Tells it like it is
Drives: SS1LE | F150 Diesel | Civic | S3
So what horsepower level are people needing to upgrade the injectors/pump?
Simple enough question, trying to plan for the future
Thanks
-Seven || youtube.com/turnsevenvideo
![]() 2012 C6 Grand Sport 4LT 2015 Mazda 3i-T/Tech |
If you boost, it's pretty safe to just buy upgraded injectors. I'm gonna be running 700cc injectors on a 400HP+ setup...but that's just what was reccomended by the shop building my kit.
Drives: 2014 Widebody Cosworth FR-S
It is not very likely that you will need to upgrade them if you stay NA, unless you do an E85 tune. If you go with forced induction then you will definitely need to upgrade both.
-Zach |
| The Following User Says Thank You to RallySport Direct For This Useful Post: | Chad86 (07-01-2015) |
#4 | ||
Tells it like it is
So ok, to be more specific... 1- this is the forced induction forum - So assumed forced induction2- I ask because companies like AVO are making 230-250whp on stock injectors and while I like their kit, I know I will want more power shortly after... I'd like to know when I'd need to plan for injectors, so I can budget for the upgrades to happen all together and not have issues. Thanks guys
Well everyone seems to be ok with 550cc injectors for sub 350HP, I think a few have taken them up past 400HP so they work there. I went 700cc to give me more room to go even higher than 400HP once theres a few more options to reduce compression. I may be wrong here but I am under the impression that you can run a higher flow rate injector for lower power figures, it's all about duty cycles etc. So for future proofing I don't think it hurst to go bigger. I'm sure that if i am wrong someone will chime in!
#6 | |
Tells it like it is
![]() Thanks for the help so far... Anyone else have insight on the stock injector limit?
Here check out this thread, on page 16 Visconti suggests that anything over 6PSI of boost should have upgraded injectors, he also says on the same page that 550cc injectors are easier to tune for 400ish HP.
http://www.ft86club.com/forums/showt...jector&page=16 |
| The Following User Says Thank You to Supermassive For This Useful Post: | seven (12-18-2012) |
Drives: 72 240z
Curious as to the specs (snail size, location) you are going with to reach that number (we have similar goals) and what shop in Phoenix have you commissioned for the work? Sorry for the thread jack, don't hang me, my PM system isn't working ATM.
1.)1992 240sx SE A/T bone stock: The Daily
2.)1972 240z SBC355 5spd: Ratrod Project 3.) .....[undecided]....: Weekend Warrior |
#10 | |
Tells it like it is
Thanks sir. I'll take a look thru that thread!
#11 |
Drives: 2013 "AVO Orange" FR-S
In our testing on the car in Japan, we ran out of injector (90% duty cycle) at roughly 280whp on 94 octane gas, 6.5 psi.
| The Following 7 Users Say Thank You to AVOturboworld For This Useful Post: | frsvr4 (12-20-2012), Lawnik (12-19-2012), Pure Automotive (12-18-2012), seven (12-19-2012), Starscream15 (12-20-2012), Supermassive (12-18-2012), swift996 (12-24-2012) |
#12 |
Drives: ZD8
I have STI Pink Injectors lying around, 550cc from memory...might use these if i get the AVO kit
EOJ | PERTH | ZD8
#13 | |
Drives: Nevermorange FRS
My expectation is clearly wrong and it would appear that the fact that the fuel is being squirted by DI or that the HPFP is at a very high PSI isn't as important as the size of the squirter itself (to use unscientific terms). Good to know as I plan on going FI in the future for race trim and will probably be a bit above 6 psi.
PRO86 | WTCC | STL
#14 | |
Tells it like it is
Anyone able to chime in on the pump?
| My oil level was low! | FRSjeff | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 12-15-2012 11:22 PM |
| Deatschwerks Injectors - Released | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 0 | 09-08-2012 04:20 PM |
| Deatschwerks BRZ/FR-S Fuel Injectors! | RallySport Direct | Engine, Exhaust, Bolt-Ons | 2 | 09-07-2012 06:29 PM |
