#309 |
Who's the BADDEST?
Drives: 2013 BRZ Limited - Crystal Black
I ran my stock BRZ in an event a few weeks ago. I spun out twice!
The next event for NY Region is in a few weeks, I just need to learn to go easy on the throttle out of corners. I want to do tires but I know I'll learn fast on the sh*tty Michelins. I'm hooked though!
AM I THE MEANEST?
AM I THE PRETTIEST? AM I THE BADDEST LOW DOWN MOFO AROUND TOWN? SHO-NUFF! |
#310 |
Add some rear toe-in will help with the power on oversteer. If you are on a stock alignment it could be toed out for all you know. Stock tires of course are much easier to overpower than something decent.
#311 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
On stock front bar, a .15 degree toe-in on each rear is really nice
![]() I reduced to .1 when I went with Strano bar.
#312 | |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
-Keith
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
| The Following User Says Thank You to Miniata For This Useful Post: | trippinbillies40 (04-18-2013) |
#313 |
Drives: 2013 FR-S Asphalt
There are two schools of thought for new folks and what they should or shouldn't do to their cars while learning.
Thinking 1: Don't touch anything and "learn to drive" Thinking 2: Set the thing up to a known good starting point and "learn to drive". I'm a #2 type guy, and not just because I sell parts (seriously, in fact I am stubborn about not selling stuff that won't help), but because I teach autocrossing and have for years, and at more than a casual local level. In fact when I teach I actually earn more per day than a Skip Barber or Bondurant instructor. Let's think this through. If you were learning to drive a stick, would you want to learn in a car with terrible throttle tip in, and a clutch that is super touchy, and a gearbox that isn't synchronized? Probably not. But yet folks seem hell bent on telling others to drive the car stock, they'll learn more. They won't, it's not easier to drive stock it's harder, much harder. And slower. And trust me, the fastest way to wreck someone's confidence is for them to be way off the pace in a hard car to drive. The harder they try, the worse it gets. If I want to learn to shoot a handgun, I'll start with something pretty close to what I want to use. Doesn't need to be competition grade or anything, but if you know anything about guns you know that tuned ones tend not to be harder to shoot, cheap box stock ones are the worst, typically. Grip is grip. If you have more of it, and the car behaves more like you want it to ultimately want it to behave, you learn more about driving it, and without excuses. It's common for folks to not want to change things when starting out. I get it, it costs money. The upside is it makes a better driving street car too. But really it takes away excuses on the car being out to lunch and not everyone can handle that. For every argument for, there is one against. In the past I'd recommend folks start on tires less than Hoosier's, something that is close but didn't need to have every tenth worth of speed. But since so many of you guys are running either STX or RTR (or whatever it will be in the future), the street tires wear well enough that it's silly to be out there skating around on crappy tires. Camber is easy to add and it's so little and the car is so light it doesn't tear up tires. Shocks and the bar make the car more forgiving, and as you learn you can play with shock settings to suit your taste. |
| The Following 4 Users Say Thank You to Sam Strano For This Useful Post: | Areddi (04-18-2013), neurokinetik (04-18-2013), shaunsweeney (12-21-2013), suaveflooder (04-17-2013) |
#314 |
Drives: Scion FRS
I agree with Sam on this one. Why learn to drive a car that is set up improperly and then have to relearn when you make changes. Do it once properly and be done with it. The only thing you can blame then is the driver.
We're not happy till you're not happy 2013 Scion FRS Whiteout 6MT SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover. |
#315 | |
Drives: '22 WRB
| 2012 BRZ/FR-S Stock Class Autocross Discussion | EMguy | Tracking / Autocross / HPDE / Drifting | 183 | 01-04-2013 03:17 AM |
| What SCCA autocross class will the FRS be most competitive | SVThis | Tracking / Autocross / HPDE / Drifting | 5 | 07-30-2012 04:29 PM |
| Share/discuss (this mornin) 86 Newsletter... | RebootWindows | AUSTRALIA | 6 | 07-19-2012 04:15 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
| Discuss.... | carbonBLUE | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 02-11-2012 12:55 PM |
