| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2013 FRS - Whiteout
Question about Fumoto valve
Which washer is better to use with the Fumoto valve? Crush washer or the cork washer it comes with?
#2 |
Drives: FRS :D
i used the one that came with it. not leaks no problems
Out of the FRS game
| The Following User Says Thank You to Mr.Jay For This Useful Post: | zoomzoomers (04-17-2013) |
#3 |
Drives: 2010 BMW M3, 2013 Subaru BRZ
#4 |
SLO NO MO
I too use the blue one that came with it. No problems. Hand tightened it, then did about a quarter turn with a crescent.
#5 |
Driveway labs.
Drives: '13 BRZ Limited, 6sp, SWP
Which valve?
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list) -'13 Town and Country Limited (Mods: too many kids) |
#6 |
Cool Stuff
Drives: Cool Car
use the supplied one. that's why they give it to you.
#7 |
I also use the one that came with it. Works great no leaks.
As for which valve, the fumoto site has a car model selector to pick the right one. I think I ordered the shorty for the most clearance, it has a little nozzle thats about 1/4" long and came with a plastic nipple that clips on to attach a drain hose. |
#8 |
I have yet to do an oil change since I installed it some time ago, but not a single problem. The shop I go to took a look at it and said they've give me a $5 discount on oil changes. I take my own filter and oil so they just charge me $15 to do the work and take care of the waste. A bargain if you ask me. So the valve will have paid for itself in 3 oil changes.
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#9 |
If anyone is curious/concerned, the valve does not stick below the belly pan, and it has a firm spring holding the tiny lever in a notch to lock it in the closed position. You have to hold the lever up against the spring before the valve can open. The valve itself is very high quality and lever action is quite firm, so there's literally no opportunity for it to come open on its own or leak. I can't remember which direction the lever is clocked when its tightened down with the fumoto gasket, but I faintly remember thinking it was in a good position.
Now I only have to get the front of the car high enough for my arm to reach the lever and position a drain pan; with the filtwr up top, the rest is cake! |
| Fumoto valve quick question | #87 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 130 | 11-21-2015 04:32 AM |
| help me decide: Fumoto Valve or Greddy MagDrain | chenshuo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 41 | 09-10-2013 09:43 PM |
| Installed Perrin shifter bushing & Fumoto oil drain valve | zooki | Engine, Exhaust, Transmission | 23 | 03-31-2013 05:18 PM |
| FS: Fumoto quick valve | Laika | Engine, Exhaust, Bolt-Ons | 1 | 01-08-2013 01:51 PM |
