Old 04-03-2013, 05:42 PM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That Visconti pump looks just like my Full Blown pump. There are no barbs on the output like the DW pump.
Sportsguy83 (04-03-2013)
Old 04-03-2013, 08:51 PM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The DW 65 pump includes the electrical connector, so there are no cables to splice BUT I don't see how it drops in.
BUT also, there won't be any true drop in until one is made specifically for our cars. The OEM pump is extremely small when compared to the DW65.
Edit: According to the instructions it does fit. I'm debating if I try it or not because if I do, there is no returning it.....
Old 04-04-2013, 12:41 PM   #17
Dustin@Dynosty
1) It comes with plugs so that it is true plug and play and no cable soldering is necessary;
Answered, it does come with plug and play connector.
2) the instructions show to use the two O-rings and no spacer, is that an error in the instructions, or should the spacer be removed?
Yes removing the spacer and using the two o-rings is what DW recommends, the second o-ring is acting as a spacer to seat the first o-ring in place.
3) It fits completely inside the canister, to the point the clips snap back into place.
You have to separate the clips from the bottom of the filter and fuel pressure regulator and then yes it will clip back in place, we recommend to utilize a large worm gear clamp to ensure that the clips do not pop back up
I have a hard time believing that because it seems all aftermarket FP are longer than the stock one.
Yes all aftermarket options we have seen are longer than stock, but that is the only way to get more flow.
Can anyone whoi has actually installed it in our cars comment/answer the 3 questions?
Done
And just FYI, we are finishing up the last little pieces to our fuel system that will allow you to drop this monster in the tank and not have to worry about double o-rings or running out of fuel
Dustin@Dynosty is offline   Reply With Quote
The Following 4 Users Say Thank You to Dustin@Dynosty For This Useful Post:
akuhei (04-04-2013), Draco_PR23 (04-04-2013), Lawnik (04-05-2013), Sportsguy83 (04-04-2013)
Old 04-04-2013, 12:54 PM   #18
Sportsguy83
Drives: Limited BRZ
Originally Posted by Dustin@Dynosty View Post
[COLOR=Blue]And just FYI, we are finishing up the last little pieces to our fuel system that will allow you to drop this monster in the tank and not have to worry about double o-rings or running out of fuel
Awesome!! Any idea on ETA?
Old 04-04-2013, 01:33 PM   #19
Dustin@Dynosty
If the machine shop stays on target, we will have the production version pieces in middle of next week and we will do a final test to verify nothing changed from the prototypes and then we will release to the public. This will be full feed and return lines with rails, regulator and fuel lines for those really looking to push the limits with out having to run an additional external tank.
Draco_PR23 (04-04-2013), kenward (04-04-2013), Lawnik (04-05-2013), Sportsguy83 (04-04-2013)
Old 04-04-2013, 04:00 PM   #20
charged86
charged86's Avatar
Will I get your updated kit if I order today?
Ryan
Old 04-04-2013, 04:20 PM   #21
Dustin@Dynosty
we haven't sold any of these yet until we do final testing to confirm the venturi is working properly and draining both sides of the tank, the factory unit has a built in regulator and venturi which draws off the fuel pump supply, so no matter what pump goes into the stock hanger, it bleeds some of the output off to feed the venturi, our setup will allow for full flow from the fuel pump
The Following User Says Thank You to Dustin@Dynosty For This Useful Post:
crook (04-04-2013)
Old 04-04-2013, 05:54 PM   #22
charged86
charged86's Avatar
Poop
Old 04-17-2013, 03:07 PM   #23
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
@Dustin@Dynosty have you guys experienced this http://www.ft86club.com/forums/showt...t=33991&page=2
Huehuecoyotl is offline   Reply With Quote
Old 04-17-2013, 03:10 PM   #24
Sportsguy83
Drives: Limited BRZ
Originally Posted by Huehuecoyotl View Post
"Thank you Sportsguy83, for bringing this to my attention" - Gem
Old 01-18-2015, 10:08 PM   #25
blown
Drives: ft86
any update on the drop in mods for this pump?
blown is offline   Reply With Quote
FS: Visconti Fuel Pump Sportsguy83 Engine, Exhaust, Bolt-Ons 0 03-31-2013 04:45 PM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 09:57 AM
New tail lights and fuel pump inc MindtheGap Mid-Atlantic 14 12-19-2012 07:42 PM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
