Old 03-27-2013, 12:22 AM   #1
gbgracer
Drives: 2011 STI
What's the Purpose of WL Com C Top Mounts?
If you are running camber bolts already do they increase the amount of neg camb that you can run?
Do you continue to use your camber bolts with them?
What's the max neg camber that they allow?
Do they raise the front of the car like many camber plates do?
Are there any negatives to running them?
Thanks!
gbgracer is offline   Reply With Quote
Old 03-27-2013, 12:48 AM   #2
wootwoot
Drives: FRS
They change camber by -0.5 and add +0.75 of caster. They had some issues with the initial batch but they seem to have it handled now. When you add camber bolts you can run -4 or -5. Not that it would be advisable in most cases, but you could. I plan on running them...
wootwoot is offline   Reply With Quote
Old 03-27-2013, 12:48 AM   #3
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
They don't raise the car. The give you more negative camber without bolts and more tire clearance because you don't tilt the tire closer to the spring like you do with bolts. They also add caster. I run them on my car, and I sell them too. I have KW's which have slotted holes so no camber bolts are needed to get a LOT of camber.
Yes, if you add them to bolts you can increase your camber that much more. I'd say they add an easy 1 degree based on the fact that between the KW slots and the mounts I can get -3 or more.
Sam Strano is offline   Reply With Quote
Old 03-27-2013, 12:49 AM   #4
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
YES
You CAN
I dunno, 2.5 from myplates and almost another degree from bolts?
I dunno, I run GC, & they do not
I'm curious too, they are rubber rite?
Thanks!
reply in red
Huehuecoyotl is offline   Reply With Quote
Old 03-27-2013, 12:49 AM   #5
jamal
jamal's Avatar
Drives: Legacy GT
It is not a camber plate, it is a top mount just like the stock one, except that it is made with stiffer rubber and the bearing is offset to gain you some camber and caster. You'll still need to adjust camber at the strut.
woah, all those posts happened fast.
jamal is offline   Reply With Quote
Old 03-27-2013, 12:50 AM   #6
Huehuecoyotl
wow FOUR replies in a minute!
Old 03-27-2013, 01:01 AM   #7
gbgracer
Drives: 2011 STI
Thanks for the info! I feel fully educated now... ;-)
Old 03-27-2013, 01:14 AM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I have them and camber bolts. I can't get more than -2.2degrees. No way you'll see 4 or 5 degrees.
Mine finally started making noise. Oh well.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-27-2013, 01:26 AM   #9
wootwoot
Drives: FRS
The adds say -5...
Do you have the most updated version? What kind of noise are they making? I don't like the sound of this...
Old 03-27-2013, 01:28 AM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The adds say -5...
Mine are older. If they add -.5 camber plus the -1 to -1.5 for the bolts that's nowhere near -4 to -5. Noise is due to the lack of a conical washer.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-27-2013, 07:15 AM   #11
makinen
makinen's Avatar
Drives: Toyota 86
Hello,
Is it required to use a conical washer with recent com-c?
makinen is offline   Reply With Quote
Old 03-27-2013, 08:25 AM   #12
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by makinen View Post
Hello,
Not sure.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-27-2013, 09:00 AM   #13
OrbitalEllipses
Drives: Attitude
Aside from bearing issues, in the older plates the rubber used to separate from the hat itself. QC on them hasn't been very good from what I've seen.
Old 03-27-2013, 11:36 AM   #14
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
My Asphalt Tri-Purpose Build Thread DD/Autox/HPDE TPTBOY Member's Car Journals 14 04-15-2013 02:51 PM
Thread with genaral purpose TIE Pilot Site Announcements / Questions / Issues 2 03-07-2013 03:13 PM
Purpose of alternator and a/c covers Turbowned Engine, Exhaust, Transmission 3 03-03-2013 04:54 PM
Purpose of oil catch can? denverizzles Engine, Exhaust, Transmission 1 06-28-2012 03:55 PM
What purpose or role will the FR-S / BRZ serve you? switchlanez Scion FR-S / Toyota 86 GT86 General Forum 139 03-27-2012 02:28 PM
