Old 04-08-2013, 09:23 PM   #15
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Originally Posted by mad_sb View Post
that mounting location is not practical for a street driven car since you have to remove the impact absorbing foam that mounts on front of the crash beam.
I see so many people park 'braille'.... great idea for track tho!
Huehuecoyotl is offline   Reply With Quote
The Following User Says Thank You to Huehuecoyotl For This Useful Post:
Dimman (04-08-2013)
Old 04-09-2013, 07:25 AM   #16
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Originally Posted by Pure Automotive View Post
Hey guys,
Just thought I'd post up the research we're doing with an oil cooler.
This is something we are testing out to see if it works as an option for an oil cooler. I don't have any concrete datalog numbers yet, we're working with different driving conditions/styles and collecting all the data necessary before posting final numbers.
The Setup:
The car belongs to Typerrspec789, it is a Full Blown Stage 1 Kit, 451 Hp on E85
What will the kit include?
-10AN Lines
-Mocal Oil Sandwich Plate
-10AN Adapters
-12" Heat Sink Style Oil Cooler
-Install Hardware
Why use a heat sink style oil cooler?
-The main reason is space saving. I wanted to make a kit that will work with a turbo setup, without running 5-6 fee of lines across the front of the car.
I'll save you some typing time and say this: Yes I know if you google heat sink oil coolers you will find both good and bad results. A lot of people dismiss them because they can get heat soaked easily and flow faster than a tube and fin type oil cooler. The way the FRS front bumper is designed, air rushes through the front grille while in motion and with the foam bumper support removed will definitely keep air flow across the cooler.
On this car I know it's cheating to have the front bumper cutout, but it was already there for the intake. That being said, even without a hole in the front bumper, you will still have airflow across the cooler because of the design. It can be improved on a stock bumper by adding additional air flow in any way you see fit. (vents, holes, opening up the honeycomb in the upper front grill, etc.)
Again, this is preliminary and if I find that it does not work well enough, and I will be honest about results!
Pics:
Painted it black for aesthetic purposes:
Thanks For Reading!
Could this be mounted next to the pod filter?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 04-09-2013, 07:36 AM   #17
2forme
This might be a stupid question, but what about the bumper itself (the styrofoam)?
Old 04-09-2013, 08:05 AM   #18
Huehuecoyotl
you loose it
Old 04-09-2013, 08:10 AM   #19
2forme
-__- and no one sees anything wrong with that? LOL
Old 04-09-2013, 08:25 AM   #20
DJCarbine
Thupercharged
DJCarbine's Avatar
Removing the foam is common practice in many other cars where you mount intercoolers etc.
The foam does NOT provide any sort of impact absorption, it is only a filler and helps prevent cracking of the plastic bumper cover in very low speed "bumps"
DJCarbine is offline   Reply With Quote
Old 04-09-2013, 08:26 AM   #21
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Do you really think that piece of foam does anything? At least we kept the metal part of the bumper, there are some people who think intercoolers are more important than those, lol.
Pure Automotive is offline   Reply With Quote
Old 04-09-2013, 08:28 AM   #22
2forme
No, I don't think it has any function, but insurance companies will look for any excuse not to dole out money in the event something happens....
The Following User Says Thank You to 2forme For This Useful Post:
tech4pdx (04-09-2013)
Old 04-09-2013, 08:31 AM   #23
xjohnx
Grip>Slip
xjohnx's Avatar
What happens if you rear end someone with that oil cooler mounted there? The only thing between the oil cooler, hoses and fittings is the thin plastic facia of your bumper. Seems like the chance of spewing oil in close proximity to your exhaust manifold is a pretty real possibility, or am I missing something?
Old 04-09-2013, 08:35 AM   #24
Pure Automotive
What happens if you rear end someone with a side mounted oil cooler and nothing to protect it but the plastic bumper?
It's all the same, if you're worried about breaking something when you rear end someone, don't rear end someone. Intercoolers, oil coolers, piping, etc, it's all in danger when you are in a collision.
The Following User Says Thank You to Pure Automotive For This Useful Post:
Laika (04-09-2013)
Old 04-09-2013, 08:38 AM   #25
s2d4
s2d4's Avatar
umm, part of eurocap testing involves pedestrian protection at 25mph, that foam actually does something...
The Following User Says Thank You to s2d4 For This Useful Post:
Huehuecoyotl (04-09-2013)
Old 04-09-2013, 08:38 AM   #26
Huehuecoyotl
Really?
I expected better from you 2forme
Foam on my bumper does the same thing as the foam in my helmet
anyone who thinks its not there for a good reason needs to redo college physics. Its what makes the bumper a 5mph bumper
without it, its a zero mph bumper
got that? the foam is VERY functional, it works in conjunction with the bumper supports and beams
The location will not be ideal for anything but a track car. I dont know about other states, maybe its the heat here but folks round here do not know how to park, they will love tap you and then put the car in park. Just hang out at a walmart parking lot for 5 minutes, you see what I mean
removal of the bumper foam also may open you up to liabilities if you hit or hurt someone, so I am careful about anything that affects the designed safety, airbag deployment and impact absorption. I would urge you to recheck if it has any function, I think its function is key
staying on my car
I love the cooler idea, I just want to look at other location, frame rails, behind steering rack etc
Old 04-09-2013, 08:40 AM   #27
Pure Automotive
To me, it looks like it's in there to hold the shape of the front bumper in a collision. Otherwise, its the same foam they pack in electronics boxes.
Old 04-09-2013, 08:41 AM   #28
2forme
Gem, you've apparently never had to deal with insurance companies.
Review of ACT 6 Puck HD Clutch @ Pure Automotive Performance Pure Automotive Engine, Exhaust, Transmission 11 04-02-2013 01:12 AM
TOYOTA EMBLEMS FOR YOUR FRS! @ PURE AUTOMOTIVE PERFORMANCE Pure Automotive Exterior Parts - The Rest 12 02-18-2013 05:36 PM
Review of ACT 6 Puck @ Pure Automotive Performance Pure Automotive Mid-Atlantic 3 01-10-2013 02:06 PM
**Everything Invidia is on SALE!!** @Pure Automotive Performance Pure Automotive Engine, Exhaust, Transmission 0 01-08-2013 02:32 PM
