Old 09-03-2012, 08:19 PM   #1
xravexboix
xravexboix's Avatar
Drives: 12 Camry Hybrid on 19" RE30
Send a message via AIM to xravexboix
TSB "S-SB-0019-12" Speaker Grille Appearance 8/28/12 FR-S
Production Change: JF1ZNAA1#D1704676 (so if it's after this VIN, your car should be good)
What's done: It basically calls for the tweeter's wiring to be 'rearranged' and if that doesn't work, the grille is replaced with a new one (same part number, so it's not an updated part) and then the wire is 'rearranged' again. So it might require parts, but will not in most cases. Just a simple wire.
Attached
xravexboix is offline   Reply With Quote
The Following 7 Users Say Thank You to xravexboix For This Useful Post:
BRZranger (10-02-2012), GMT (10-01-2012), Guff (09-03-2012), Laika (09-03-2012), Sigh-on-Rice (09-03-2012), Sovran (10-01-2012), Xanatos (10-02-2012)
Old 09-03-2012, 08:54 PM   #2
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Thanks for posting. I can't believe they just now released this...I picked my car up with this issue back on June 2nd.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 09-03-2012, 09:18 PM   #3
mashal
DADA
mashal's Avatar
Drives: 2013
So what was the problem? Your picture doesn't show
mashal is offline   Reply With Quote
Old 09-03-2012, 09:33 PM   #4
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Thanks for posting.
Sigh-on-Rice is offline   Reply With Quote
Old 09-04-2012, 06:29 PM   #5
xravexboix
xravexboix's Avatar
Some of the speaker grilles in the dash are not flush as they should be due to the speaker wire cable being in the way. The fix is to move the cable and reinstall the cover. If the cover is 'broken', a replacement cover is ordered in. The part number is the same- no changes there.
Old 09-04-2012, 06:43 PM   #6
White64Goat
Does this effect he FR-S only?
Old 10-01-2012, 03:59 PM   #7
xravexboix
xravexboix's Avatar
Should technically be both vehicles, but it's up to Subbie to issue a TSB if it's something they find to be abnormal. Toyota issued it because customers are complaining about it and they want to alleviate the issue with a tech fix- especially since it's so simple.
Old 10-02-2012, 10:38 AM   #8
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
It's just simple relocating wiring.
if my dealer is like 50 miles away, i would rather do it myself.
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) — General Topics 59 12-01-2013 12:28 AM
>>> MOTEGI WHEELS 17"/18" - INCLUDING MR121/MR125 ROTARY FORGED @ 17 LBS/19 LBS BestWheelDeals Wheels and Tires 2 09-07-2012 09:26 PM
FS: 3/4" PVC Speaker Spacers/Adapters for the BRZ/FR-S phenryiv1 Audio/Visual, Electronics, Infotainment, NAV 1 08-22-2012 05:03 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
