Old 04-17-2013, 12:58 PM   #15
robispec
Drives: Black frs project
Originally Posted by CBR600RR View Post
have you considered getting fuel foam? it is more known in the morotcycle racing world to keep the fuel from sloshing back and forth and upsetting the bike in switchback turns.
teh foam comes in little cubes and is simply stuffed into the fuel tank right up to the brim. it displaces next to no volume of the tank too.
I am guessing that since it isn't happening to you at a full tank that fuel sloch is your problem, and since you are FI your pump is consuming fuel so fast that it is getting air when the fuel sloshes.
this is looking better and better lol
robispec is offline   Reply With Quote
Old 04-17-2013, 01:03 PM   #16
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Might consider this for my ITA car which has a stock tank. What's the degradation rate of this foam? How does it withstand E10 fuel and how often does it need to be replaced?
PRO86 | WTCC | STL
Old 04-17-2013, 01:10 PM   #17
Dezoris
Dezoris's Avatar
You have to tools to log these issues, I am surprised you are not constantly data logging, when you are out running this hard?
Old 04-17-2013, 01:13 PM   #18
CBR600RR
Drives: Raven Black
here is a quick ebay link: http://www.ebay.com/itm/10-Gallon-An...#ht_838wt_1156
I am not sure of the degradation rate if any. I have never used it or really read up much on it.
Old 04-17-2013, 01:43 PM   #19
FRSPirate
FRSPirate's Avatar
Drives: 13 Scion FRS Raven M/T, 05 Raven R6
Yeah, heard about the fuel cell foam in bikes as well.
Quick search has a lot of people raving about this stuff:
http://www.fuelsafe.com/store/foam-baffling.html
I have read that you may need to replace it more frequently and that you may need to run another filter but it may be related to cheaper foam. Everything else i have read, the guys linked above are still the first choice in foam baffling. Most complaints are about the cheap stuff from Jegs and Summit.
-Alex
05 Raven R6
13 Raven FRS M/T
FRSPirate is offline   Reply With Quote
Old 04-17-2013, 02:01 PM   #20
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
so...news update
had a good long talk about this..
I am not alone, @robispec has experienced the same issues, so its about carrying high G's thru a corner (he is way lower CG and I am way pushing my r-comps)and pulling fuel out of the bowl just afterwards of a high G event and going WOT-not pump limited, and thats why I have not put a aftermarket pump in, it will only make it worse.
Per Robi, he is about to put his OE pump back in, as it in fact does get worse with the higher flo pump...so that made me feel better about what I had been theorizing from my tests, and we have arrived at identical conclusions, him on NA e85 and me on FI pumpgas, so bigger pump is NOT the answer. Thats the problem rather.
While none of you will ever see this on the street, tho it is a very real issue for those who track it at the limit. As I expect the problem to be worse doing the 12psi testing I'm about to do, it makes me hesitate tracking the car that way, it makes me worry about lean----? leading to Kaboom! and so I think its good to know the track limits of the oe fuel setup,
and the risks goes up as boost goes up
Robi and I agree, the solution is out of the box, meaning the oe fuel tank and setup is where the problem lies, it was never made to do what we are asking it to do. This is gonna slow down my testing, since unlike many guys happy with a dyno chart and a few passed cars on the street, I'm not happy till this thing runs like a wristwatch out on the track
tentatively I'm firming up plans for a visit out to see Robispec to deal with the fuel issue as a priority, end of May is when I plan to be out there for car work. I'm looking at a custom fuel cell.alum solution from him, as its clear he's already ahead of me with recreating the problem and finding a solution, this will be a good, I'm looking fwd to working with Robispec.
If we can solve teh fuel issue, then it makes sense to continue to make it faster, both in corners and in straights, so that helps me continue on to adding better suspension parts-right now I'm fuel limited in corners when I am anything but full of fuel, so adding front control arms, be it Robi or racerx, will need to wait till I solve the fuel issue. If that goes well, I may be up for the robispec cooling kit too...
those of you who have no clue what this is, it will require you either run a high flo setup, like robispecs tuned e85, or FI with high fuel demand, go spend a bunch of time on the track and you will see this thing rear its ugly head, its systemic, not build specific..we have seen it gets worse with adding a high flo pump alone
EDIT:Update,I'm looking into the dynosty solution as well.
this will be something that anyone and everyone who tracks, as your skills and build increase, you will all need once you max out the bowl refill capability on the oe plumbing. Its the magic combo lefty hander, slosh, tank level etc
I broke the dongle on my ecutek key while lapping, so theres a small gap but usually I am logging, I wasnt logging the fuel rail pressure value that day tho.. next weekend I have the opportunity to track but no dongle...so ... waiting on ecutek and @PERRIN_Jeff to help me recover from that one
Huehuecoyotl is offline   Reply With Quote
The Following 2 Users Say Thank You to Huehuecoyotl For This Useful Post:
ftc~brz (04-17-2013), naikaidriver (04-17-2013)
Old 04-17-2013, 02:07 PM   #21
robispec
confirmed we are working on a 2 pump swirl pot, solution and a full custom cell as well (visions of the NASA 25H running in my head Drivers/sponsors lets talk).
The Following 3 Users Say Thank You to robispec For This Useful Post:
AZP Installs (04-13-2015), CSG Mike (04-17-2013), Huehuecoyotl (04-17-2013)
Old 04-17-2013, 02:19 PM   #22
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Originally Posted by Huehuecoyotl View Post
so...news update
those of you who have no clue what this is, go spend a bunch of time on the track and you will see this thing rear its ugly head, its systemic, not build specific
Thanks to you and @robispec for working on this issue! The more I think about it, this really explains what happened to me on the skidpad!
Scott
naikaidriver is offline   Reply With Quote
The Following User Says Thank You to naikaidriver For This Useful Post:
Old 04-17-2013, 02:41 PM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
No thanks on a higher mounted aftermarket fuel cell. I would rather see a new fuel pump bucket solution. I know you guys are not the only two out there running 10/10ths on track. Has anyone else had this issue?
Old 04-17-2013, 02:43 PM   #24
CSG Mike
CSG Mike's Avatar
We gonna take on 949?
Miata vs FRS?
Old 04-17-2013, 02:44 PM   #25
CSG Mike
CSG Mike's Avatar
I believe the issue is from their respective cars having higher rates of consumption (boost in one case, E85 in the other).
I'm honestly surprised that a stockish car has starvation issues. We ran at ACS with no issue, even with the gas light on (14 degree banked turn, sustained for over 10 seconds, nearly 2G lateral)
Old 04-17-2013, 02:46 PM   #26
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Miata vs FRS?
That would be awesome. I loved watching the show about the 25 hours this year. It is actually the only thing I have saved on my DVR right now, haha.
Old 04-17-2013, 02:48 PM   #27
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I was thinking about Jon Miller setting the TTD record at Roebling last weekend. He was on an E85 tune and some serious grip, but Roebling really only has two left hand turns.
Old 04-17-2013, 02:48 PM   #28
Huehuecoyotl
its going to be in stock location...rip out old tanks, put in new
by now you know, I go to try and test out whomever's solutions I like* and I think I am liking this alot
Left hand drive GT86 exist? hotmetal Scion FR-S / Toyota 86 GT86 General Forum 62 01-04-2018 01:22 AM
Fuel Starvation issues? YAY OR NAY? track_warrior Tracking / Autocross / HPDE / Drifting 23 10-22-2013 11:19 AM
AT holding 2nd gear to high revs during a long left turn EK_Golfer Scion FR-S / Toyota 86 GT86 General Forum 9 03-01-2013 10:35 AM
Left hand drive cars in Australia Kevstra AUSTRALIA 27 01-24-2013 07:30 PM
Fuel Starvation feldy Tracking / Autocross / HPDE / Drifting 1 06-09-2012 10:14 AM
