Old 04-08-2013, 05:16 PM   #1
Osiris
Osiris's Avatar
Drives: Asphalt FR-S
Benefits of a front pipe?
Hey guys! I know the basics of what the front pipe is and what it will do. I am currently running an Invidia N1 system and I'm planning on buying the Invidia front pipe to match. Will I get a sound change? Will it be louder? if so will the tone be deeper? And will I get an increase in HP?
Osiris is offline   Reply With Quote
Old 04-08-2013, 05:18 PM   #2
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
replace both the front and over-pipes, frees up a lot of restriction. if you go cat-less you will definitely be louder (catted will be louder than stock too but less so), not too sure about deeper however.
FreshFRS is offline   Reply With Quote
Old 04-08-2013, 05:21 PM   #3
mrk1
Drives: Sterling BRZ Ltd
I currently am running an over pipe and catless front pipe with the stock cat back. It sounds a bit deeper at idle but once your rolling I don't notice much sound difference at all.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-08-2013, 05:25 PM   #4
Osiris
Osiris's Avatar
What brand over pipe are you running?
Old 04-08-2013, 05:29 PM   #5
DSOmegaX
DSOmegaX's Avatar
Switching out the front pipe will make it louder and increase your power as front pipe and over pipe are the most restrictive section of the exhaust. The stock front pipe alone has a restrictive cat AND a resonator so getting rid of those can significantly change power and sound
@dsomegax.cars
Old 04-08-2013, 05:34 PM   #6
FR-S Matt
Go catted.... Catless sounds like ass and adds rasp to MOST exhausts. Don't go the cheap route and end up with a fartcan. Besides, the difference between catted and catless is negligible and its been proven.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Opposed (04-08-2013)
Old 04-08-2013, 05:45 PM   #7
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Also, if you ever decide to have headers, this will help keep the sound down and smell away. That's one of the reasons I went with the Invidia catted front pipe.
husker741 is offline   Reply With Quote
The Following User Says Thank You to husker741 For This Useful Post:
Old 04-08-2013, 05:57 PM   #8
mrk1
Made it myself, its 2.5" diameter. I previously had an axle back and with that it did make a throatier sound.
The Build Thread
Old 04-08-2013, 05:59 PM   #9
Osiris
Osiris's Avatar
God, I really don't want a fartcan... I just pulled the trigger on the unresonated front pipe. Do you think I will get rasp with JUST the front pipe and the catback system? I don't plan on doing headers or an over pipe any time soon. So hopefully it won't be too raspy or fartcan-esque.
Old 04-08-2013, 06:04 PM   #10
mrk1
Ive had a few arrangements of exhaust and the only one I found annoying in sound was just the axle back muffler delete with everything else stock. I found it just loud and not a very appealing sound.
The front pipe is the ticket to a better sound, then from there the cat back will decide the volume.
The Build Thread
Old 04-08-2013, 06:04 PM   #11
husker741
I think you'll be fine this way.
Osiris (04-08-2013)
Old 04-08-2013, 06:06 PM   #12
Osiris
Osiris's Avatar
Thank you for the reassurance. It's what I needed.
Old 04-08-2013, 06:09 PM   #13
husker741
Here.. http://www.ft86club.com/forums/showthread.php?t=20678
A video of the N1 with the catless front pipe is on their first post if you scroll down a bit.
Old 04-08-2013, 06:13 PM   #14
Osiris
Osiris's Avatar
It seems like it gives the exhaust a little more pop. I like that.
Agency Power Front/Over pipe (Combo pipe) - Cheap! seven Engine, Exhaust, Bolt-Ons 12 03-09-2013 01:40 AM
FA20CLUB Over Pipe Front Pipe & Cold Air Intake Now Ready FA20Club.com Engine, Exhaust, Transmission 171 02-27-2013 09:44 AM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 07:24 PM
Agency Power over-pipe/front pipe combo question... seven Engine, Exhaust, Transmission 11 01-13-2013 12:14 PM
