Old 04-09-2013, 01:59 AM   #1
forzajuve
Drives: Ultramarine 86 - 6MT
Suggestions for more horsepower! Turbocharger upgrade + more!
If someone wanted to get a turbo upgrade for their FRS/BRZ, what other components to the car need to be upgraded in order to cope with 50 to 100/200+ more horsepower?
I understand upgrades need to be made to the engine, plus tune, etc. But specifically I couldn't name them off (cause I am newb)...
So, with your constructive words of advice and suggestions, what turbo build would you guys would go with and what parts would you upgrade in order for your 86 to cope with that new harnessed power!
You are welcome to be general with naming off upgrade parts too! Please include potential total cost $$ if possible. Thanks guys. Hope this helps other people as well.
forzajuve is offline   Reply With Quote
Old 04-09-2013, 02:15 AM   #2
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
no prices, but here is a lot of what you need from when i asked
http://www.ft86club.com/forums/showt...048#post830048
lbroskee is offline   Reply With Quote
The Following User Says Thank You to lbroskee For This Useful Post:
forzajuve (04-09-2013)
Old 04-09-2013, 02:19 AM   #3
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Thats the nice thing with kits that have been popping up, they basically include everything you need like injectors, a tune , a fuel pump and so on. A few things that are necessary in my opinion but some kits state that they are not required would be a clutch, and a lightened flywheel; in addition to that you could also invest in a catback preferably a free flowing one thats 3" and some sticker tires (i wouldn't do that straight away id get a chance to shred the stock ones and then upgrade)
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Old 04-09-2013, 02:27 AM   #4
forzajuve
What if I wanted to run a modest turbo upgrade, like 60-110 whp gain; is that possible on low boost and would it also have less wear on the engine?
Thanks for providing that info with regard to the parts list and the kit which includes everything.
I kind of relate this in smaller terms to building a desktop computer.
Old 04-09-2013, 02:45 AM   #5
lbroskee
lbroskee's Avatar
most of the kits are under 10 PSI. i would def call that modest boost when my friends GTI was i think lik 16 stock (give or take).
as for wear on the engine.... ours are pretty similar to WRX and those things take a lot and still run strong so im sure +100 whp on ours is nothing (if done correctly of course)
Old 04-09-2013, 02:52 AM   #6
forzajuve
Whoa, really? That is good to know that they will react the same way as a WRX.
How much would an 8-10 psi kit go for? Can you go to just a modest 7 or 8?
Old 04-09-2013, 03:03 AM   #7
Turdinator
Señor Member
Turdinator's Avatar
Have a look HERE then check out the for sale section.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
Old 04-09-2013, 03:08 AM   #8
forzajuve
Dude, too good... the AVO so far seems perfect for the moderate bit of power I want to add.
Old 04-09-2013, 03:10 AM   #9
Turdinator
Señor Member
Turdinator's Avatar
There are a lot of user reviews in the forced induction section. Probably worth doing some lurking there for a bit to get a good overall idea of the kits available.
1974 TA22 Celica
2013 86 GT
Old 04-09-2013, 03:24 AM   #10
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
First thing to do is get decent tires. Second thing is get the brakes upgraded.
mswhong (04-09-2013)
Old 04-09-2013, 05:16 AM   #11
mswhong
Drives: FT86
this.
With all that added power, you'll be travelling at greater speeds when compared to stock and the oem brakes won't be able to handle the abuse.
mswhong is offline   Reply With Quote
Old 04-09-2013, 07:37 AM   #12
FR-S Matt
Well, the stock brakes can handle it unless you're driving like a madman. (Which is likely to happen with a turbo) So brakes and tires might be a good option, and a clutch once your upgrades are finished.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Sportsguy83 (04-09-2013)
Old 04-10-2013, 02:32 PM   #13
forzajuve
What if I wanted to wait till my car had like 20,000-30,000 miles on it, THEN I add a turbo. Still worth it?
Old 04-10-2013, 02:56 PM   #14
xjohnx
Grip>Slip
xjohnx's Avatar
probably better to ask this question in the forced induction forum.
Electric Turbocharger Shankenstein Forced Induction 91 06-24-2013 03:47 PM
Michelin/Enkei upgrade + more. Community suggestions welcome! forzajuve Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 03-29-2013 08:14 PM
So what horsepower level are people needing to upgrade the injectors/pump? seven Forced Induction 24 01-02-2013 12:28 AM
Report: BRZ STI Model Already in the Works, No Turbocharger Sport-Tech BRZ First-Gen (2012+) — General Topics 188 08-30-2012 06:53 PM
