Drives: '13 Firestorm FRS
Does TRD diffuser work with aftermarket exhausts?
Here is the part in question:
http://new.newscionparts.com/product.php?productid=3386 The website states that the diffuser is only compatible with vehicles equipped with the TRD exhaust. However, I know that certain aftermarket exhausts, as well as muffler deletes, can free up a lot of space. Specifically, I am wondering if this TRD diffuser is compatible with the Berk muffler delete. Also, what's the installation process on this piece? Thanks. |
#2 |
Drives: Toyota 86 TRD Version AT
I have this on my car. It's connected to the TRD muffler itself. I suppose you can make it work with other exhausts by welding some bungs for it. Expecting it to bolt on however, is a no.
#3 |
Thanks for the response. How feasible do you think it would be to make it fit with, say, a Berk muffler delete?
#4 | |
Drives: 2013 Scion FR-S (Hot Lava)
WAIT! Come to think of it, I bet it would be pretty easy to make some aluminum brackets that attach to the heat shield (held on with 4 decent sized bolts. I bet for $20 it would be possible to make a permanent and strong solution. |
#5 | |
#6 |
Yes I do think it would solve all of those issues. I will give it a try tomorrow. I honestly think that it would be fairly simple to construct something that not only looks professional but is functional. Honestly, with the FR-S, a front lip and a diffuser should add a slight bit of downforce of not negate the any lift that may be there.
#7 | |
#8 |
Drives: 2003 Camry Blue | 2013 FR-S White
Which TRD exhaust do you have? the Ver R. or do you have the one that looks like a dome on the exhaust tip?
#9 |
Yes I have the VER R.
#10 | |
#11 |
Drives: Ford Mustang
Think sequoia for a second. They got those long bolts and bushings to attach all sorts of aftermarket plates....leads me to believe that is possible on FRS/BRZ. Will take a closer look when I do another pre delivery.
| Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts | serial gixxer | Wheels and Tires | 41 | 03-29-2013 03:14 AM |
| Exhausts | stevo_12v | AUSTRALIA | 142 | 03-04-2013 03:00 AM |
| OEM wheel lock work on aftermarket wheels? | #87 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-27-2012 08:00 AM |
| Aftermarket Exhausts? | devinclfalcons | Engine, Exhaust, Transmission | 309 | 10-18-2012 02:07 AM |
| Are 17" wheels too big? Might work 16's work a little better? | rogerdalien | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 46 | 05-10-2012 10:09 PM |
