#99 |
NASA SpecE30 Racer
It is running it right now. It will be running it on Saturday as well.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | ALbadboy (03-27-2013) |
#100 |
NASA SpecE30 Racer
You would be right. You have two choices, add boost and pull more timing, or reduce boost and add timing. The octane of the fuel and knock are the limiting factors. John prefers to run more boost and less timing. He asked me to turn it up, so I turned it up to 14, and he tuned the fuel and timing to match.
- King Tut
#101 |
Drives: 2013 Subaru BRZ Limited (WRB MT)
Thanks for the ride again! The car is amazing! Waiting on dyno sheet & video!
#102 | |
#103 |
Drives: 2003 Subaru Outback
In for results
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
#104 |
#105 |
NASA SpecE30 Racer
Dynosheets and video will have to wait until tonight. It didn't put down the the horsepower numbers I was hoping for, and we had some issues with the tach input and RPM reading correctly.
- King Tut
| The Following User Says Thank You to King Tut For This Useful Post: | akuhei (04-02-2013) |
#107 |
NASA SpecE30 Racer
You can do it man. You just can't quit when you run into problems, and everyone will run into some problems. I can tell you that driving the car to work every day and enjoying it has made it all well worth the effort.
- King Tut
| The Following User Says Thank You to King Tut For This Useful Post: | Sportsguy83 (04-03-2013) |
#108 | |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
#110 |
NASA SpecE30 Racer
- King Tut
#111 |
#112 |
NASA SpecE30 Racer
Okay guys, time for the numbers. Let me start off by stating that I was originally told that they could log boost, but they couldn't log boost. We also had issues getting the tach signal working correctly. I am still not sure it was done correctly because each of these runs are really from 3000 RPM to 8000 RPM. I told the dyno operator to roll into it at 2500 RPM and start the dyno run at 3000 RPM. We also had issues with the AFM1000 air fuel on one of the runs. So overall it was not a great experience at what has always been my favorite local Dynojet where I have dynoed at least 5 previous cars. If anyone knows how to properly log RPM on a Dynojet on these cars, please let me know for next time.
Here is the dyno chart of two back to back runs: ![]() You will note the little torque spike as full boost hits. You will also notice that the torque tails off all the way to redline. The curve is definitely not as smooth as I was hoping for and may have been pulling timing. Ambient air temp was at around 83 degrees F. Unfortunately, I forgot my laptop and EcuTek cable, so I could not log the dyno runs. I did have my AEM Failsafe gauge though, so I know the runs were done properly to 8000 RPM as the gauge logs boost, AFR, and RPM. Here is a graph of boost on one of the pulls from my datalog: ![]() You will note that boost starts out okay maintaining 14 psi and then hits a weird area just after 5500 RPM. I have had this issue ever since I got the kit, but it seemed especially bad yesterday. I get boost spikes and valleys in that area all the time. I am using a 7 psi spring in my wastegate with a Grimmspeed manual boost controller. You will also notice that I got quite a bit of boost taper as RPM increased dropping all the way down to 11 psi at 8000 RPM. I am hoping to mess with wastegate springs and get an electronic boost controller to hopefully improve my boost curve. The car feels great as that big 240 ft-lbs of torque hit with full boost. Here is a video of one of the runs: [ame="http://www.youtube.com/watch?v=VBYNrQAe6VA"]King Tut's 2013 Subaru BRZ Dyno Full Blown Turbo - YouTube[/ame] As always any questions or suggestions are more than welcome.
- King Tut
| The Following 4 Users Say Thank You to King Tut For This Useful Post: |
| Tags |
| blown, fbm, full, king tut, turbo |
| Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 04:10 AM |
| TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing | TyperRspec789 | Forced Induction | 63 | 12-31-2013 08:39 PM |
| Full Blown Motorsports Stage 1 Turbo Kits PROVEN POWER!@ Pure Automotive Performance | Pure Automotive | Forced Induction | 86 | 11-26-2013 09:27 AM |
| The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! | Pure Automotive | Forced Induction | 181 | 03-12-2013 03:11 PM |
| The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive | Pure Automotive | Mid-Atlantic | 22 | 02-12-2013 11:13 AM |
