Old 04-12-2013, 12:50 AM   #57
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by OICU812 View Post
I'd go only 255s but that's just me. I like the wheels edge more "in" like jives. Wheels edge outside the car to me at least just doesent look right at all. I also realize personal preference. I wish also these wheels had some concave in the 8.5 inch width selection but it appears they do not?
unless you can get the 8.5's in a lower offset i dont think they are the concave face.
255 i prefereance, some 255 run wide so you'll be more then fine.
Originally Posted by humanshield View Post
i'm diggin the new shots man!
thanks!
Originally Posted by djdnz View Post
They are only concave in 9.5" width unfortunately
seems to be so...
Originally Posted by LSxJunkie View Post
ZOMG WTF IRS?!? I never dun did that before. Newfangled Jap shit.
only in 04 right? my buddy has an SGT and when he told me he couldn't add camber to the rear i almost choked on my coffee.
_DSC3120 by Ivan Tuk, on Flickr
Jive Turkey is offline   Reply With Quote
Old 04-14-2013, 11:15 PM   #58
Jive Turkey
the tuna, no crust.
went back to the airport to do a video. thats coming soon. meanwhile some updated photos, and much needed interior shot.
alignment/corner balance tuesday.
Old 04-15-2013, 07:38 AM   #59
Jive Turkey
the tuna, no crust.
Originally Posted by s2d4 View Post
What did you do with the climate control surrounds as well as the radio/dash trim?
wrapped in 1/4inch foam and alcantara.
Originally Posted by Alfalasy View Post
I have the same question, how the car feels and handles
the car feels great. i was at autocross yesterday and i ran pretty good times, faster than some cars that i shouldn't be keeping up with at all. it does like to push a bit though, so i think i'll need front bar. it does feel a tad slower in 1st and 2nd because of the added weight but it isn't anything crazy. its still very peppy. even though it does have 265's i can still rotate the car just fine.
The Following User Says Thank You to Jive Turkey For This Useful Post:
Alfalasy (05-07-2013)
Old 04-17-2013, 09:03 AM   #60
Jive Turkey
the tuna, no crust.
update.
once we set hte camber in the rear to -2, we were limited and couldn't adjust the to and it was toe OUT by about 5/8'th of an inch. i ordered whiteline adjustable toe arms so until then i cna't attest to how it drives, feel etc etc.
however we also did a few bushings and inserts to stiffen the car up. updates will probably be in a few weeks as i wont be around.
Old 04-17-2013, 03:15 PM   #61
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Originally Posted by Jive Turkey View Post
if you read what i wrote i didn't really notice any difference.
but if all you care about is MPG's then you shouldn't be in a brz anyway
Is it not possible to have less than -2* of camber in the rear?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 04-17-2013, 07:15 PM   #62
Jive Turkey
the tuna, no crust.
not with this setup. go to a higher offset + whiteline bushings. -2 really isn't a lot.
Old 04-18-2013, 09:46 AM   #63
Jive Turkey
the tuna, no crust.
Do you advice to use the same wheel but 19" instead of 18"
its really the same thing, you just have to compensate in either tire size, or how low you will go. the rest should be the same.
Old 04-18-2013, 11:39 AM   #64
Raceseng
Raceseng's Avatar
Gramlights 57 Extreme
Just put the Gramlights 57 Extreme 18 x 9.5 +40 offset on our FRS. We're really happy with the way them.
Raceseng is offline   Reply With Quote
The Following 5 Users Say Thank You to Raceseng For This Useful Post:
AbsolutKev86 (04-19-2013), Chewie4299 (04-19-2013), FRSWiLLY (04-19-2013), PRORICAN (04-19-2013), SkAsphalt (04-18-2013)
Old 04-20-2013, 08:24 AM   #65
Raceseng
Raceseng's Avatar
I got the wheels from Adam at No Limit Motorsports, he was great to deal with and took the time to answer all my questions. I would buy and deal with them again in a heartbeat!
The tires are 255/35 Toyo Proxes R888, with NO rubbing. I went full lock in either direction and it was fine. I'm dropping the front and back of the car more today, I will let you know if I notice any rubbing.
I'm running Cusco coil overs and originally used the SPC rear lower control arms... I would never buy them again. Both of them broke while on the alignment rack trying to adjust rear camber. I plan on designing and manufacturing our own rear lower control arms but in the meantime I got the Agency Power arms. I also have SPC adjustable toe arms, I was not able to get as much rear toe as I needed with the stock rear toe arms.
The car is going to get aligned again today and I will share the specs I align it to.
The Following 2 Users Say Thank You to Raceseng For This Useful Post:
OjiGeorge (04-23-2013), tranat (04-29-2015)
Old 04-20-2013, 08:26 AM   #66
Raceseng
Raceseng's Avatar
Originally Posted by AbsolutKev86 View Post
Mr Seng,
What brakes are those?
The brakes are from Neo Motorsports. 330mm front rotor with a 6 pot caliper and 300mm rear rotor with a 4 pot caliper.
My first choice was Brembo for AP Racing, both out of stock when I was building!
The Following User Says Thank You to Raceseng For This Useful Post:
AbsolutKev86 (04-20-2013)
Old 04-20-2013, 08:28 AM   #67
Raceseng
Raceseng's Avatar
Originally Posted by No Limit Motorsport View Post
Looks great guys!!!
PM me about that center cap...
I would be willing to custom manufacture these center caps if we had enough interest! I will send you a PM
Old 04-20-2013, 08:29 AM   #68
Raceseng
Raceseng's Avatar
Originally Posted by #87 View Post
Wheels straight 3/4 photo?
Nice car
I will get some more shots tomorrow at the Tri State Tuners meet. The only thing I don't like about the wheels is the front has a little too much poke for my liking. I have Seibon wide body front fenders on order which will help eliminate the poke a bit.
Old 04-22-2013, 12:10 PM   #69
Jive Turkey
the tuna, no crust.
had some fun sunday, proof that you can look good and be functional.
whataboutbob (04-24-2013)
Old 04-23-2013, 09:53 AM   #70
congiiee
Drives: WRB Subaru BRZ
Switch the lights to the parking light mode and it will turn on the boomerangs. When the parking brake is off the DRL's should turn on as well.
Jive any rubbing while doing the hard cornering at the autox?
Doing that turns on the boomerang but it also turns on the side marker lights and taillights. I just want the boomerang and DRL to be one. According to the photos, Turkey is able to just have the boomerangs on with the DRL.
congiiee is offline   Reply With Quote
gramlights 57xtreme, toyo tyres
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 L8Apex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 71 08-05-2023 09:20 PM
Wheel Directory: Gram Light 57Xtreme: 18x8.5 +33 / 18x9.5 +40 jadewbj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 378 06-26-2017 05:57 AM
Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 12-04-2014 10:56 PM
Wheel Directory: Gram Lights 57Xtreme 17x7.0 +42 MVJ1975 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 10-05-2013 02:29 AM
Wheel Directory: Gram Lights 57Xtreme 18x7.5 +40 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-05-2012 12:44 PM
