Old 04-02-2013, 10:15 AM   #15
Itssrayyxd
Drives: Scion frs.
Well I want to lower it about 1.6" max cause my area has bad roads. So I don't want to lose any control quality on the car either. I'm not going to track my car at all. And my budget is ~1k or so.
Itssrayyxd is offline   Reply With Quote
Old 04-02-2013, 10:26 AM   #16
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
Ksports coilovers fetch for right around 1000 bucks
Old 04-02-2013, 10:39 AM   #17
Itssrayyxd
Drives: Scion frs.
Ill definitely do some research on them as well
Old 04-02-2013, 11:29 AM   #18
CSG David
CSG David's Avatar
A shock/spring combo would be a better choice for you. My suggestion is Tein Street Basis (sub 1k) or Koni shocks and lowering springs. Both in which CSG carries.
Old 04-02-2013, 12:27 PM   #19
Itssrayyxd
Drives: Scion frs.
How long would springs last for? I don't want to get springs just to get coils in the future if the springs fail
Old 04-02-2013, 12:50 PM   #20
coastertrav
Drives: Whiteout FRS
Springs don't fail.
coastertrav is offline   Reply With Quote
Old 04-02-2013, 12:56 PM   #21
AllDayJonRay
Drives: 2013 Ultramarine FR-S
Springs DO fail, but what people are referring to failing is the shock absorber. The stock shock absorbers have a tendency to fail when the vehicle is lowered. The vehicle is more likely make the shock absorbers 'bottom out' (and work in a piston travel distance they were not designed for).
From what another member has seen (he is a Toyota Service Advisor), people have had decent luck with the stock absorbers when lowering 1", but he has seen multiple failures already when lowering the car more than that...
So if you do lower your car (with just springs), and your stock shock absorbers DO fail, you will likely replace them with aftermarket units, and use the same springs.
'13 Ultramarine 6MT FR-S || K&N Drop-In, SpeedFactory V1 Cat-Back || Moto-East tuned
Join the 86 Owners Clan on Clash of Clans: "86 Owners" Password: "fa20" || Help us take over the world || Thread
AllDayJonRay is offline   Reply With Quote
Old 04-02-2013, 01:13 PM   #22
Itssrayyxd
Drives: Scion frs.
If I went with the springs set up, what would the total cost be around if I get eibach sportlines with aftermarket shocks?
Old 04-02-2013, 01:28 PM   #23
OrbitalEllipses
Drives: Attitude
Do some research?
Your springs are probably $200...but there's only one aftermarket shock right now and that's the Koni. Those are $770 right now, but were on sale for 20% off last month.
Old 04-02-2013, 01:38 PM   #24
Itssrayyxd
Drives: Scion frs.
Do some research?
So it'll cost about the same as coils then.
Old 04-02-2013, 03:32 PM   #25
CSG David
CSG David's Avatar
It's not the spring that fails. It's the OEM shock that will fatigue over time. With lowering springs, the shock life will decrease. Aftermarket Koni's or shocks have a more performance oriented valving to handle the slightly more performance oriented spring rates. Although this setup may be close to a "coilover" setup in price, this particular suspension setup is better than the cheaper alternatives.
Old 04-02-2013, 04:05 PM   #26
Itssrayyxd
Drives: Scion frs.
About how long will it take for the shocks to wear out?
Old 04-02-2013, 04:36 PM   #27
CSG David
CSG David's Avatar
Shock life varies upon use. How abusive you are to them and how many cycles it goes through are just a couple things to take into consideration. You're essentially loading the OEM shock a little extra and causing the shock to work a little harder with lowering springs and slightly higher spring rates. However, if you want the car to look good while you're saving up money for a solid set of coilovers in the future, I'd say lowering springs are fine for purely looks. Just be extra nice to your car over dips and bumps to reduce to impact loading on your shocks.
Old 04-02-2013, 06:35 PM   #28
Itssrayyxd
Drives: Scion frs.
On average, how long should it last tho? Assuming there is minimal aggressive driving
springs vs coilovers?? which is best? FRS-HHH Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 06-11-2013 02:09 PM
Springs over coilovers ? brocktwalker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 02-24-2013 11:13 PM
Coilovers or lowering springs Hawk77FT AUSTRALIA 9 07-30-2012 09:41 PM
Coilovers vs Springs – What are coilovers and what’s better? phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 07-30-2012 12:24 AM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 08:49 PM
