Old 04-16-2013, 05:46 PM   #15
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
For all those people that worried about low coolant a few months ago.....how does it look now that's it warm out again?
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 04-16-2013, 05:51 PM   #16
OrbitalEllipses
Drives: Attitude
Still kinda green.
Old 04-16-2013, 06:17 PM   #17
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Still kinda green.
It should be blue
Old 04-16-2013, 07:21 PM   #18
OrbitalEllipses
Drives: Attitude
It should be blue
Nah man, replace that crap with Peak Long Life!
Old 04-18-2013, 09:06 PM   #19
iaclimber4
iaclimber4's Avatar
Drives: 2013 Whiteout FR-S MT
In Florida, fairly warm year round. Coolant reservoir is about half way between max and low. Never refilled, running about 5500 miles.
iaclimber4 is offline   Reply With Quote
Old 04-20-2013, 01:13 AM   #20
ItsOnlyNoe
Drives: 91 Mr2
Just a note of knowledge the Low and full aren't really Low and full. As Coolant becomes hot and expands it can raise as it pushes fluid from the radiator into the reservoir and then when it cools down and condenses it retracts back into the radiator thanks to the simple beautiful thing called the Radiator cap. So as long as you aren't at empty and somewhere in between then you should be cool. Same thing goes for the dipsticks and and any other fluid like Power steering in other cars. Brake Fluid not so much in street cars it typically only changes with pad wear.
ItsOnlyNoe is offline   Reply With Quote
Old 04-20-2013, 09:34 AM   #21
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
My BRZ has 9,000 miles and the coolant level has been steady.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 04-21-2013, 01:10 AM   #22
Juurian
Juurian's Avatar
Drives: 2013 Scion FRS WhiteOut
i have a feeling you're looking at the overflow tank lol
Winnipeg, Manitoba
Juurian is offline   Reply With Quote
Old 04-23-2013, 04:25 PM   #23
torqdork
torqdork's Avatar
Drives: RV-7
What coolant is OEM? If it's Toyota Long Life, it's good for 100K miles but it's pink, not blue or green.
torqdork is offline   Reply With Quote
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 05:13 PM
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 06:34 AM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
Good Eats in AZ apoplexy Southwest 1 08-12-2012 03:28 PM
