| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 | |
Drives: t
So I suggest EVERYONE to do THIS! A ROCK hit and damaged my condenser already.. |
#16 |
Drives: 2019 Mazda Miata RF
When mounted, the fender washers appear to be 1/4 to 3/8 from the back of the mesh, is that the case? and if so, does the grill float fore/aft?
#17 |
Drives: 1995 Acura Integra GS-R
Yes, I suppose I could get a spacer of some sort to keep it tight - probably can stack 2 or 3 fat rubber washers, but the grill does not move due to the curvature it needs to sit at along with those other 2 protruding pieces of plastic nearby which do a good job of keeping it in place.
#19 |
#20 | ||
![]() Quote:
Notice engine temps being any higher? |
#21 |
Oh good point. Not at all! My hypothesis should now be an accepted theory.
Another cool thing is, when I first did this mod, there were a bunch of leaves and debris when I took the bottom plates off. This time there were none! Though leaves getting caught between grille and bumper made it look like it had stuff stuck in 'teeth' when it was silver. |
#22 | |
This one is on my to-do list for the BRZ. Thanks for the info. |
#23 |
Drives: SWP BRZ
I've done similar to this to my old RSX. it does its job for preventing rocks hitting condensor. I might do this on my BRZ but not planning anything yet
#24 |
Drives: BRZ DGM Limited
Looks good...would like to see it black and mounted on the outside. Anyone do that?
#25 |
#27 |
Power Ranger Elite
Drives: '13 WRB Sport-tech
To add to the this thread, heres my installation photos.
Removing the bumper was surprisingly straightforward thanks to all the removal threads all over the forums. I used some leftover Honda panel clips I had laying around instead of bolts. They were very very snug so I didn't bother gluing them down or anything. Black zip ties were used at each vertical bar top and bottom for added support. If you weren't looking for the ties you wouldn't notice them. Didn't bother wrapping the edges with molding/tubing as dirt and salt would just collect in it and form rust. I didn't trim it because theres nothing back there for it to catch. I sprayed it black, but i can already see the paint chipping away over time. I'll keep my eye out for a grill made of black metal for the future and switch it out. For now, this is perfect for what I want it for and would recommend it to anyone. It really completes the car. P.S. The gutter guards that OP and I used can be found at Lowes.
| The Following User Says Thank You to jimmillion For This Useful Post: | xn7485 (06-13-2015) |
#28 | |
Drives: GTS 86 auto
| BRZ front grille mod | bloomy116 | Cosmetic Modification (Interior/Exterior/Lighting) | 255 | 06-13-2021 08:58 PM |
| FR-S Front Grille Options | Borgore | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 11-14-2012 04:03 PM |
| Pics without front bumper grille? | Synack | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 13 | 10-23-2012 12:18 AM |
| TSB "S-SB-0019-12" Speaker Grille Appearance 8/28/12 FR-S | xravexboix | Issues | Warranty | Recalls / TSB | 7 | 10-02-2012 10:38 AM |
| Fog Lights in the grille... looks kinda cool | Moshpit37 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 5 | 08-05-2012 02:40 PM |
