go_a_way1
Old 04-09-2013, 10:06 AM   #1149
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by bryzter View Post
What if i'll camber it, will still have issues? thanks again..
There's not enough camber to make up for a +10 offset...
Unless you are leaving off the 25mm spacers.
You haven't stated what width of wheels you are running...
Slick is offline   Reply With Quote
Old 04-09-2013, 07:59 PM   #1150
bryzter
Drives: 2005 BMW 3 series / 2013 Scion FRS
I see. alright thanks Slick..
8.5 rear and 8 on front..
bryzter is offline   Reply With Quote
Old 04-10-2013, 10:04 AM   #1151
Slick
Slick's Avatar
I think you'll be okay with a 35 offset on a 8/8.5" wheel, but keep the spacers off.
Here is pics of mine with 18x9 +35 and they poke slightly, but depending on the viewing angle they look flush.
ProKit springs have been installed and crash bolts on front, but alignment will be done shortly. No rubbing at all so far (4 days since spring installation).
Old 04-10-2013, 11:45 AM   #1152
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
I just picked up some 18x8 +45 TSW Nurburgrings. I Don't know sh*t about tires really, can someone suggest some good low profile tires?
Forum members tend to have the Hankook v12 evo 245/35, and I like the look of low sidewalls (I don't race or auto X).
225/40 18 (Continental DWs or Goodyear Asymmetrical 2)was the size recommended from a tire guy... Help?
322whp/273wtq
Readytoxplod is offline   Reply With Quote
Old 04-10-2013, 12:01 PM   #1153
Slick
Slick's Avatar
I would recommend the Continental Extreme Contact DW in a 245/35R18.
I have them on my 18x9's and they look a bit stretched so they should look good on an 8 inch wheel.
But 225/40's are a good size too, both these are same diameter as stock. The 235/40 from Conti is too tall.
Old 04-11-2013, 12:33 AM   #1154
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
any idea if this will fit?
18x8.5 +35 wheels with 245/40/18 tires
Lee358 is offline   Reply With Quote
Old 04-11-2013, 02:26 AM   #1155
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Fit? Sure will..
ill86 is offline   Reply With Quote
Old 04-11-2013, 03:21 AM   #1156
Overland'n'5thGEN
Overland'n'5thGEN's Avatar
Drives: 5th Gen Toyota 4Runner
Looking at 18x8.5 with +47 offset, square set up with 245/35x18 tires. Looking to eventually get Ohlins coils to bring the car down about an inch. Will I have issues with this set up?
Overland'n'5thGEN is offline   Reply With Quote
Old 04-11-2013, 06:02 AM   #1157
saiyajinimports
Drives: 2013 Scion FRS and 1995 Supra
waiting on these to come in 18x8.5 +48 18x9.5 +48. should be in by May. i hope.
allen castillo
2013 Scion FRS
1995 Toyota Supra
saiyajinimports is offline   Reply With Quote
Old 04-11-2013, 08:24 AM   #1158
Slick
Slick's Avatar
They'll fit the wheelwells but the tires are too tall. Stick to a 245/35 or if not available, go down in width.
Check the diameter and revs/mile for the tire brand you are looking at versus the OEM at 24.7" and 844. Anything above 825 revs will get you pretty damn close to OEM size. Tirerack is a good resource for this info.
My Conti 245/35s (revs/mile 838) are less than half a km per hr difference at 100km/h, so virtually no difference at all.
Old 04-11-2013, 10:43 AM   #1159
Lee358
Lee358's Avatar
So they will throw off my speedometer and mess with my gearing?
Old 04-11-2013, 10:49 AM   #1160
Slick
Slick's Avatar
Yes, what make/model tire are you getting?
Old 04-11-2013, 11:08 AM   #1161
Lee358
Lee358's Avatar
245/40/18 Federal SS595
A guy on here has a set of wheels for sale with those tires on it.
Old 04-11-2013, 11:33 AM   #1162
Slick
Slick's Avatar
That tire is a whole inch taller in diameter than OEM.
So you will lose acceleration due to higher gearing from the tires.
And your actual speed will be 4.3% higher than what is indicated.
Depending on the weight of the wheel/tire combo you may lose additional acceleration from the extra weight. Always keep this in mind when running a plus-size set.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
