord with the connector off. I then exposed about 4" of the USB cable, found the wires, and verified that each one made it to a pin on the connector. In this case there are actually 5 links here - shield, ground, power, data 1 & data 2.
Sitting in the car, I pulled the radio out, unplugged everything, and then found the connector. I plugged my cable into the factory socket in the car, and then used the VOM's conductivity tester to validate where the leads where.
They were on this connector:
Using the VOM, I was able to find all five wires on the USB cable in this connector - so I just cut it off. I know some folks are weary about cutting a factory connector, but this is really specialized and really useless - if/when I move on from the FR-S, believe me, the radio goes with the car.
On the old mouse wire, there was a shield, black, green, white and red. These connected pins 1-4 respectively (when facing the USB connector, holes & contacts up..).
In the car, once I peeled back the insulation on the wires, I found the shield, black and red wires easily enough - and the two data wires were bundled together separately. I kept those wires separate, verified conductivity from the red-wire on the mouse USB cable going to the red wire in the cut part of the car harness. Colors matched simply - red to red, black to black, shield to shield. Since I was on a roll, I matched up the data wires similarly - in my case, green (mouse) to brown(car) and white (mouse) to purple (car) respectively.
The end result:
I used some wire joiners to act as crimp-on connectors for the power, and I'd had enough of the sheild to wrap those together, and then I taped all that down, nice and neat, then did the data - making sure to keep the wires similarly long and well wrapped on each other - then I taped it all down.
At some point if I've got the time, I'll shorten the USB cable and solder the leads - however, it's working great and now I'm using the factory connector.
For those of you who fear messing with USB, please keep in mind something about USB - this is digital signal here - not analog - there's little interference that you'll run into with a setup like this as long as it's well insulated. The key when working with tiny wires, keep your wraps good and clean, tape things down, and make sure to use the heavy wires as anchors.
The final result here is now I can USB link with the stereo using the factory USB plug.
Cheers.
JPiratefish is offline   Reply With Quote
Auto Factory Aftermarket exhaust ESBjiujitsu Engine, Exhaust, Transmission 113 01-17-2014 06:45 PM
More Scions in Richmond Port. Marloon CANADA 203 06-07-2012 02:43 PM
More shots from the Port of Portland DarrenDriven FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 05-11-2012 02:04 PM
Look what I spotted at the port of LB today Trojan_SC Southern California 4 05-09-2012 03:40 PM
Southeast Cars are In Port! Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 3 04-27-2012 12:39 PM
