Old 04-02-2013, 02:49 AM   #183
Retro86
Retro86's Avatar
Drives: Awesome
Originally Posted by Sco2355 View Post
Sob! I need this in my life! Any chance you have the part number for that stalk?
hahaha this made me laugh. i need it too
Retro86 is offline   Reply With Quote
Old 04-02-2013, 03:01 AM   #184
Retro86
Retro86's Avatar
Drives: Awesome
any news on that euro stalk part number?
Old 04-02-2013, 04:08 AM   #185
Sco2355
Nope. I haven't found it as of yet. Still trying though!
Sco2355 is offline   Reply With Quote
The Following User Says Thank You to Sco2355 For This Useful Post:
civicdrivr (04-02-2013)
Old 04-03-2013, 10:00 PM   #186
Lanbaldo3
Divine Wind - Dori
Lanbaldo3's Avatar
Drives: RWD
anyone know the dimension/measurment of the fog lights by any chance been seeing 3/12"-3" in diameter? looking to install mine soon with stalk just always wondered what the diameter?
1990 FC3S T2swapped! "Savannah"
1992 240sx Type X "Nadia"
2013 Scion FRS "Raven"
Drift Specials.....
Lanbaldo3 is offline   Reply With Quote
Old 04-03-2013, 11:05 PM   #187
zooki
Drives: waiting on a 2021...
.I just measured mine. I have the Subaru Outback lights, and they measure 3 1/2" in diameter.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
Lanbaldo3 (04-04-2013)
Old 04-04-2013, 06:32 PM   #188
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Got mine completed today.
Used the Tundra stalk and Nigel harness after a rewire to make it a negative tigger. One wire into the cab, the ground and attached to the white wire in the steering column.
One thing I didn't expect. With the headlights turned on the indicator in the dash works with the fog switch on. Turn the headligts off the fogs stay on and the indicator goes off. Turn on the high beams and the fogs and indicator turn off.
The fogs also stay on with the ignition off. I may go in a put them on a ignition switched circuit.
[IMG]http://i260.photobucket.com/albums/ii21/KySilverado/7DB72302-26E0-49EB-B***-3673E4B229E6-28278-00000581F45D30D6_zps056c8417.jpg[/IMG]
FRSFirestorm is offline   Reply With Quote
Old 04-04-2013, 07:06 PM   #189
zooki
One thing you may want to change if you use Nigel's wiring harness. It has the ground for the lights and the ground for the relay trigger tied together. If you use the Corolla/Tundra stalk to ground the trigger you will be putting all the power through that thin little wire. I cut the ground for the lights and grounded them separately.
Old 04-04-2013, 08:12 PM   #190
FRSFirestorm
Red is Fastest
I have the circuit grounds separated. Even so I'm still leery of such small guage wire even it is just in the coil circuit. I wanted and still may try and find the output from the ECU that I posted earlier in the thread. Its difficult to understand the manual and track down the specific connectors and pin locations.
Old 04-05-2013, 09:43 AM   #191
FRSFirestorm
Red is Fastest
Originally Posted by PatGT86 View Post
Everything I've read seems to indicate that the Toyota stalk (part number 84140-02670) DOES NOT have the auto position -- the only catch being that the retaining clip that comes with this one is too big and you'll need to remove & reuse the clip from the factory FR-S stalk.
If you google the part number, any pics that come up look like it's what you're looking for.
I have not ordered it yet, however I do intend to when I'm ready to complete this mod...
A note from my install. The retaining clip with the Tundra stalk worked fine. I did not need to change it.
Assuming its the clip with the red retainer attched in this shot.
Old 04-05-2013, 12:13 PM   #192
zooki
Aah, I thought the retainer was part of the clip when I glanced at it. I just swapped it out so I wouldn't have to take it back off if the cover didn't fit.
Old 04-05-2013, 03:35 PM   #193
FRSFirestorm
Red is Fastest
Originally Posted by FRSFirestorm View Post
Another tidbit from the wiring diagrams. If the wire from pin 30 of Body ECU happens to be found under the hood somewhere.... you won't need to run any wires through the firewall to turn on the fogs.
Quoting myself. I am finally understanding the manual. I originally thought there was an external PIN 30 you could tap to on the ECU to control an external relay to work the fog lights.
Everything shaded in gray is internal to the ECU. So if all the hardware is in the ECU on our Scions you should be able to put fuses in the fog light slots. Tap into pins 3 and 5 of Connector 3C of the ECU and run those two wires to each individual light. No external harness with relay needed and no worries of over currenting the white wire at the stalk harness.
The Following User Says Thank You to FRSFirestorm For This Useful Post:
civicdrivr (04-05-2013)
Old 04-05-2013, 04:25 PM   #194
norm24
Drives: TSX
Sorry, I'm a little bit confused. Are you saying that all that needs to be done to properly fire up the fog lights with a Tundra stalk is tap onto pins 3 and 5 of connector 3C, run the wires to both fog lights, insert fuses on the fog light slots? Is this how you did yours?
norm24 is offline   Reply With Quote
Old 04-05-2013, 04:55 PM   #195
FRSFirestorm
Red is Fastest
Yes, if the hardware is in the ECU. The two wires from the ECU would be 12v+, you'd still have to ground the lights. No I didn't do it this way. I didn't figure out the drawings till after my install.
Old 04-05-2013, 05:42 PM   #196
norm24
Drives: TSX
^ Thanks for the info. Now, how do we find out if the hardware is in the ECU???
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 11:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 01:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 06:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 04:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 01:53 AM
