#29 |
Drives: B9 S4/ND2
#30 | |
Because compromise ®
Drives: Red Herring
From http://www.essexpartsblog.com/news/f...ng-brake-discs |
#31 |
Drives: 2013 FR-S Ultramarine
The Sprint kit does have a through fastener with a bolt on the other side vs a tapped hole in the aluminum. I'm not sure if that makes a difference.
#32 |
Automotive Connoisseur
Drives: too many cars
I am going to throw this out there but does anyone know if this vehicles wheel bearings were 100%? I tried to read the original thread but my work computers for whatever reason will not let me access that S2K forum. Excessive wheel bearing play would certainly transfer a significant amount of lateral force during braking in a corner to the friction disk (although braking should have been completed prior to this stage). This combined with a fixed caliper could have created issues over time at the mounting points. Lets face it, those rotors have seen some use so if excessive deflection had been happening it may have been for some time. If the deflection were bad enough I would guess even a floating friction disk would have failed eventually at the weakest links (The mounting points). You can only TQ metal so many times before it becomes weak.
LSx Powered 86/ASE Master Certified Automotive Technician
#33 | |
#34 | |
Drives: 2013 Scion FRS "Raven"
Do you know how long that rotor was on the car? When was it last inspected? I'm assuming everything was safety wired so the bolts wouldn't back out. I have seen bolts back out and cause cracks in the mount points not saying that is what happened here. Being that I run endurance races I have gotten I to the habit of checking the brakes regularly and this includes removing the rotor from the top hat and I have not had any problem to date other then normal wear of the rotor. Last edited by DAMotorsports; 04-06-2013 at 10:33 AM. |
#35 |
Drives: Perrin/VORTECH Supercharger TestBRZ
Going Endurance myself...
this is SCARY to look at |
#36 |
Hey look one dude had a rotor failure on his race car! That must mean all the other people using that brand are gonna have the same issue, better run for the hills!
This is why the internet is idiotic. Seriously, that rotor looks like it had been run hard for quite a while, you can see the wear had actually left a nice little lip around the hub. Not to mention that the slot wear indicators are flush with the rotor surface. The fact that these are used on a "professionaly" maintained racecar leads me to question just how diligent those inspections were, rotors are a CONSUMABLE resource, just like pads, brake fluid, etc. This failure sucks, but like someone else said, metal can take only so much stress before it fatigues and eventually breaks. The other side of the coin that has yet to be shown is the condition of the other rotors, if they are all worn the same way, but have no stress fractures, then it could be surmised that this was a defective part. Shit happens, I've seen brembo rotors self destruct on bikes before, a name brand doesn't ensure that you will have no issues. Here's some more things to consider, the rotor in that pic is an 8 bolt pattern...probably this exact rotor: ![]() While Wilwood's newer kits, specifically on our car are a 12 bolt pattern like this : ![]() Pretty beefy and a failure like what happened to the S2K would require a tremendous failure or impact to occur with this design. Personally, I think it was negligence on the team maintaining this car, that led to this. I don't race, and I would never drive my car on the street with rotors worn like that. So yeah I may be partial to Wilwood because I have them on my car, but it's not out of fanboyism that I do so. I was going to run the AP kit but I realized that if I was gonna spend that kind of money on brakes I would just get Brembos. Sure AP is nice but I've had Brembos on most of my sport bikes and love their product. The Wilwoods price can't be beat, the kits are way lighter than AP's endurance kit (same rotor diameter as well as 6 pistons instead of 4) and cost $1000 bucks less. So enough ranting, I'll let the internet go back to making wild assumptions about the quality of parts a manufacturer makes based on a picture of broken rotor. |
#37 |
No one here is trying to fearmonger or bash Wilwood. We are simply asking, was this a failure caused by negligence or is there a flaw in the way the Wilwood disk/hat connection is designed, or was this particular rotor just defective?
There are some parts where one catastrophic failure is reason for concern. This is one of them. Brakes are extremely important. There's no reason to get butthurt because people on a forum are discussing a failure that happens to relate to the system you have on your car. Jumping to the conclusion that it was entirely the race team's fault is no better than saying all Wilwood products are junk because of this. Both assign fault without knowing all the facts. Cheers Nathan |
#38 | |
That Guy
Drives: 2013 asphalt FRS MT
#39 | |
That Guy
Again, from what I can see in that picture, I wouldn't contribute that to Wilwood. |
#40 | |
Drives: Sterling BRZ Ltd
Now knowing that you were there and haven't mentioned any contact thats probably off the table. However it still makes my point. More information always helps. |
#41 | |
Drives: Asphalt FR-S
BTW, newer S2000 Willwood kits have 12 bolts. Edit - I've used 8 bolt Willwood hats on my racecar (production calipers, Coleman custom rotors), with ARP hat bolts that were safety wired. I do remember the hats had runout as did some other brand hats I've used and had to be machined true. Yes APs throughbolt w/ jet nuts is nice but you can't always package things that way. And if you think Brembo is the ultimate, they had a rash of rotor failures in some BBK kits for mid 2000's Mustangs.
Asphalt FR-S
1965 Mustang Vintage Road Racer Ducati Paul Smart 1000LE Ducati 848 Last edited by bpracer; 04-08-2013 at 02:05 AM. |
#42 |
Drives: Legacy GT
Why wouldn't you?
That one is modified for the brake cooling duct plus it protects the ball joints and tie rods. Just because the rotors weren't brand new doesn't mean you should expect a catastrophic failure like that. I know a little about that car and it's pretty well maintained and put together. Plus it's n/a and on street tires so there's not even that much stress on the brakes. |
| Trunk release failure - BRZ | Smilez | CANADA | 35 | 07-15-2019 10:15 PM |
| Raven down! Mechanical failure :( | rasec29 | Issues | Warranty | Recalls / TSB | 151 | 10-08-2013 11:25 AM |
| BC Coilover failure in the past | phenom86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 10-25-2012 05:07 PM |
| Ringland Failure? | iLuveKetchup | BRZ First-Gen (2012+) — General Topics | 9 | 01-30-2012 12:25 PM |
| A pessimist's take on sales success / failure | Mess11 | Scion FR-S / Toyota 86 GT86 General Forum | 137 | 11-24-2011 01:10 PM |
