Old 03-20-2013, 08:24 PM   #15
choi0706
Drives: t
Originally Posted by xn7485 View Post
Woah, didnt check this thread after I made it, sorry for delayed response but better late than never!
I gotta say I don't really like having the car with the shiny grille either, I plan on painting it black once it gets warmer.
As for airflow, having anything in front of the condenser/radiator would restrict airflow. Personally I do not believe this mod to be bad, though I do not have any evidence backing my claim up.
A Subaru mechanic also pointed out to me that this opening was one of his concerns, especially with the car sitting low, that a flying rock may damage the aluminum condenser as it was.
Only one I got
ProjectD actually PM'd me about this too, it took just one segment of the precut pieces at home depot. I just had to trim off about 4 inches on the length. I have the photo of the label of the exact one I got in OP.
So I suggest EVERYONE to do THIS!
A ROCK hit and damaged my condenser already..
choi0706 is offline   Reply With Quote
Old 03-26-2013, 09:17 PM   #16
Gunman
Drives: 2019 Mazda Miata RF
When mounted, the fender washers appear to be 1/4 to 3/8 from the back of the mesh, is that the case? and if so, does the grill float fore/aft?
Old 03-27-2013, 11:36 AM   #17
xn7485
Drives: 1995 Acura Integra GS-R
Yes, I suppose I could get a spacer of some sort to keep it tight - probably can stack 2 or 3 fat rubber washers, but the grill does not move due to the curvature it needs to sit at along with those other 2 protruding pieces of plastic nearby which do a good job of keeping it in place.
xn7485 is offline   Reply With Quote
Old 03-27-2013, 12:19 PM   #18
Gunman
Thanks. Could see about a zip tie, or safety wire in the middle too.
Old 03-27-2013, 12:57 PM   #19
xn7485
Always room for improvement! There's a reason why I'm not being paid as an engineer lol.
Anyways, new pictures with black grille updated in OP.
Old 03-27-2013, 01:00 PM   #20
Gunman
haha, and the reason I am, and the reason I over analyze all this stuff
Nice.
Notice engine temps being any higher?
Old 03-27-2013, 01:04 PM   #21
xn7485
Oh good point. Not at all! My hypothesis should now be an accepted theory.
Another cool thing is, when I first did this mod, there were a bunch of leaves and debris when I took the bottom plates off. This time there were none! Though leaves getting caught between grille and bumper made it look like it had stuff stuck in 'teeth' when it was silver.
Old 03-27-2013, 04:32 PM   #22
Gunman
fwiw you're "cooling drag" should be lower too. We use a similar screen on the Vipers this year, and it's so much easier to get debris off during a pit stop vs. getting it out of the radiator inlet.
This one is on my to-do list for the BRZ. Thanks for the info.
Old 03-29-2013, 01:56 PM   #23
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I've done similar to this to my old RSX. it does its job for preventing rocks hitting condensor. I might do this on my BRZ but not planning anything yet
Old 04-10-2013, 07:03 AM   #24
BRZnut
Drives: BRZ DGM Limited
Looks good...would like to see it black and mounted on the outside. Anyone do that?
Old 04-10-2013, 12:49 PM   #25
Gunman
check the DIY section on the other subaru brz forum dot com (not sure if rules allow me to link)
Old 04-27-2013, 09:37 PM   #26
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
Nice!! Thanks a lot! I gotta do this asap.
Marcoscrdo is offline   Reply With Quote
Old 09-02-2013, 09:45 PM   #27
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
To add to the this thread, heres my installation photos.
Removing the bumper was surprisingly straightforward thanks to all the removal threads all over the forums.
I used some leftover Honda panel clips I had laying around instead of bolts. They were very very snug so I didn't bother gluing them down or anything. Black zip ties were used at each vertical bar top and bottom for added support. If you weren't looking for the ties you wouldn't notice them.
Didn't bother wrapping the edges with molding/tubing as dirt and salt would just collect in it and form rust. I didn't trim it because theres nothing back there for it to catch.
I sprayed it black, but i can already see the paint chipping away over time. I'll keep my eye out for a grill made of black metal for the future and switch it out. For now, this is perfect for what I want it for and would recommend it to anyone. It really completes the car.
P.S. The gutter guards that OP and I used can be found at Lowes.
jimmillion is offline   Reply With Quote
The Following User Says Thank You to jimmillion For This Useful Post:
xn7485 (06-13-2015)
Old 09-25-2013, 04:58 AM   #28
notout86
Drives: GTS 86 auto
Good trade off I would think ..... the reduced airflow of your mod will be offset by lack of bugs and stuff on the radiator
BRZ front grille mod bloomy116 Cosmetic Modification (Interior/Exterior/Lighting) 255 06-13-2021 08:58 PM
FR-S Front Grille Options Borgore Cosmetic Modification (Interior/Exterior/Lighting) 21 11-14-2012 04:03 PM
Pics without front bumper grille? Synack FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 10-23-2012 12:18 AM
TSB "S-SB-0019-12" Speaker Grille Appearance 8/28/12 FR-S xravexboix Issues | Warranty | Recalls / TSB 7 10-02-2012 10:38 AM
Fog Lights in the grille... looks kinda cool Moshpit37 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 08-05-2012 02:40 PM
