Old 03-28-2013, 11:27 PM   #1
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
Does TRD diffuser work with aftermarket exhausts?
Here is the part in question:
http://new.newscionparts.com/product.php?productid=3386
The website states that the diffuser is only compatible with vehicles equipped with the TRD exhaust. However, I know that certain aftermarket exhausts, as well as muffler deletes, can free up a lot of space. Specifically, I am wondering if this TRD diffuser is compatible with the Berk muffler delete.
Also, what's the installation process on this piece?
Thanks.
sittinSideways is offline   Reply With Quote
Old 03-29-2013, 09:27 AM   #2
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
I have this on my car. It's connected to the TRD muffler itself. I suppose you can make it work with other exhausts by welding some bungs for it. Expecting it to bolt on however, is a no.
Tye300 is offline   Reply With Quote
The Following User Says Thank You to Tye300 For This Useful Post:
sittinSideways (03-29-2013)
Old 03-29-2013, 06:43 PM   #3
sittinSideways
Thanks for the response. How feasible do you think it would be to make it fit with, say, a Berk muffler delete?
The Following User Says Thank You to sittinSideways For This Useful Post:
SkitterSkotter (03-29-2013)
Old 03-29-2013, 10:10 PM   #4
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
This is also what I would like to know. I have the berk single exit muffler delete and this piece would look fantastic to fill the huge gap there is sans muffler.
WAIT! Come to think of it, I bet it would be pretty easy to make some aluminum brackets that attach to the heat shield (held on with 4 decent sized bolts. I bet for $20 it would be possible to make a permanent and strong solution.
SkitterSkotter is offline   Reply With Quote
Old 03-30-2013, 02:45 PM   #5
sittinSideways
Please let me know if you figure out a way to attach the TRD diffuser. Do you think it's skmething a competent fab shop could do for cheap? Also, do you think this diffuser will solve the drag/parachute problem created by removing the stock muffler?
Old 03-30-2013, 11:38 PM   #6
SkitterSkotter
Yes I do think it would solve all of those issues. I will give it a try tomorrow. I honestly think that it would be fairly simple to construct something that not only looks professional but is functional. Honestly, with the FR-S, a front lip and a diffuser should add a slight bit of downforce of not negate the any lift that may be there.
The Following User Says Thank You to SkitterSkotter For This Useful Post:
sittinSideways (03-31-2013)
Old 03-31-2013, 07:14 AM   #7
Tye300
Tye300's Avatar
I guess it could be easy. You just need to weld the brackets for the diffuser to your Berk Muffler, then bolt the diffuser on. The welder just needs to know the exact location so the diffuser would sit in the right place.
Old 04-06-2013, 07:35 PM   #8
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Which TRD exhaust do you have? the Ver R. or do you have the one that looks like a dome on the exhaust tip?
CamryDS is offline   Reply With Quote
Old 04-07-2013, 12:07 PM   #9
Tye300
Tye300's Avatar
Yes I have the VER R.
The Following 2 Users Say Thank You to Tye300 For This Useful Post:
CamryDS (05-07-2013), Subie (04-07-2013)
Old 05-05-2013, 03:42 PM   #10
sittinSideways
Any luck?
Old 05-16-2013, 12:58 AM   #11
TRD8
Drives: Ford Mustang
Think sequoia for a second. They got those long bolts and bushings to attach all sorts of aftermarket plates....leads me to believe that is possible on FRS/BRZ. Will take a closer look when I do another pre delivery.
TRD8 is offline   Reply With Quote
Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts serial gixxer Wheels and Tires 41 03-29-2013 03:14 AM
Exhausts stevo_12v AUSTRALIA 142 03-04-2013 03:00 AM
OEM wheel lock work on aftermarket wheels? #87 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-27-2012 08:00 AM
Aftermarket Exhausts? devinclfalcons Engine, Exhaust, Transmission 309 10-18-2012 02:07 AM
Are 17" wheels too big? Might work 16's work a little better? rogerdalien Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 05-10-2012 10:09 PM
