Old 03-28-2013, 10:36 PM   #1
brillo
Drives: 2013 Firestorm FR-S
Can the transmission crush washers be reused?
thinking about changing my fluid this weekend wasn't sure if the dealers have them in stock or are they a standard size?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 03-28-2013, 10:45 PM   #2
schtebie
Drives: CBS BRZ Limited
Should be able to reuse it no problem. I know I did.
schtebie is offline   Reply With Quote
Old 03-28-2013, 11:04 PM   #3
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
My rule of thumb is, first time you take it off you should be able to reuse, second time you should replace it but still reusable if you cant get a hand on one and then third time change it ASAP. And yes the dealer does carry washers.
LeeMaster is offline   Reply With Quote
The Following User Says Thank You to LeeMaster For This Useful Post:
charged86 (04-27-2013)
Old 03-29-2013, 12:46 AM   #4
engee
Drives: Subaru
Probably, but just get a new one.
Dealers will stock them and they aren't be that expensive.
engee is offline   Reply With Quote
Old 03-29-2013, 06:45 AM   #5
runny_yolk
Drives: minivan
If you read this post you'll see that whereas the diff seems to have crush washers, the tranny has flat washers to begin with and can/should be re-used. In a pinch, I wouldn't hesitate to re-use a crush washer (but perhaps turn it around before installing).
True story, one of the "quick lube" places installed one crush washer right on top of another once on my oil drain plug. No oil leaked but I was pissed when I discovered this. I swear I'm never letting those clowns touch my car ever again.
runny_yolk is offline   Reply With Quote
Old 03-29-2013, 06:53 AM   #6
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
Make sure both surfaces are really clean (should be with a new car) before reusing it. Personally I prefer not to. My peace of mind is worth more than $3
RandomHero is offline   Reply With Quote
Old 03-29-2013, 08:03 AM   #7
runny_yolk
Drives: minivan
True enough, I wouldn't advocate re-using crush washers over and over, only if you can't easily get a replacement. That said, the transmission washer, which apparently is a flat washer, costs like $8 per washer and there appears to be no reason to replace it at all. Am I missing something?
Old 04-01-2013, 08:53 PM   #8
superpilun
Drives: 1986 MR2
The flat washers can be found at places like belmetric.com or mcmaster.com for about a dollar per washer or less. The crush washers used for the diff are probably more leak-proof because of the service interval, although I really have no idea. I don't think there's anything wrong with using a flat washer there as well.
superpilun is offline   Reply With Quote
Old 04-13-2013, 11:59 PM   #9
alex_86
alex_86's Avatar
Drives: 2013 scion firestorm frs
It's more than highly recommend to ALWAYS change out washer's or crush sleeves any time they have been in between services. none of them from factory were intended to be reused.
alex_86 is offline   Reply With Quote
Old 04-14-2013, 01:33 AM   #10
LeeMaster
Red wine
Actually, the rear differential has the flat washers and the transmission has the crush washers.... At least on my car it did..
Old 04-14-2013, 02:04 AM   #11
Hanakuso
I always change it. Saving $1-2 isn't worth a possible leak that might ruin the engine, trans or diff which would end up costing thousands. For the trans/diff they are more expensive for the washers but you change those fluids out less then the engine oil
Hanakuso is offline   Reply With Quote
The Following User Says Thank You to Hanakuso For This Useful Post:
Subie (04-21-2013)
Old 04-15-2013, 07:35 PM   #12
runny_yolk
Drives: minivan
Weird, I just changed my car's fluids. Tranny had flat washers (fill and drain). My diff had crush type (fill and drain). I swear the factory people just make it up when they build.
The Following User Says Thank You to runny_yolk For This Useful Post:
Crush Washer Sizes Eric1855 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 55 08-30-2021 02:21 AM
MT fill and drain washers diirk Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 11-09-2012 12:24 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
Man Crush A Friend's Car With A 100-ft Axe ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 11 01-19-2012 03:31 PM
Which Transmission ? gatchaman Engine, Exhaust, Transmission 15 10-29-2009 12:48 PM
