go_a_way1
Old 04-12-2013, 12:50 PM   #1177
fred864
Drives: brz/fr-s
Originally Posted by Slick View Post
Need wheel offset.
You can fit 255's in front depending on the offset (edit: and tire brand) but still very tight, and 9.5" wheel is very aggressive for the front, no issues in the rear though.
With a stock suspension setup, you will either poke out or rub against the strut on the inside depending on the offset. Not an ideal fitment either way.
+ 40 offset both front and rear!
Will 255 fit with this set up
fred864 is offline   Reply With Quote
Old 04-12-2013, 02:16 PM   #1178
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by white_knight View Post
I'm guessing you mean a perfect fit???
Perfect fit is subjective. The fitment is OK.
ill86 is offline   Reply With Quote
Old 04-12-2013, 02:18 PM   #1179
ill86
ill86's Avatar
Drives: iG FR-S
Slick, thank you for providing valuable input and helping in this thread. It is appreciated by all of us.
Old 04-12-2013, 02:21 PM   #1180
Overland'n'5thGEN
Overland'n'5thGEN's Avatar
Drives: 5th Gen Toyota 4Runner
Originally Posted by Overland'n'5thGEN View Post
Looking at 18x8.5 with +47 offset, square set up with 245/35x18 tires. Looking to eventually get Ohlins coils to bring the car down about an inch. Will I have issues with this set up?
Any words of wisdom on this set-up?
sent from a Galaxy SIII...
Overland'n'5thGEN is offline   Reply With Quote
Old 04-12-2013, 02:23 PM   #1181
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
No sweat, glad to help out.
Not new to cars and wheels, but fitment is always tricky on various cars.
I learned alot going through this process with the FR-S, so just paying it forward.
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
ill86 (04-16-2013)
Old 04-12-2013, 04:06 PM   #1182
Slick
Slick's Avatar
+47 on that width of wheel would put it very close to the stock strut (if not against it), but if you are moving to coilovers you will have additional clearance inboard but you may rub the sway bar on tight turns. I.e. coilovers first, then wheels. Or find a set of these wheels to test fit first.
Maybe others can chime in better in terms of inside clearance, but I see no issues with poke with this setup, should be less than flush on the front.
I think on the rears you will be fine even without coilovers.
ill86 (04-16-2013)
Old 04-12-2013, 04:15 PM   #1183
Overland'n'5thGEN
Would I be better off finding a +38 offset?
Old 04-12-2013, 04:29 PM   #1184
Slick
Slick's Avatar
YES! This will give you a flush fitment and not give you the inner clearance issues.
ill86 (04-16-2013)
Old 04-12-2013, 06:59 PM   #1185
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
I always considered flush to be a perfect fitment.
I'm currently running 18x8.75 +33 all round. Some would consider this an 'OK' fitment, however there is too much poke up front.
This time, the goal is 'perfect flushness', not just an OK fitment.
white_knight is offline   Reply With Quote
Old 04-13-2013, 11:41 AM   #1186
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Gram Lights 57dr (18x9.5 +40 should fit all around on stock suspension correct?
Lee358 is offline   Reply With Quote
Old 04-13-2013, 10:22 PM   #1187
rmz290
Drives: 2013 Scion FR-S, 2010 Toyota Tacoma
What about OZ 18x9's with an offset of 51 on stock suspension? I'm guessing I would have to use a 10 mm spacer? Is this safe? These would be mainly for autocross and some trackdays. Tried searching but couldn't find much information.
rmz290 is offline   Reply With Quote
Old 04-13-2013, 10:24 PM   #1188
t00n3wb
t00n3wb's Avatar
Drives: 2013 Hot Lava Scion FR-S
Im looking at Varrstoen Es 2 18'' would this fitment be a nice fit?
Front: 18x8 +30
Rear: 18x8.5 +31
t00n3wb is offline   Reply With Quote
Old 04-14-2013, 11:35 PM   #1189
Lee358
Lee358's Avatar
They'll fit the wheelwells but the tires are too tall. Stick to a 245/35 or if not available, go down in width.
Check the diameter and revs/mile for the tire brand you are looking at versus the OEM at 24.7" and 844. Anything above 825 revs will get you pretty damn close to OEM size. Tirerack is a good resource for this info.
My Conti 245/35s (revs/mile 838) are less than half a km per hr difference at 100km/h, so virtually no difference at all.
http://www.tirerack.com/tires/tires....odClar=Limited
thats a good tire correct? it will be going on a 18x8.5 +35
or would this be better?
http://www.tirerack.com/tires/tires....11XL&tab=Specs
Old 04-15-2013, 01:38 PM   #1190
Slick
Slick's Avatar
The 225/40 will be closer to stock gearing. Good size tire for that rim and a really good price for RE-11s'. Sticky....
ill86 (04-16-2013)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
