| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#57 | ||
the tuna, no crust.
Drives: 2014 Hachiroku of the year
255 i prefereance, some 255 run wide so you'll be more then fine. thanks! seems to be so... Quote:
![]() _DSC3120 by Ivan Tuk, on Flickr Last edited by Jive Turkey; 04-14-2013 at 11:16 PM. |
#58 |
the tuna, no crust.
went back to the airport to do a video. thats coming soon. meanwhile some updated photos, and much needed interior shot.
![]() ![]() ![]() ![]() ![]() alignment/corner balance tuesday. Last edited by Jive Turkey; 04-15-2013 at 11:55 AM. |
#59 | |
the tuna, no crust.
the car feels great. i was at autocross yesterday and i ran pretty good times, faster than some cars that i shouldn't be keeping up with at all. it does like to push a bit though, so i think i'll need front bar. it does feel a tad slower in 1st and 2nd because of the added weight but it isn't anything crazy. its still very peppy. even though it does have 265's i can still rotate the car just fine. |
| The Following User Says Thank You to Jive Turkey For This Useful Post: | Alfalasy (05-07-2013) |
#60 |
the tuna, no crust.
update.
once we set hte camber in the rear to -2, we were limited and couldn't adjust the to and it was toe OUT by about 5/8'th of an inch. i ordered whiteline adjustable toe arms so until then i cna't attest to how it drives, feel etc etc. however we also did a few bushings and inserts to stiffen the car up. updates will probably be in a few weeks as i wont be around. |
#61 |
Drives: 2003 Subaru Outback
Is it not possible to have less than -2* of camber in the rear?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
#62 |
the tuna, no crust.
not with this setup. go to a higher offset + whiteline bushings. -2 really isn't a lot.
#63 |
the tuna, no crust.
#64 |
Gramlights 57 Extreme
Just put the Gramlights 57 Extreme 18 x 9.5 +40 offset on our FRS. We're really happy with the way them.
| The Following 5 Users Say Thank You to Raceseng For This Useful Post: | AbsolutKev86 (04-19-2013), Chewie4299 (04-19-2013), FRSWiLLY (04-19-2013), PRORICAN (04-19-2013), SkAsphalt (04-18-2013) |
#65 |
I got the wheels from Adam at No Limit Motorsports, he was great to deal with and took the time to answer all my questions. I would buy and deal with them again in a heartbeat!
The tires are 255/35 Toyo Proxes R888, with NO rubbing. I went full lock in either direction and it was fine. I'm dropping the front and back of the car more today, I will let you know if I notice any rubbing. I'm running Cusco coil overs and originally used the SPC rear lower control arms... I would never buy them again. Both of them broke while on the alignment rack trying to adjust rear camber. I plan on designing and manufacturing our own rear lower control arms but in the meantime I got the Agency Power arms. I also have SPC adjustable toe arms, I was not able to get as much rear toe as I needed with the stock rear toe arms. The car is going to get aligned again today and I will share the specs I align it to. |
#66 |
| The Following User Says Thank You to Raceseng For This Useful Post: | AbsolutKev86 (04-20-2013) |
#67 |
#68 |
I will get some more shots tomorrow at the Tri State Tuners meet. The only thing I don't like about the wheels is the front has a little too much poke for my liking. I have Seibon wide body front fenders on order which will help eliminate the poke a bit.
#69 |
the tuna, no crust.
had some fun sunday, proof that you can look good and be functional.
| The Following User Says Thank You to Jive Turkey For This Useful Post: | whataboutbob (04-24-2013) |
#70 |
Drives: WRB Subaru BRZ
Doing that turns on the boomerang but it also turns on the side marker lights and taillights. I just want the boomerang and DRL to be one. According to the photos, Turkey is able to just have the boomerangs on with the DRL.
| Tags |
| gramlights 57xtreme, toyo tyres |
| Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 | L8Apex | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 71 | 08-05-2023 09:20 PM |
| Wheel Directory: Gram Light 57Xtreme: 18x8.5 +33 / 18x9.5 +40 | jadewbj | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 378 | 06-26-2017 05:57 AM |
| Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 12-04-2014 10:56 PM |
| Wheel Directory: Gram Lights 57Xtreme 17x7.0 +42 | MVJ1975 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 10-05-2013 02:29 AM |
| Wheel Directory: Gram Lights 57Xtreme 18x7.5 +40 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 09-05-2012 12:44 PM |
