Old 04-14-2013, 07:08 PM   #1
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
help me decide: Fumoto Valve or Greddy MagDrain
Please help me decide. They each have their advantages and disadvantages over the other one. I like the convenience of the Fumoto Valve, but i also like the magnetic function of the MagDrain. What do you guys think i should get?
chenshuo is offline   Reply With Quote
Old 04-14-2013, 07:53 PM   #2
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Fumoto. It's nice being able to do quick oil changes with a flat drain container. If you change your oil often, then the magdrain would seem less advantageous. The only bad thing would be impact to the environment.
tech4pdx is offline   Reply With Quote
Old 04-14-2013, 08:17 PM   #3
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
magdrain.
IMO, unless you habitually overfill your oil, the fumoto doesn't really make anything much easier seeing as you need to get your car on ramps (or eq.) anyways. Fumoto valve saves...15 seconds per oil change?
I've become accustom to adding 5.2 quarts of oil so I'm not worried about overfill since I know that's the exact amount necessary based on how much oil stays in the engine after dumping.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 04-14-2013, 08:48 PM   #4
Foobar
SLO NO MO
Foobar's Avatar
Fumoto, IMHO. Still pretty damned convenient to not have to jack with a wrench, and if you have the S or N version with a hose, you have full control of where the oil goes - no more oil spattering around on a windy day for those of us who change oil outside on the driveway.
As for the Magdrain, I figure the oil filter is doing its job already, and wouldn't most of the metallic material in our engine be non-ferrous anyway?
Old 04-14-2013, 09:13 PM   #5
xxscaxx
Drives: 2013 SWP BRZ
Fumoto.
And just so you know, you can change the oil without jacking the car up if you are on stock suspension with this valve. Just drive it on 2x4 and you have enough space.
With my air suspension I just air up and I have enough room lol. I end up sitting and waiting for the oil to fully drain out since everything else takes two seconds.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Laika (04-14-2013)
Old 04-14-2013, 10:52 PM   #6
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by xxscaxx View Post
Fumoto.
I'm lowered slightly but I might still have to give this a try next time with my 2x8 ramps.
Old 04-15-2013, 04:04 PM   #7
jackhill
Drives: 2010 subaru
I recommend using a fumoto valve, have used in all my vehicles never had a problem + they don´t cost much. Check them out at fumoto valve original store.
jackhill is offline   Reply With Quote
Old 04-17-2013, 05:10 PM   #8
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
go with the valve, the fact you can change the oil without any tools besides a jack and stand, ramp, or a decent curb should mean more than a hardly effective magnet placed in the sump.
Get a filtermag, and go with the valve.
killerkid08 is offline   Reply With Quote
The Following User Says Thank You to killerkid08 For This Useful Post:
serial gixxer (04-17-2013)
Old 04-17-2013, 06:37 PM   #9
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
magnets schmagnets
Huehuecoyotl is offline   Reply With Quote
Old 04-17-2013, 07:07 PM   #10
sanmarcosfrs
sanmarcosfrs's Avatar
Drives: 2013 asphalt frs
I went with a dimple magnetic drain plug. Its a nice piece and for 35.00 Im not out much even if it doesnt work.
sanmarcosfrs is offline   Reply With Quote
Old 04-17-2013, 07:56 PM   #11
wrxneffect
wrxneffect's Avatar
Drives: 13 BRZ Ltd 6MT(sold), 03 WRX (RIP)
another +1 for the Fumoto valve.
I had one on my WRX for 10 years and loved the convenience of it. Does it save you a whole lot of time...ehh prob not but I def liked not having to wrench off the drain bolt.
I got one on the BRZ now and just ordered one for my beater that I just bought.
wrxneffect is offline   Reply With Quote
Old 04-17-2013, 08:03 PM   #12
BAS
Drives: Snow White
Another +1 for the Fumoto Valve.
I have race ramps, but after installing the Fumoto...I decided to put the car on the ground and see if I could reach the valve without lifting the car at all? I was able to. Now granted I am thin, almost 6ft2in, and stock suspension. It was still easy to reach. Will make oil changes a breeze, just snap on white connector/hose and twist...drain into oil pan.
TRD Exhaust/Cold Air Intake/High Pressure Radiator Cap (1.3 bar/18.5 psi)/Door Stabilizer, Cusco Front/Rear Type OS Strut Tower Brace/Power Engine Member Brace/Rear Member Brace, 215/45ZR17 PSS, Perrin Master Cylinder Brace/Shorty Antenna/Front Tow Hook License Plate Mount, TWM M1 Abrams White Pearl Shift Knob, SilverStar Ultra H11/9005, OEM Auto Dimming/Home Link Rearview Mirror, Full LED's with Switchbacks and JDM Clear Sidemarkers
BAS is offline   Reply With Quote
Old 04-17-2013, 11:43 PM   #13
serial gixxer
+1 for fumoto and filtermag or other magnet on filter. No mess to clean up. Love it!
serial gixxer is offline   Reply With Quote
Old 04-17-2013, 11:46 PM   #14
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
Is fumoto valve that convenient? I mean it takes a few second to wrench the drain plug...
What does filtermag do?
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Fumoto valve quick question #87 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 130 11-21-2015 05:32 AM
Installed Perrin shifter bushing & Fumoto oil drain valve zooki Engine, Exhaust, Transmission 23 03-31-2013 06:18 PM
FS: Fumoto quick valve Laika Engine, Exhaust, Bolt-Ons 1 01-08-2013 02:51 PM
