Old 04-16-2013, 04:51 PM   #15
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
Still waiting for my set. *sigh*
JackSmiley is offline   Reply With Quote
Old 04-16-2013, 05:15 PM   #16
RYU
RYU's Avatar
Drives: really slow...
Originally Posted by swift996 View Post
I can't wait to get mine in! Thanks for the review.
BTW - You mentioned you lowered it 1" around. How much did you have to adjust them? I want to do about the same.
+1!
I'm still waiting for my R1s which I believe have similar off-the-shelf rates and hoping to get some guidance from you on where the lower perch is to get you at 1". I'm hoping to get max height (I know i'm crazy) which I hear results in about 30mm drop but i'm going off my crappy memory for this. If you were able to get 1" that's less than 30mm which would be fantastic.
20mm drop is just enough to clear most parking blocks and over the years i've had enough of tearing up front lips
RYU is offline   Reply With Quote
Old 04-16-2013, 05:32 PM   #17
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The springs, helpers, and spacers arrived for mine today.. dampers themselves on thursday.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-16-2013, 05:45 PM   #18
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
They are coming!!
Originally Posted by RYU View Post
+1!
On the way Regan i'll have tracking for both of you guys before you know it!
Old 04-16-2013, 07:21 PM   #19
JackSmiley
JackSmiley's Avatar
Lol got to love @JoeBoxer
Old 04-16-2013, 07:26 PM   #20
donutfilling
donutfilling's Avatar
Drives: frs
I don't really remember but I think the fronts off the shelf were 1 inch or extremely close. I'll snap a picture of how it sits when I have time. Keep note that height could also set a little more.
+1!
donutfilling is offline   Reply With Quote
Old 04-16-2013, 11:50 PM   #21
xwd
I mounted my MCS reservoirs the same as the R2s in the front. It's easy to just put them under the fender liner where the brake hard lines run.
As for heat I have measured mine with a pyrometer and they definitely heat up to 90-95 degrees. I checked the pressure and the difference hot and cold was negligible. You could always use some reflective heat barrier if you are that concerned.
Old 04-18-2013, 03:59 AM   #22
donutfilling
Drives: frs
Got that pic for ya!
Do you have a pic of the front strut mounted on the car with the wheel off? (not the reservoir).
- Andy
Old 04-18-2013, 08:00 PM   #23
ayau
Drives: Some rust bucket
@donutfilling, can you confirm for us the part numbers for the front and rear springs?
Old 04-18-2013, 09:55 PM   #24
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I have mine sitting in my garage... maybe I'll assemble mine this weekend and throw them on the car. (Mine came in pieces due to the way they were ordered)
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-18-2013, 10:13 PM   #25
ayau
Are you keeping the front oem crash bolts at max camber? I've read that it's recommended to get camber at the hub and to add any additional camber with the camber plates. Adjusting camber at the hub won't change the geometry of the coilover angle.
Old 04-18-2013, 10:42 PM   #26
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yes.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-18-2013, 10:57 PM   #27
OrbitalEllipses
Drives: Attitude
While correct, it's way easier to get camber with plates.
Old 04-18-2013, 11:07 PM   #28
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
To adjust, yes. Just set to max during install, most will still be adding some up top anyways.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Fortune Auto 500 Coilover Review stoneman155 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 01-16-2020 05:22 AM
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
***Time to freak out, Eibach coilover pricing available**** JoeBoxer Brakes, Suspension, Chassis 154 05-16-2013 05:30 PM
Eibach Multi-Pro-R1 VS KW v3 thebear21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 04-10-2013 01:32 PM
Eibach Coilover Options - SEMA 2012 Coverage FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 01-25-2013 07:19 AM
