Old 04-11-2013, 12:14 PM   #43
Hanakuso
Originally Posted by Cadenz View Post
You guys think Subaru would hassle me much on potential warranty issues if I were to get a TRD branded intake, or treat it as factory compliant like on an FR-S?
If they really want to hassle you then yes it could give you potential warranty issues.
CARB wouldn't be legal as well since i'm guessing TRD only applied for this intake on the FRS. Although I have doubts any cop would give you crap, the cops that do know the twins are essentially the same car would probably think it's cool.
Hanakuso is offline   Reply With Quote
Old 04-11-2013, 12:57 PM   #44
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Originally Posted by Mars2 View Post
what is the length and width of the filter to calculate area and compare to the OEM one.
Got the mesurement on the other thread of TRD filter so if not wrong with my math it's about 58-59% increase fllter area compare to OEM. Not bad!
Would like to know what is the length and diameter of Perrin filter to calculate area of it (Length x Diameter x 3.1416...)
Mars2 is offline   Reply With Quote
The Following User Says Thank You to Mars2 For This Useful Post:
tripjammer (04-11-2013)
Old 04-11-2013, 02:07 PM   #45
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
I wish they'd make the air box so big that I could use the AC filters for my house in it
Jeff86 is offline   Reply With Quote
The Following User Says Thank You to Jeff86 For This Useful Post:
Old 04-11-2013, 02:30 PM   #46
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
shu5892001 is offline   Reply With Quote
Old 04-11-2013, 03:17 PM   #47
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
LMAO!
tripjammer is offline   Reply With Quote
Old 04-11-2013, 03:25 PM   #48
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
I still can't believe there are no Air Straighteners here. Especially near the MAF like the factory box. Seems like they cut some corners and rushed this box into production.
Spartan65 is offline   Reply With Quote
Old 04-11-2013, 03:29 PM   #49
Red2Liter
Drives: Subaru BRZ Limited, Red
OK, We installed the TRD CAI on the BRZ this AM. The instructions and parts were all quality and the install required about 25 minutes. Some hardware from the OEM CAI were used in the install. The original MAF sensor is simply moved to the new airbox. If you look at your engines I believe the covers say both Toyota and Subaru; I doubt that you will encounter any crap from your dealer on warrenty issues
Note: this was included in the instructions___
" If your state requires an Emissions Complianc Label, one may be ordered through your Scion dealer or the Toyota Materials Distribution Center (MDC) 310-468-9800 or MDC@toyota.com"
Also: "This TRD Performance Air Intake Kit has received 50-State Emmisions Compliance via the California Air Resources Board (CARB). Not all states require the Emission Compliance Label for this TRD Performance Air Intake Kit, please order MDC part number 00602-21140. Proof of ownership may be required."
Next up---I do not have access to a dyno. I am 71 years-old and have been an SCCA licensed driver as well having driven a variety of performance machinery my whole life. It's my opinion that the TRD CAI has dramatically improved the low-end torque. When I roll on the throttle I'm getting a nice seamless torque response throughout the RPM range, where the OEM setup was peaky at best. All of the OEM system is removed except the last little bit of the sound tube, which is blocked off with a cap. The cabin is slightly less noisy, I can now hear the injectors clicking (a common Subaru trait). The engine now sounds like an engine; lovely, smooth mechanical sounds instead of that "artifical sound-tube." There is no "magic" bullet to increase horsepower without spending cubic dollars. Subaru and Toyota have equipped these cars with technology that was common only to real racing cars not so many years ago. My goal has been to enhance my BRZ with practical additions that increase my driving pleasure and enjoyment. The only other items I've added were a master cylinder brace and braided stainless brakelines. These enhancements have produced a much firmer pedal that reminds of race cars I've driven. Now I'm going to enjoy driving the car and "learning" to get the most out of it with what skills I still have.
Red2Liter is offline   Reply With Quote
The Following 7 Users Say Thank You to Red2Liter For This Useful Post:
Craig (04-15-2013), Fly Guy (04-13-2013), i_giado (04-12-2013), normancw (04-11-2013), re-animator (08-11-2017), tmcmullins (04-28-2013), tripjammer (04-25-2013)
Old 04-11-2013, 03:36 PM   #50
Red2Liter
TRD CAI
The TRD tube comes right off the CAI and has a straight path to the throttle body with no resonators creating pulses and no curved tubes.
The Following User Says Thank You to Red2Liter For This Useful Post:
Old 04-11-2013, 03:37 PM   #51
Red2Liter
OK, We installed the TRD CAI on the BRZ this AM. The instructions and parts were all quality and the install required about 25 minutes. Some hardware from the OEM CAI were used in the install. The original MAF sensor is simply moved to the new airbox. If you look at your engines I believe the covers say both Toyota and Subaru; I doubt that you will encounter any crap from your dealer on warranty issues
Also: "This TRD Performance Air Intake Kit has recieved 50-State Emmisions Compliance via the California Air Resources Board (CARB). Not all states require the Emission Compliance Label for this TRD Performance Air Intake Kit, please order MDC part number 00602-21140. Proof of ownership may be required."
acro (04-12-2013), bdub85 (04-11-2013), Chewie4299 (04-15-2013), Jeff86 (04-11-2013), NickFRS (04-11-2013), sid325 (04-11-2013), tripjammer (04-11-2013)
Old 04-11-2013, 03:43 PM   #52
2forme
The stock box has no curves before the MAF either. The straighteners were used to help the MAF reading. Anything after the MAF is irrelevant unless its super restrictive.
Old 04-11-2013, 03:51 PM   #53
shu5892001
Ontario's FT86
Good to hear!
Old 04-11-2013, 03:55 PM   #54
OrbitalEllipses
Drives: Attitude
You sure it's not your brittle bones becoming more sensitive to gravity?
usptwins (04-11-2013)
Old 04-11-2013, 04:12 PM   #55
Red2Liter
Brittle Bones
Could be, I've been around long enough to know I shouldn't rule anything out. Before you all scoff; when asked to what he attributed his driving success, Mario Andretti pointed to his butt and said, "it's all right here."
The Following 4 Users Say Thank You to Red2Liter For This Useful Post:
CB762 (04-02-2016), Chewie4299 (04-15-2013), NickFRS (04-11-2013), tripjammer (04-11-2013)
Old 04-11-2013, 04:47 PM   #56
tripjammer
tripjammer's Avatar
Red2Liter, you almost got me sold!
If i get one in time, I will be able to dyno it on the 20th....
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
