Old 04-12-2013, 12:29 PM   #1
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
New STi Chassis Mounts
The STi Page has been updated with the new Chassis Mounts.
http://www.sti.jp/parts/catalogue/brz_zc6/1.html
Engine Mount:
Transmission Mount:
Differential Bushing:
Subframe Bushing:
Steering Bushing:
Beyer Subaru is offline   Reply With Quote
Old 04-12-2013, 12:29 PM   #2
OrbitalEllipses
Drives: Attitude
Yessss. Someone baller get those engine mounts and review them.
Old 04-12-2013, 12:33 PM   #3
Hanakuso
I wonder if these are the same exact parts as the TRD mounts.
Hanakuso is offline   Reply With Quote
Old 04-12-2013, 12:34 PM   #4
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
Not till spark plug time comes hahaha.
Sent from my Nexus S 4G using Tapatalk 2
zohare is offline   Reply With Quote
Old 04-12-2013, 01:58 PM   #5
xwd
They are up on Japanparts. $227 for the engine mounts, $143 for the trans mount. How does that compare with Cusco? It's cheaper than the Perrin solid mounts.
The STi bushings and mounts were never outrageously priced compared to some of the other items.
Old 04-12-2013, 02:50 PM   #6
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Ha! Just saw these on Japanparts, linked their sad photos (EJ parts), got corrected by Orbital for being lazy and not noticing this thread, then realized I had the STI catalogues link myself, so I linked those pics instead. Glad this thread is here. I gotchu covered over on NASIOC BRZ Forum.
Old 04-12-2013, 04:04 PM   #7
Calum
That Guy
Drives: 2013 asphalt FRS MT
Those look sexy as hell, but whiteline has us covered for most of those. I wonder how the two different approaches will differ in feel and performance?
Those engine mounts are going on my list though! I thought I was done with buying mounts and bushings, damn.
Old 04-12-2013, 04:15 PM   #8
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
From the looks of it these are hard rubber mounts vs. most of the aftermarket which are poly. I don't have experience with STI mounts, but in the Honda world I have had a couple cars with the Mugen hard rubber bushings and for a DD I would much rather have the hard rubber vs. the poly mounts. Still have the improved response, but not the direct translation of vibration in a lot of cases.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 04-12-2013, 04:20 PM   #9
OrbitalEllipses
Drives: Attitude
I have had Group-N (hard rubber) engine mounts before. Only change in NVH was at start up. Could I get even LESS movement with poly or a solid mount? Yes. The trade off in NVH is not worth it for me. Rubber is the way to go.
Rubber vs. poly discussion for the bushings. One is not objectively better than the other, they just do similar things differently. Rubber should be less prone to noise and need less re-greasing. On the downside, you're going to have to press those bushings in whereas most aftermarket poly bushings will be split design so you just have to get the old bushing out (not necessarily with a press ).
Old 04-12-2013, 04:23 PM   #10
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
I had Group N transmission mount for my WRX. I enjoyed it. I'm hoping these are pretty much the exact same thing. No reason they shouldn't be. I had bought engine mounts, too, but decided I didn't want to hassle with them at the time so I sold them. Will definitely hassle with them this time around, though.
Old 04-12-2013, 04:31 PM   #11
mrk1
Drives: Sterling BRZ Ltd
I don't consider myself to baller but I'm in to buy a set of engine/trans mounts. I had Cusco and Group N mounts in my sti and loved the Group N much more.
Nothing better then over night parts from Japan. (not really paying for overnight shipping) I can use these as an excuse to also pick up the gurney flap for my wing.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-13-2013, 08:53 AM   #12
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
Does anyone know if the differential bushings will be legal for scca st?
enjoyminutemaid is offline   Reply With Quote
Old 04-13-2013, 09:06 AM   #13
Beyer Subaru
I would assume so if I'm reading the below correctly:
http://www.moutons.org/sccasolo/Rule...t_touring.html
Suspension bushings may be replaced with bushings of any materials (except metal) as long as they fit in the original location. Offset bushings may be used. In a replacement bushing the amount of metal relative to the amount of non-metallic material may not be increased. This does not authorize a change in type of bushing (for example ball and socket replacing a cylindrical bushing), or use of a bushing with an angled hole whose direction differs from that of the original bushing. If the Stock bushing accommodated multi-axis motion via compliance of the component material(s), the replacement bushing may not be changed to accomodate such motion via a change in bushing type, for example to a spherical bearing or similar component involving internal moving parts. Pins or keys may be used to prevent the rotation of alternate bushings, but may serve no other purpose than that of retaining the bushing in the desired position.
The only problem I see is that these aren't USDM parts. The angles and materials used should be allowed.
Old 04-13-2013, 09:39 AM   #14
enjoyminutemaid
I guess without knowing what the oem bushings look like, it's tough to tell.
Engine Mounts? mrk1 Engine, Exhaust, Transmission 17 05-15-2016 04:31 PM
Whiteline Com-c top mounts sw20kosh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 349 05-27-2015 05:15 AM
What's the Purpose of WL Com C Top Mounts? gbgracer Tracking / Autocross / HPDE / Drifting 16 03-27-2013 01:52 PM
upgraded mounts? 7thgear Engine, Exhaust, Transmission 19 01-11-2013 11:31 PM
