Old 03-21-2013, 10:43 PM   #15
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Correct me if I'm wrong, but putting a HID bulb in the DRL/high beam slot would be blinding to oncoming traffic as there is no projector housing there.
Even putting an HID bulb into the stock projectors is a bad idea unless you bend the light cut off metal piece down or get proper projector housings, such as the ones from The Retrofit Source.
OjiGeorge is offline   Reply With Quote
Old 03-22-2013, 12:36 PM   #16
jjdrivesajazz
Drives:
80% of the time, you use your high beams to flash for a quick second or use them for a couple seconds on the backroads, rarely do you use your high beams for a long period of time. I do not suggest installing HID kits into the high beam for a couple reasons
-Quick flash of the high beams will cause the bulbs/ballast to fail prematurely
-HID bulbs take about 15-20 seconds to warm up and fully settle in color temperature, so they wouldn't be bright for flashing anyways
-You'd have to run a relay/resistor harness to allow the HID's to function properly during DRL mode
I personally would get a pair of authentic PIAA or Raybrig 9005 bulbs, they work for DRL mode and high beam mode, function like OEM, and are a brighter white than OEM.
jjdrivesajazz is offline   Reply With Quote
Old 03-22-2013, 12:41 PM   #17
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Do you have a link to these bulbs?
husker741 is offline   Reply With Quote
Old 03-23-2013, 03:00 AM   #18
Kai Uhl
Kai Uhl's Avatar
Originally Posted by Trashed675 View Post
Whatever you do DON"T BUY THESE.
I had one separate and fall into the headlight with no way to get it out. I had to bake and split the headlight, i took the opportunity to paint the headlight, but it was still a huge PITA.
I'll post pics if you want, i'm just being lazy.
I bought those exact DRLs lol. I havent had a problem with them though. or at least not yet
Kai Uhl is offline   Reply With Quote
Old 04-18-2013, 05:01 PM   #19
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
@jjdrivesajazz is this Cree LED pretty good for DRL or just so so ....
http://www.ebay.com/itm/2pcs-20W-CRE...d5e85a&vxp=mtr
Old 04-18-2013, 05:05 PM   #20
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
http://www.ebay.com/itm/PIAA-Super-P...5b7807&vxp=mtr
Old 04-18-2013, 06:56 PM   #21
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Originally Posted by boredom.is.me View Post
I second this. It doesn't matter what LED DRL you get. As long as you get an LED DRL, you WILL lose your high beams. I got mine from HID powerhouse and they look good, but I am considering real bulbs.
Why is this?
Carlitoz3 is offline   Reply With Quote
Old 04-18-2013, 07:25 PM   #22
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
HID_Powerhouse's DRL's are G's 7.5 watt 9005's I have them on my car and they are nice -- I don't care about high beams since i rarely use them. DRL's they are great.
I'm looking for LED low beams now since I really don't care about messing with HIDs anymore.
CamryDS is offline   Reply With Quote
Old 04-18-2013, 08:01 PM   #23
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
here ya go
http://www.ft86club.com/forums/showthread.php?t=27891
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 04-18-2013, 10:58 PM   #24
FR-Slide
Drives: 13 Whiteout 6MT
Is there no way to hardwire LED DRLs to function as high-beams ever?
FR-Slide is offline   Reply With Quote
Old 04-18-2013, 11:52 PM   #25
Xdragonxb0i
Drives: ex500r
They dont just get hot enough/ bright enough to function as High beams.
Xdragonxb0i is offline   Reply With Quote
Old 04-18-2013, 11:54 PM   #26
FR-Slide
But I guess what I am asking is, with LED DRLs can you not at least activate them to shine (with low-beams) when the high's are turned on? Surely something is better than nothing, no?
Old 04-19-2013, 12:44 AM   #27
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Originally Posted by Carlitoz3 View Post
Why is this?
LED's do not project light nearly as well as halogen and HID bulbs.
Old 04-19-2013, 12:46 AM   #28
boredom.is.me
Custom User Title
They do function when you flip your high beams on. However, they aren't any brighter when in high beam mode than they are when they are on DRL's.
LED -> One Brightness
Toyota 86 DRLs 86drift Australia Classifieds 8 04-08-2013 11:46 PM
LED DRLs on A/T?? eddieEndo Cosmetic Modification (Interior/Exterior/Lighting) 16 03-21-2013 06:47 AM
Difference Between $3 DRLS and $40 DRLS? FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 14 12-31-2012 05:05 AM
LED DRLs bulbs! seven Exterior Parts (Aero, Lighting, Etc.) 0 11-05-2012 01:34 PM
Adding led Halos as DRLs? Roborat Cosmetic Modification (Interior/Exterior/Lighting) 6 07-15-2012 06:54 PM
