Old 03-31-2013, 12:36 PM   #1
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Lightbulb 22w LED H11 Headlight Bulb (from AutomationLED) Review
So I've always liked the light put out by HIDs ever since I owned my 2003 Evo VIII which had them from the factory. I never liked the idea of fitting them aftermarket because I believe in ensuring my headlights are as FUNCTIONAL as possible. With an assembly engineered for halogen bulbs that has been fitted with an HID bulb aftermarket one may get more light output but the beam pattern will not be optimal. The cutoff may LOOK perfect but there will be bright spots and dim spots where you'd usually have even lighting AND you risk putting further stress on yourself as the driver and others' eyes due to this.
I liked the idea of the retrofit kits from TRS but had seen mixed reviews on them. Basically the reason I hesitated was that I'd never baked headlights before to take them apart so I was a little apprehensive. I also wanted to paint much of the chrome black if I did it but I'm a terrible painter and don't trust myself to do it.
When I saw these new 22w H11 bulbs sold by AutomationLED I was intrigued. They seemed like the best of both worlds. So I bought them at a price of about $112 shipped due to the current 15% off promo.
I installed them on Friday evening. The install was EXTREMELY simple and straightforward. The only problem I ran into was that the piece the factory harness plugs into has 3M double sided tape on the back to attach nearby the headlight but on one of them half the backing was removed already which left only half the adhesive functional and on the other the entire backing was removed so the tape was useless.
AutomationLED Sale Thread: http://www.ft86club.com/forums/showthread.php?t=27891
Review Thread by @sabSquishy : http://www.ft86club.com/forums/showthread.php?t=31403
Here's some pics:
Stock
IMG_20130329_195227 by Chewie4299, on Flickr
IMG_20130329_195252 by Chewie4299, on Flickr
LED on Left/Stock on Right
IMG_20130329_200012 by Chewie4299, on Flickr
IMG_20130329_200020 by Chewie4299, on Flickr
Both LED
IMG_20130329_200519 by Chewie4299, on Flickr
IMG_20130329_200530 by Chewie4299, on Flickr
So these things look great and the light is the perfect color. I was REALLY excited once I turned them on and was hoping that they performed well on the road.
Yesterday I drove two hours to a meet in RI and than had the opportunity to drive 2 hours home in the dark.
Notice the cutoff? The halogens have some light above them while the LEDs do not. This actually has made it harder to see highway signage at any real distance at night since the headlights are putting no light that high.
Also, there is significantly more light on the road right in front of the car now where it is not needed and less forward and to the left/right in 'deerland'. The combination of these two factors leads to it being quite difficult to see off to the sides on dark roads when you cannot use your highs because you aren't quite alone.
My final opinion is that these lights will look great for show purposes and, with properly engineered projectors meant to work with them, could probably be exceptional alternatives to HIDs but they just don't perform with the stock housings.
I'd honestly return them if I had that option but I don't so I'll probably plug them in for certain occasions but I think I'll be utilizing the stock bulbs for most of my driving.
Chewie4299 is offline   Reply With Quote
The Following 4 Users Say Thank You to Chewie4299 For This Useful Post:
Brzzee (04-02-2013), cdo221 (04-01-2013), infinite012 (03-31-2013), sastexan (04-02-2013)
Old 03-31-2013, 12:44 PM   #2
Yruyur
Yruyur's Avatar
Good honest review. Could always make crazy reverse lights out of them.
Old 03-31-2013, 12:52 PM   #3
Chewie4299
Spaceman
Chewie4299's Avatar
Haha... I think the LAST think I wanna do is blind folks that are looking in my direction when I'm backing up.
Old 03-31-2013, 01:09 PM   #4
eurominican
Bringing Hachiroku Back
eurominican's Avatar
Drives: 2013 Firestorm FR-S
Thank you for the honest review.
eurominican is offline   Reply With Quote
Old 03-31-2013, 01:42 PM   #5
_hollywood
Drives: 97 itr sold
I figured this would be the result, i put led reverse lights in my truck last year, they " appear" brighter but they just dont throw the light as far as i need, led technology is improving just not where it needs to be yet, unless the housing is designed for it....
FR-S #56 of 86 Raven MT ***FOR SALE***
_hollywood is offline   Reply With Quote
Old 03-31-2013, 01:44 PM   #6
Chewie4299
Spaceman
Chewie4299's Avatar
LED tech is pretty advanced. They just need special projectors since they emit light differently and are a different shape than other bulbs.
Old 03-31-2013, 10:17 PM   #7
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
LEDs are not meant to go in traditional headlights. Real LEDheadlights are designed very differently. Not shocked by your findings, sorry to hear you spent that much money tho.
Old 03-31-2013, 10:56 PM   #8
sid325
Drives: Ultramarine FR-S 6MT
I have the same set of LED headlight bulbs. I'm going to try them in my fogs. Thoughts?
sid325 is offline   Reply With Quote
Old 04-02-2013, 01:42 AM   #9
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Thanks for the review, it's too bad that these don't fit the housing better. Can you comment on the color temperature of the bulb? Are they really 4300k? They look a bit blue in the pictures, is it closer to 6000k?
cdo221 is offline   Reply With Quote
Old 04-02-2013, 03:21 AM   #10
ThugNasty
Drives: Asphalt FR-S
Make reverse lights out of them and smoke it
ThugNasty is offline   Reply With Quote
Old 04-02-2013, 06:02 AM   #11
Chewie4299
Spaceman
Chewie4299's Avatar
They're a crisp white. No blue.
automationLED: DIY LED interior + license plate conversion jjdrivesajazz DIY (Do-It-Yourself) Guides 84 04-22-2014 09:27 PM
AutomationLED LED Headlight Bulbs Review Squishy86 Cosmetic Modification (Interior/Exterior/Lighting) 7 03-31-2013 12:40 PM
AutomationLED LED Headlight Bulbs Review Squishy86 Cosmetic Modification (Interior/Exterior/Lighting) 0 03-18-2013 06:44 PM
AutomationLED set 4 Sale Jacob G. Interior Parts (Incl. Lighting) 1 02-12-2013 03:33 PM
BRZ D4S bulb ? MRZ415 BRZ First-Gen (2012+) — General Topics 82 06-28-2012 07:18 PM
