Old 04-23-2013, 09:19 AM   #15
Xdragonxb0i
Drives: ex500r
Go with a Tune first. You will always need a tune after you add headers or turbo =D
My set up include a Catted P&L headers, Nameless Front Pipe with cat and resonator, and a Accelerated performance muffler and midpipe.
Keep in mind that i never had any headers before and only compare to stock. But even with a catted header i feel like its really loud. My engine noise drown out my exhaust, which is slightly louder then stock. I say get the nameless Front pipe, i cant hear any sound coming from underneath or behind me. Its only engine noise.
My car is untuned at the moment and while it feels faster, acceleration does not feel as smooth as stock. I will be get a tune soon, i feel like i need it to restore its original smooth acceleration feel.
Xdragonxb0i is offline   Reply With Quote
Old 04-23-2013, 09:27 AM   #16
frslee
Just drive it
Drives: 13' FR-S
Originally Posted by allawd View Post
Since you are in MD, do you know if Jermaine at TurboXS is doing NA BRZ tuning? He tuned by WRX. I prefer to get a real dyno tune since there's several shops in my area that can do it.
I'm not sure, are you talking about the shop near Andrew Tech?
I know friend of mine got his car tuned there (09 wrx), but not sure about this engine though. I'm sure they'll do a custom tune.
frslee is offline   Reply With Quote
Old 04-23-2013, 09:41 AM   #17
8686
8686's Avatar
Drives: 86
Originally Posted by FT-86 SpeedFactory View Post
Borla UEL and Tune.
What is the expected increase in torque with this setup?
8686 is offline   Reply With Quote
Old 04-23-2013, 10:15 AM   #18
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
There has been more than one person that has achieved over 200rwhp with e85 tune + header + plus exhaust + drop in filter. Looking at peak torque only doesn't give the big picture.
You can gain only 15lbs ft. of torque peak but by eliminating the "dip" you're picking up much more where it counts.
Scott
naikaidriver is offline   Reply With Quote
Old 04-23-2013, 10:19 AM   #19
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by DJCarbine View Post
I've complained about borla quality because I got the dreaded warped flange syndrome, but honestly with the visconti tune and the Borla UEL, I cannot feel the torque dip any longer.
You and me both, I'm not leaking out of the sides, but I think I'm leaking cylinder to cylinder, I think the only thing that is effected by that though is the exhaust note.
Anyone with more information about what happens if you header is leaking between the cylinders but not out into your engine bay?
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 04-23-2013, 10:21 AM   #20
8686
8686's Avatar
Drives: 86
Scott
so Headers + Tune will do the trick and eliminate the "dip"? Or I will need a full exhaust?
Old 04-23-2013, 10:23 AM   #21
naikaidriver
Headers and e85 tune have been best methods for achieving this so far, yes.
I would strongly recommend you check out the P&L and Nameless Header sections for more, detailed info.
Scott
Old 04-23-2013, 10:44 AM   #22
CSI:86
86 = First New Car
Drives: 2013 Pegasus White Toyota 86 GTS MT
As Jeremy says: Headers + Tune.
Don't get a intake (particularly AFE takeda) thinking it will fix the torque dip. It makes the low end torque before the torque dip more, and increases the noticeability of the torque dip.
CSI:86 is offline   Reply With Quote
Old 04-23-2013, 11:15 AM   #23
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
NOS or the nitrous express kit
Old 04-23-2013, 11:37 AM   #24
Opposed
Drives: 2013 Asphalt FR-S
That's odd...my AFE with tune shortened the torque dip quite a bit. Or are you saying the intake alone?
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 04-23-2013, 11:50 AM   #25
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
Won't get rid of torque dip but will be much higher with a 4.67 final drive swap, 21lb more torque across the entire rev range.
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline   Reply With Quote
Old 04-23-2013, 11:58 AM   #26
CSI:86
86 = First New Car
Yes just the intake itself. My only mod is AFE takeda intake. Plan to put Perrin headerback, Borla UEL and Stage 2 FA20club tune. Hopefully this will get rid of the torque dip!
Old 04-23-2013, 01:16 PM   #27
projectXTR
Drives: Sterling Silver BRZ
Dude, this ain't The Fast and The Furious.
projectXTR is offline   Reply With Quote
Old 04-23-2013, 01:33 PM   #28
mad_sb
This makes sense, I just don't want the extra noise, so planning on keeping the stock cat-back even at the expense of weight/power.
I've had enough years of full exhaust on my WRX to know what it will sound like on a daily commute.
I understand and im in the same boat after years of catless 3" turbo backs on my evo viii, X, and ralliart If you go with an axle back and keep the stock midpipe it keeps the volume down... especially if you keep a high flow cat in the front pipe.
Check out some of the nameless axle-back threads
Cheapest way to get 5-Axis or TRD wing in Canada? SkAsphalt CANADA 13 03-21-2013 11:07 PM
any way to reduce or eliminate "idle creep"? Nepenthe Scion FR-S / Toyota 86 GT86 General Forum 8 07-03-2012 02:00 PM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 12:22 AM
