Old 03-27-2013, 12:33 AM   #99
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Just the pass through socket will be fine, you dont need to get both.
Fizz is offline   Reply With Quote
Old 03-27-2013, 01:41 AM   #100
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
You can't torque down to spec with just the pass-thru socket/ratchet.
Phaedrus29 is offline   Reply With Quote
Old 03-27-2013, 03:56 AM   #101
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yes that's true, but i think using the crowfoot to torque would not be very precise anyway. The centreline of the torque wrench's head is not directly above the centreline of the nut, so you'll have slightly more leverage, which means the nut still isnt getting torqued to spec. But i guess using that is still better than nothing....?
Old 03-30-2013, 02:58 AM   #102
marioj
Drives: Scion FR-S
Thanks for this. I'm doing the Eibach sportlines, and the pics were pretty helpful.
marioj is offline   Reply With Quote
Old 04-03-2013, 02:33 PM   #103
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
Thanks for posting this, I did it!!! jut like Dora the Explore we did it, we dit it!!!!
kombatlion is offline   Reply With Quote
Old 04-06-2013, 02:14 AM   #104
Nezz
86DESU
Nezz's Avatar
Drives: 86 GTS, S13, CB9
Originally Posted by brz7400 View Post
Thanks for the detailed DIY!
Last time I changed springs was on a 98 Honda Prelude, and it seems like the BRZ/FRS setup looks slightly more straight forward without all the pushing down on suspension arms to get things out/in, lol.
Will come back to this very useful thread for reference, when I am ready to upgrade from stock
Man, it's really strange how many guides advocate reefing on suspension components on Accords and Preludes when you can spend five more minutes, undo three more bolts and not have to put major pressure on anything.
Careful. It's contagious!
Nezz is offline   Reply With Quote
Old 04-06-2013, 08:42 AM   #105
jwjknorr
Drives: FRS 2013
For those who think they may have messed up a strut during install because you did not use a Allen wrench , there is hope. if you re tighten the bolts the right way with a open ended ratchet and allen key , it may just not of tighten all the way down due to spinning. Of course it could of been over spun. I had 2 struts i though i spun, decided to tighten anyway because i did not want to spend more money on new struts yet, and it fixed my rattling and bouncy ride. Just food for thought.
jwjknorr is offline   Reply With Quote
Old 04-06-2013, 06:30 PM   #106
jesperswe
Drives: GT86
I installed my Pro-Kit today using this guide, but i did not feel comfortable using the air gun for disassembly/assembly of the shocks
Used a vice grip around a deep socket and a allen key, worked fine for both removal and install of the topnut.
Now i have a "poping" sound coming from the rear though when going over bumps. And i did hear a spring tension "fjoooing" coming from the right front when i parked my car after some driving. Maybe i tightened something to much?! Going over all the nuts tomorrow just to make sure everything seems allright
EDIT: Did a check on all the nuts and bolt so they were nice and tight. And i realized i snapped 1 of the 3 bolts (top-nuts) holding the damper to the chassis in the engine bay!!!
jesperswe is offline   Reply With Quote
Old 04-07-2013, 11:33 PM   #107
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
whoa...u snapped a bolt? do u have biceps like he-man?
Old 04-08-2013, 11:55 AM   #108
jesperswe
Drives: GT86
Haha well the torque wrench snapped it
Old 04-08-2013, 02:08 PM   #109
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
I used the impact gun technique to separate my rear struts yesterday and I appear to have blown both of them. Making all sort of crazy clunking and rattling sounds now. I used an open ended ratchet (from sears) and an allen key on the fronts and they appear to be fine.
Looks like I'll be headed to the dealership to get 2 new struts.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 04-08-2013, 02:52 PM   #110
jesperswe
Drives: GT86
Did you reinstall the rear struts with the impact gun also? Or just to disassemble?
Old 04-08-2013, 04:52 PM   #111
f0rge
I just disassembled them with the impact gun, when I put them back together I used the open ended socket and allen wrench.
I read your post above but it confused me. If you have a way to fix the struts I'm all ears.
Old 04-10-2013, 10:36 PM   #112
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
i just installed the pro kit on the front. i had to use the impact to get the top nut off (i wasn't strong enough to do it by hand) but i assembled everything by hand. how can i tell if i blew my shocks?
Bones36 is offline   Reply With Quote
Replacing the Scion FR-S seats bloomy116 Scion FR-S / Toyota 86 GT86 General Forum 36 11-09-2012 12:41 PM
Installing TRD Parts / Locating a good shop Re~Mix Engine, Exhaust, Transmission 9 06-12-2012 12:05 PM
T1R Coil-over suspension AJ PwR Brakes, Suspension, Chassis 33 05-29-2012 10:07 PM
Handling: Camber Attainable with Struts. Your Experiences? skeeler Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-09-2011 04:07 PM
