Old 04-22-2013, 05:08 PM   #309
WillRacer1jz
Drives: 1987 JZA70 Supra, 2013 FR-S
After data logging my first track day since I got the app, it looks like I need an oil cooler now.
WillRacer1jz is offline   Reply With Quote
Old 04-22-2013, 06:23 PM   #310
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Originally Posted by reeves View Post
I do notice.. when 'coasting' to a stop, if you put the car in NEUTRAL, the AFR remains around ~14. But if you keep the car in gear, the AFR goes up to 20+.. Does that mean you get BETTER MPG's if you keep the car in gear when approaching a stoplight, rather than putting it into neutral?
Yes, your car goes into fuel cut and uses its own momentum to keep the engine spinning basically.
Look at your fuel usage gauge next time. Let off (above ~1400 rpm) and it'll go right down to 0 L/100km, whereas if you shift to neutral, you're still burning fuel to keep the engine idling.
pheoxs is offline   Reply With Quote
Old 04-22-2013, 07:12 PM   #311
Lonewolf
Lonewolf's Avatar
Drives: Moped
276...yeesh
Old 04-22-2013, 07:50 PM   #312
DriftEm
DriftEm's Avatar
Yup, that's what my car was running too, my Perrin Oil Cooler is in it's way
DriftEm is offline   Reply With Quote
Old 04-22-2013, 09:06 PM   #313
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Damn! Good choice on getting the oil cooler!
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 04-23-2013, 02:50 AM   #314
Kodename47
Kodename47's Avatar
Drives: UK GT86
Exactly, it's one of the reasons why FI is advantageous over carbs as they would still use fuel on the over-run.
Ideally you'd only be in neutral when at a stop as yes, you can save yourself fuel by using the engine to slow you down. I know it's really the wrong kind of car, but if you wanted to get some great MPG out of the car, read the road ahead and try and use the engine braking as much as you can. All the time you're doing that, you're using no fuel.
If you want to prove it, I'm sure there's an injection time parameter you can monitor in Torque (I use ECUtek, and there is in that). Obviously it will go 0 in these circumstances.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-23-2013, 03:15 AM   #315
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
The Perrin one is a fine looking piece of kit.
nzer is offline   Reply With Quote
Old 04-24-2013, 11:21 AM   #316
swift996
swift996's Avatar
Is anyone familiar with a cheap 7" tablet with android? I like the app so much I was thinking of running a dedicated tablet showing the gauges on Torque.
I found these on ebay, I know they're cheap, just wondering if anyone has experience with something cheap:
http://www.ebay.com/itm/Trio-Stealth...item43bb1f6298
http://www.ebay.com/itm/NEW-Coby-Kyr...item257c80c97a
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 04-24-2013, 05:36 PM   #317
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
The first one doesn't indicate anything about bluetooth capabilities, therefore you would need a wifi-obd reader, which tend to be quite a bit more expensive compared to the bluetooth ones. It also mentions that it's wifi READY, I'm under the impression you may need something else to use wifi on it.
For the 2nd link you provided, it says wifi, but the description has no information and nothing mentioned about bluetooth.
Most of the wifi-obd readers go for 30$-50$
In my opinion, buy yourself a Google Nexus 7 16gb for around 200$ or find a used one on eBay if you like.
The Nexus 7 is a quality tablet, it runs fast and the torque app works flawlessly on mine, I couldn't be happier.
At 200$, that is still an extremely competitive price for a decent 7" tablet.
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 04-24-2013, 06:43 PM   #318
Kamran
Pepe Le Pew Wannabe
Kamran's Avatar
Read my post #228, this thread...
My middle age crisis started prematurely… at 16!
I'm also independently very, very..... dependent!
Kamran is offline   Reply With Quote
Old 04-25-2013, 01:20 PM   #319
Brody602
Drift King
Brody602's Avatar
Can anyone make something like this? Just a couple ideas, one is just a little tray with a lip coming from underneath the HVAC controls, the other is two brackets on each side, maybe with a rubber line to prevent movement? Out of plastic or fiberglass? I'd probably wrap it in carbon fiber anyways, and I don't want a permanent solution, so I'd probably stick the side brackets with 3M tape, or the tray under the HVAC controls might be able to just be tucked under?
Old 04-27-2013, 06:53 PM   #320
gonzo
Drives: frs
On the subject of accuracy close to running empty, I've noticed (on several fillups the past 3 months), that it's accurate ONLY if you're not driving hard. If I'm cruising on the hwy, it'll be very accurate down to 0.5 gallons.. below that, you're on your own.
I thought the PID setup for fuel remaining is "VERY accurate".
Does very accurate mean .5 gallons?
gonzo is offline   Reply With Quote
Old 05-05-2013, 06:20 PM   #321
vtmike
vtmike's Avatar
Drives: Scion FR-S
I noticed while logging a/f ratios the smallest value it will show is 12.1653614. Does anyone know if this is a limitation of the sensor or the included torque a/f measurement.
Sent from my Nexus 7 using Tapatalk HD
vtmike is offline   Reply With Quote
Old 05-05-2013, 06:28 PM   #322
soros151
SorosMotorsports
soros151's Avatar
Drives: Whiteout Pearl
I have recorded lower values. But that tends to be the ECU configuration believe.
Sent from my HTC VLE_U using Tapatalk 2
soros151 is offline   Reply With Quote
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
