Old 04-16-2013, 01:20 AM   #1
Bleevin
Drives: 2013 FRS - Whiteout
Question about Fumoto valve
Which washer is better to use with the Fumoto valve? Crush washer or the cork washer it comes with?
Bleevin is offline   Reply With Quote
Old 04-16-2013, 02:07 AM   #2
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
i used the one that came with it. not leaks no problems
Out of the FRS game
Mr.Jay is offline   Reply With Quote
The Following User Says Thank You to Mr.Jay For This Useful Post:
zoomzoomers (04-17-2013)
Old 04-16-2013, 03:00 AM   #3
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
I also use the one that came with it.
I have the short nipple one and I track with it. No leaks or clearance problems so far.
RAWR BRZ is offline   Reply With Quote
Old 04-17-2013, 01:33 PM   #4
Foobar
SLO NO MO
Foobar's Avatar
I too use the blue one that came with it. No problems. Hand tightened it, then did about a quarter turn with a crescent.
Old 04-17-2013, 01:58 PM   #5
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Which valve?
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
Old 04-17-2013, 04:07 PM   #6
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
use the supplied one. that's why they give it to you.
killerkid08 is offline   Reply With Quote
Old 04-17-2013, 04:27 PM   #7
wheelhaus
wheelhaus's Avatar
I also use the one that came with it. Works great no leaks.
As for which valve, the fumoto site has a car model selector to pick the right one. I think I ordered the shorty for the most clearance, it has a little nozzle thats about 1/4" long and came with a plastic nipple that clips on to attach a drain hose.
Old 04-17-2013, 04:34 PM   #8
zoomzoomers
zoomzoomers's Avatar
I have yet to do an oil change since I installed it some time ago, but not a single problem. The shop I go to took a look at it and said they've give me a $5 discount on oil changes. I take my own filter and oil so they just charge me $15 to do the work and take care of the waste. A bargain if you ask me. So the valve will have paid for itself in 3 oil changes.
Old 04-18-2013, 09:27 AM   #9
wheelhaus
wheelhaus's Avatar
If anyone is curious/concerned, the valve does not stick below the belly pan, and it has a firm spring holding the tiny lever in a notch to lock it in the closed position. You have to hold the lever up against the spring before the valve can open. The valve itself is very high quality and lever action is quite firm, so there's literally no opportunity for it to come open on its own or leak. I can't remember which direction the lever is clocked when its tightened down with the fumoto gasket, but I faintly remember thinking it was in a good position.
Now I only have to get the front of the car high enough for my arm to reach the lever and position a drain pan; with the filtwr up top, the rest is cake!
Fumoto valve quick question #87 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 130 11-21-2015 04:32 AM
help me decide: Fumoto Valve or Greddy MagDrain chenshuo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 41 09-10-2013 09:43 PM
Installed Perrin shifter bushing & Fumoto oil drain valve zooki Engine, Exhaust, Transmission 23 03-31-2013 05:18 PM
FS: Fumoto quick valve Laika Engine, Exhaust, Bolt-Ons 1 01-08-2013 01:51 PM
