Old 04-19-2013, 06:12 AM   #29
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Originally Posted by jmaryt View Post
what do you believe is causing this? idk,but for some reason,thought they was usin' ''stainless" pipes?
Different grades of stainless based on alloy content (chromium, nickel, etc.) - I assume these are a lower grade which will show some surface rust or staining. Will still last almost forever but looks like crap while doing it...
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 04-19-2013, 06:14 AM   #30
ihaskrayon
The Comedian
Drives: SWP BRZ Limited
6 months? I'd take it to the dealer and get new ones.
ihaskrayon is offline   Reply With Quote
Old 04-19-2013, 07:54 AM   #31
gvan1998
Drives: Blue FRS
Originally Posted by Retro86 View Post
its a cheap car lol
LOL but true
gvan1998 is offline   Reply With Quote
Old 04-19-2013, 09:07 AM   #32
Carbon420
Drives: 2013 FR-S Raven with carbon fiber
Originally Posted by brzadrian View Post
yeah mine too it bugs me everytime i look at it from the back
Isn't that what the undercoating is for?
Carbon420 is offline   Reply With Quote
Old 04-19-2013, 09:13 AM   #33
CaptainSlow
CaptainSlow's Avatar
Take them off, clean them up and spray them with a high temp clear coat
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
The Following User Says Thank You to CaptainSlow For This Useful Post:
ftc~brz (04-19-2013)
Old 04-19-2013, 09:34 AM   #34
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Originally Posted by dacedace View Post
Cheap steel, its pretty sad to see this in a japanese sports car.
Define cheap steel for me.
Old 04-19-2013, 11:47 AM   #35
Mandy
I came from a motorbike
Mandy's Avatar
Drives: Firestorm 2013 FR-S 6MT
Originally Posted by Demandred7 View Post
How much for those bad boys? They look big enough to stop a car twice as big as the FR-S.
$3000 for the whole kit. Quite pricey, but it's most likely going to be my first upgrade.
Mandy is offline   Reply With Quote
The Following User Says Thank You to Mandy For This Useful Post:
Demandred7 (04-19-2013)
Old 04-19-2013, 01:16 PM   #36
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
The factory brake system has been fine for us thus far with just upgraded pads and lines. BBK, while cool looking, don't help your braking distances that much....thats more limited by your tires. The BBK will increase braking feel, but I don't see it as a viable upgrade for the money unless you're building a purpose built racecar...and even then I'd be hesitant unless you're running long races or have FI.
GTM_Challenge is offline   Reply With Quote
The Following User Says Thank You to GTM_Challenge For This Useful Post:
strat61caster (04-19-2013)
Old 04-19-2013, 01:44 PM   #37
jarviz
jarviz's Avatar
Drives: Raven FRS MT
Everybody says to just take them off and clean them... Does everybody here have their own garage or car lift? and is removing the calipers that easy? The only thing I've done under the car is an oil change and replacing a spare.
jarviz is offline   Reply With Quote
Old 04-19-2013, 01:49 PM   #38
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
You should be able to do it with a car port, jack, jack stands and a couple feet of extra space to sit down in front of the wheel and pull it off.
http://www.ft86club.com/forums/showthread.php?t=24614
But if you're not comfortable definitely don't mess with the brakes and find a shop or supervision from someone who is.
Edit: "BBK" only helps with brake fade due to heat buildup, they do not increase stopping power, as mentioned above tires will do more for decreasing stopping distance than brakes will.
ineedyourdiddly
Old 04-19-2013, 01:51 PM   #39
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
my rears are starting to rust. I need to paint them soon.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 04-19-2013, 04:56 PM   #40
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Originally Posted by ProTekk View Post
No rust on my N1
Sent from my Galaxy Nexus using Tapatalk 2
I was going to get upset, but, then I thought "oh well, I guess I will just have to upgrade my exhaust - shucks."
Demandred7 is offline   Reply With Quote
The Following User Says Thank You to Demandred7 For This Useful Post:
ProTekk (04-19-2013)
Old 04-19-2013, 05:04 PM   #41
Demandred7
Demandred7's Avatar
Probably the fact that my FR-S is my daily driver and the excessive amount of salt used on the roads and parking lots compounded by cheap metal. Pretty sure that I read that not everyone uses the highest quality stainless steel. I don't think that they saw the need to put the best metals on something a lot of people are going to swap out. Same goes for the callipers.
Old 04-19-2013, 05:09 PM   #42
Demandred7
Demandred7's Avatar
If they work half as good as they look, I am sure you will be satisfied, not that the FR-S' brakes suck, those would just be way better.
Takeda exhaust rusting... trish07 Engine, Exhaust, Transmission 96 03-12-2014 12:41 PM
304 SS rusting in two weeks? Anorax Engine, Exhaust, Transmission 91 06-11-2013 10:37 PM
WTB: OEM FR-S / BRZ calipers crimespree Brakes, Suspension, Chassis 5 03-30-2013 11:13 AM
Anybody else's car rusting yet? Selvedge Issues | Warranty | Recalls / TSB 17 10-31-2012 09:11 AM
Fast car Fast driver vinyl decal I need help francosolracer Cosmetic Modification (Interior/Exterior/Lighting) 18 10-20-2012 03:43 AM
